Question about Whirlpool GS6SHAXMB Side by Side Refrigerator
My Whirlpool GS6SHAXMB00 ice dispenser is not working.
When I depress the dispender paddle, I can see the flapper in the chute open slowly, but the auger doesn't turn. If the motor is dead, how do I replace it? Is there access to the motor from the front door? Please advise. Thanks.
  • thayerbt May 21, 2009
    I do not have the two screws. I ahve a whirlpool 56709500 and the whirlpool 5675500 does show the two screws. I cannot figure out how to get to the motor to replace it. Any ideas?
  • 725 Answers
The ice motor can be remove from a door just under the ice bin... two screws hold the door . four screws hold the motor in ...remove motor and check it may just be frozen. thaw it out check the seal at it may be let water drip down the shaft...
let me know
Posted on Dec 21, 2008
Kenmore cold spot refrigerator model # 106.56662500 ice is not dispensing through the door. How do I fix it?
This is common in these units. When the dispenser lever is depressed, an auger motor rotates the auger wire. When the auger rotates, it pushes the ice toward the dispenser door and chute. When the auger is defective, it isnt able to push the ice out of the dispenser. You need to check the auger to determine if it is broken or disconnected from the auger motor. If the auger is broken, replace it.
Jan 28, 2017 | Kenmore Refrigerators
My Kenmore frig model **********0 makes ice, but it does not dump it when I press the outside lever to transfer the ice into my glass
The paddle you push the glass against operates a micro switch that operates the solenoid to start the auger that delivers the ice to the output chute. It could be electrical (most likely) or the auger motor is no longer operating
Dec 05, 2016 | Kenmore Refrigerators
Can the flapper for ice be replaced?
Refrigerator model number? ice chute door replacement
26177815-rm0wrikgpdq1hfoxb3io2p34-3-0.jpg need your model number for the correct part Dispenser Door 8201756
APPLIANCE 911
Apr 27, 2016 | Refrigerators
Underside of ice bin freezes up built up with frosty ice, dispenses no ice. numerous times we have defrosted with blow dryer, removed, cleaned bin, replaced; cleaned out ice that was built up in lower part...
W10224328 Dispenser Door Spring
The chute door is the reason your ice bin is freezing up and also the chute door being open draws warm moist air inside your freezer compartment causing massive amounts of frost and keeps the compressor runing all the time between defrost. You really n eed to get the chute door fixed. What is the correct model number? For the model KSRX25FT dispenser parts click HERE The chute door spring may be broken but you will not know untill you open the dispenser housing. I'm here should you post the correct model number or have questions, Sea Breeze
Oct 17, 2013 | KitchenAid Architect ® Series II KSRX25FT
The ice maker will not dispense any ice. When the dispenser lever on front panel is pushed the dispenser door opens but the auger motor does not operate. If I thaw the freezer the auger motor will...
It sounds like your auger motor has an issue in my opinion. How i check them is: remove ice bin, open freezer door, hold door switch down, depress the freezer ice dispenser button on the door and see if the auger motor has the torque when it turns, if the motor has power and turns but cant turn w/ torque or has power and dosen't turn. you need a new auger motor. lmk if u need more help!
Aug 04, 2013 | Frigidaire FPUS2686LF Professional 26 Cu....
TRS21 cloggs in the chute
I have the exact same problem. Also it won't clog so easily if the snow is deeper because the auger moves more snow through (or if I run with it.) It seems to me that the auger should be as close as possible to the scraper bar without causing any friction. Do you think that distance adjustable, or would new paddles on the auger close the gap sufficiently?
Dec 26, 2012 | John Deere Trs21 Rubber Auger Paddle Set...
My ice maker makes ice but will not dispense it
When you push the lever to dispense ice, can you hear the motor running? If not, that motor might be dead and not turning the auger, which would be your problem.
If you can hear the motor and auger turning, the chute or the opening in the ice maker might be clogged up with ice. Clean the entrance to the ice maker and the chute in the freezer door and that should fix your problem.
Dec 13, 2010 | GE Monogram ZDI15C Automatic Icemaker
Motor does not turn to dispense ice when lever is depressed
The first thing I check is the door switch. As you know if the door is opened the ice chute won't function I would start there. I have an old manual from whirlpool that will give an idea HERE
Feb 10, 2010 | Refrigerators
Open Questions:
Whirlpool GS6SHAXMB Side by Side Refrigerator Logo
495 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
