Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
New machine now working
I have sewn several proactice stiches, and then changed the color of thread. Now the led light come on afer 2-3 seconds of sewing. I have rethreaded the original thread and the same light comes on each time. the manual says it is an operation error, but I can't figure it out. I have shut down the mnachine and restarted it but still same light.
    Genius:
  • 1,074 Answers
Pull out the plug to reset it self good luck.
Posted on Apr 07, 2007
1960s Elna Supermatic - lower thread only catches sometimes
Make sure you have the correct needles for this machine and that it is fully inserted into the needle bar and correctly oriented.
Mar 20, 2013 | Sewing Machines
I cannot get the tension to set correctly on my Singer 6268 sewing machine. For instance, I'm using red thread on top spool and white in the bobbin. Suddenly, as it always does, the thread is loos
I have solved my tension problems by going to threadmagazine.com. they have solutions to many, many problems you have with your sewing machine. Hope this helps. jdokos95
Aug 01, 2012 | Sewing Machines
Janome mini heavy duty sewing machine
when you sew keep a eye on the thread take up lever & see if the thread comes off while your sewing, I've had this happen to me & I've been sewing for over 30 years. if this does happen, take a pair of pliers & very gently close the take up lever just alittle but not enough to damage it.
also check the needle to see if it's damaged--if your not sure change the needle--flat side goes to the back of the machine
always make sure the fabric & needle & thread are compatable--the thread must be able to pull thru the needle with out any problem
also check to make sure there are not any burrs on the needle plate or bobbin or bobbin case
Feb 26, 2012 | Janome SEW MINI Mechanical Sewing Machine
Sewing on reverse of fabric
There has to be thread on both sides of the cloth in order to form a stitch.
Refer to the maintenance section of your machine and clean the machine as recommended.
Did you change the thread or needle?
Check the manual to be sure the threading is correct and was done with the presser foot up.
Is the needle is correctly installed?
Check the bobbin to be sure the thread is feeding in the correct direction and through the guides on the side of the bobbin case.
Apr 29, 2010 | Brother LS-1520 Mechanical Sewing Machine
The top needle unthreads after just a few stiches. I have a Singer 2950 and am new to sewing.
Are you saying that the thread is breaking?
CAUSES of upper thread breaking
needle is in backwards
improperly threaded
tension to tight
needle bent or blunt
thread to coarse for size of needle
needle too long for machine
burr on needle
tension discs worn so that thread works in grove
neele too fine for size of thread and fabric
lint or dirt around bobbin case holder
irregular sewing speed
AND THE BIGGEST PROBLEM IS:
threads not properly pulled back under pressure foot when starting to sew
This means, Have enough of the upper and lower thread pulled to the back and hold for the first 2-3 stiches,
Do this every time and it will become second nature and you will do it automatically
Aug 28, 2009 | Singer 2950 Mechanical Sewing Machine
Bobbin thread is loose (under stich)
Not a tension problem, refer to manual and rethread the top thread, 95% + this fixes problem.
Jul 04, 2009 | Sewing Machines
Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Apr 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
The thread knots up under the feed dog on about the second stitch
hi! well, you can try to set up your thread accurately followed this
53de094.jpg fig.bobbins se up of thread.the thread should be clockwise rotation coming out to bobbins casing,insert thread on slot to acquired bobbins tension.after setting up you insert your bobbins on shuttle
casing.next set up your upper thread tension.on fig is just a sample.9cbc7d3.jpg follow the red thread set, try this on single straight sewing with dial stich set up to # 8 range to #17,Dial tension to # 3. use cotton/polyester foe sample sewing. try on hand maual sewing first several time before applying foot pedal to avoid needle breakage,
Mar 17, 2009 | New Home L-373 Mechanical Sewing Machine
Trouble with sensor
The upper thread sensor on most Brother's is activated by the check spring. Either your check spring has broken or is stuck. You may be able to fix this if you can get to it. A drop of oil may be all you need. I may be able to give more specific advise if you tell me what model it is.
Feb 06, 2009 | Brother Sewing Machines
The top thread will not grab the bobbin thread to complete a stitch.
its common, but easy to fix,,,ok......first things first, 1. bobbin in bobbin case correctly 2. machine threaded correctly 3. tension set around 3-4 upper 4. when was the last time machine was serviced
Jan 20, 2008 | Brother SE-270D Computerized Sewing...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
48 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
