Question about Technics SL-1210 Turntable
Just got a brand new techincs deck, never had one before. The instructions for fitting the lid say to just put it on top of the deck, only there are no brackets/hinges that I can tell. Do I have to buy these seperately?
I went into my local hifi shop today and asked what to do and got an answer for free without having to sign up and pay to use your website.
Posted on Dec 22, 2008
I got a white LT125 can i put a craftman mower deck on it
LT is a MTD brand so I doubt it will bolt up with a lot of modification. Most likely more trouble than it's worth.
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_722ea729aae6fd07
Jul 20, 2016 | Garden
My 97 honda civic has been in an accident before now my trunk doesn't close completely and water gets in my trunk how do I fix that
The fix depends on what was bent - the deck lid or the back of the car. To find out, clean the rubber seal with brake fluid on a rag, then dry the seal with another clean rag. Put a small amount of motor oil on your finger tip and put a small line of oil on the top of the seal, making sure you have enough oil on the seal to wet it all the length of the seal.
Now close the deck lid GENTLY. Open the lid and inspect the surface of the lid that contacted the seal, as well as the seal. The area of the lid that is dry is where the lid and seal are not contacting.
If you cannot determine where there is oil or not, you can try putting a small amount of fine ground dirt on top of the oil before closing the lid. If you can see bends in the deck lid surface, replacing the lid should fix the problem. If the deck lid is straight, then you'll need to have a body shop fix the car ( expensive). It is also possible the seal is flat, torn, or just worn out - in which case replacing the seal will cure your problem.
Hope this helps!!
Jan 25, 2014 | Cars & Trucks
How do i use the deluxe smoker (brand name outdoor expedition). There were no instructions
Outdoor expedition deluxe smoker. Place stand (black metal with leg on each corner) on level surface. place metho cups in the holes and add metho 1/4 cup. place the large metal dish on top with the handles provided inserted into the holes on the side in such a way that they clamp the lid down when fitted. spread about a table spoon (experiment for taste) of sawdust over bottom of metal dish. It can be dampened. Put drip tray on top of sawdust. push metal rack with side arms up into metal dish. (with food on it). clip on top rack (with food). Clip on lid, light burners and cook for around 15 minutes. Bon apetit.
Feb 12, 2011 | Sport & Outdoor - Others
Will not turn on or fill up
Are you able to remove the cover on the control panel on the top?
There is a fuse inside, that might have failed, (open).
I am sure you determined that the receptacle you are plugged into is still live?
Tell us more-- and more symptoms-- like indicator lights, etc.
Mack B
Jan 10, 2011 | Roper RTW4300SQ Top Load Washer
How do I put the convertible top down ?
If you reach behind the headrest on the driver's side, you should feel a handle. Pull that handle to release pins from the rear deck lid. Then there is a small yellow button under the deck lid or you can use the slide switch located on either door to release the deck lid. Next you must unlatch the front by pulling on the handles located above each of the visors. Then, with the deck lid open, fold the top down into the cargo area and close the deck lid.
Hope this helps.
Jun 26, 2010 | 1990 Chevrolet Corvette
Top drawer is hanging up on something
The only way to fix this is get the drawer out by
1 Open the drawer fully.
2 Depress the right-hand tub clip and push it back about 30mm (1
inch). Repeat for the left-hand side.
3 The tub may now be lifted up off the drawer runners.
4 Slide both runners back into the product.
5 Refit in reverse manner.
That way you can get access to the top seal - which is called the lid.
You will have to see how much of the lid is still left behind hanging on the top.
To remove lid
1 Remove tub assembly as per earlier instructions
2 On the right-hand side of the lid release the two tabs that clip the lid
to the yoke. Repeat for the left-hand side.
3 The lid is now free to slide out of the chassis.
4 Refit in the reverse manner taking care that the lid is fitted the
correct way around. The front is indicated on the top of the lid.
If the whole lid is intact then it may be a matter of fitting it back. Othwerwise you will get one from fisher and paykel parts
To fit the lid back you will have to check if the actuator yokes are not broken. In which case you will have to take these out and replace with the new one. (comes as part of lid kit if you buy it).
Remove Yoke
1 Remove the lid as per instructions above.
2 Release the lid actuator connecting arm from the bottom of the yoke
by squeezing the two tabs towards each other.
3 Slide the front of the yoke downwards at an angle until it moves out
of the track in the rear of the trim, and is clear of the chassis flange.
4 Refit in the reverse manner taking care that the yoke is the correct
way around.
When putting back you will need to align the lid actuator motors on both sides correctly so that the yoke moves the same distance when activated. Otherwise the lid will have a scew.
Hope all this helps. If unsure you will need to contact a technician.
Jun 01, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Replacing lid on old Maytag toploader
pull the lid back at angle and they will fall into tub.put one side in wet the other side and try to put ball on lid and slide it back into slot for lid ball.may be a hasssle but it will go into place.
Mar 09, 2009 | Maytag PAV2300 Top Load Washer
Salton Yogurt Maker GM5 plastic lid replacement
I have the same problem.  I used to place plastic wrap on top and still use the old cracked lids.  Now, I cannot find my instruction booklet.  Can you help me?
Jan 01, 2009 | Crock Pots & Slow Cookers
Does not pump water out or spin after first wash
Dear Customer
Please perform the following
The first thing to check is the lid switch. Open the lid and you'll see a recessed spot that a tab on the lid fits into. Put a screwdriver into the spot, press down and see if you hear a click. If you don't, the switch is bad. That's if you're lucky.
It could also be something as serious as the transmission. Try this: In the search box at the top of the page, type in repair (brand, like ur Whirlpool or anyother etc) washer. A list of sites will come up with a bunch of troubleshooting tips and repair instructions. I used this to fix my washer a couple of weeks ago. Good luck.
Please rate this,Thank u
Dec 17, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Bose wave radio/cd often cd spins but does not play, sometines will correct if I turn unit off and on. HELP tHANKS
I've repaired about 10 type Bose AWRC3x (the radio/cd model with lift up lid and top controls). If the cd won't play or skips, try cleaning the lens VERY carefully with a cotton bud with some isopropyl alcohol. Let it dry then try again. This will help in about 1/3 of cases.
After that, a new laser unit is needed. They cost around 15 pounds,30 dollars, (Type SFP100s with 13 pin connector made by Sanyo). You need to have some electronics experience to take the case to bits to get the laser deck out, change the cd laser and reassemble. Basically, DISCONNECT THE POWER! Remove the 3 screws on top, turn over and carefully prise the front of the base away from the top cover with a table knife or similar. Lift off the top cover - be careful with the lid ribbon! The deck can be disconnected from its ribbon cable and wired connector very carefully. Take the deck to bits and fit the new laser head (take photos if you think it will help). Remember to unsolder the shorting 'blob' of solder which protects the new laser from static till its fitted.
On the bright side, there is no tracking etc to set up, that's all automatic so usually they work like new with a new laser fitted. I have to say this is the weakest feature on the Bose CD radio, the actual electronics rarely gives trouble.
Hope this helps Steve O'Donnell
Nov 27, 2007 | Bose & Wave& Music System
Technics SL-1210 Turntable Logo
64 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
