Question about GE JTP27 Electric Double Oven
No power to oven
I shorted out one of the oven ligths while replacing it, now there is no power to the unit. I checked the breakder box and the breakers for the oven did not trip. Switched them on and off just to make sure. Is there a secondary fuse or would the oven circuit be run through a GFIC circuit? Tny insight you have is greatly appreciated.
    Top Expert:
  • GE Master
  • 8,248 Answers
  • GE Master
  • 1,769 Answers
No watvto know about the fuse without a model #
Posted on Nov 04, 2017
  • 4 Answers
SOURCE: Unit has no power.
I know what you mean. I was cooking with this appliance tonight and suddenly it displayed an f-3 code. My advantium oven is less than 8 months old. Not sure how this happened or how to fix the problem. In order to sleep tonight (the constant beeping) I had to shut power off at the breaker pannel. Is this representative of the the type of quality that GE stands for???? I am sooo frustrated. I cook with my advantium oven all the time and love the dual abilities of this appliance. Like I said this is brand new and to have the f-3 code which apparently (from what I read) is a failed key pad. I am very dissapointed and am begining to think about pulling my stock from this company!
Posted on Dec 26, 2007
  • 1314 Answers
SOURCE: Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Posted on Jan 30, 2008
MNTECH
  • 1543 Answers
SOURCE: GE glass top and oven are not heating?
Sounds like you are only getting 120 volts to the range. Make sure you are getting 240 volts across the two outer terminals of the range power block (where the incomming power connects to the range) and 120 from each of these to the center nuetral.
Posted on Jul 18, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Oven will not heat past 100 degrees.
Hello there:
It won't bake or even heat up correctly or If your oven won't bake, check these: Bake igniter Other causes Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself. The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame. Other causes Other reasons that your oven may not bake are: The clock settings are incorrect (if you have timed baking or a self-cleaning oven). The thermostat is defective. The safety valve that prevents accidental gas flow is defective. The selector switch is defective.
Posted on Jul 25, 2010
SOURCE: oven will not heat up. microwave works fine. all
oven will not heat up. microwave works fine. all oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where is it located
Posted on Aug 22, 2010
If you switch oven on it trips main power. what can cause that
Probably close to 50 things could cause that, but here are a few of the most common: Bare wire in a harness of the oven, causing a short-circuit in the line. Faulty plug on the power cord. Outlet in the wall is damaged. Loose wire in the outlet box, causing a dead short. Bad wire between the outlet box and the main breaker box. Weak breaker, or a breaker that isn't heavy enough to handle the load of the oven. (especially, if you just bought a new oven, it may need a larger breaker to handle start up.) Use a fused multi-meter (voltmeter) to check for these issues, and do not try to fix it if you are not familiar with electrical work. It could cause a fire, or give you a deadly shock.
Feb 12, 2017 | Ovens
Think i blown a fuse/ where do i find the fuse
First check to see if power is coming from outlet, with meter or check breaker in panel box of main. Then you will need to be careful and check inside of oven power supply inside unit
Dec 22, 2007 | Whirlpool RBS305PDS Electric Single Oven
My baumatic oven elemant burned out and blew mains fuse,so replaced both and their seems to be no power at all getting to oven
Some units have their own fuse. Usually near where the power supply goes into the oven. Check your Meyer box for tripped RCD or circuit breaker too.
Nov 22, 2014 | Baumatic Ovens
When turning oven on there is a beeping sound and error code F1
Most of the answers are correct, the EOC (Electronic Oven Control) is either damaged or shorted. I've also seen the F1 code come up on the version 2 and 3 units when the temperature probe was shorted. But most likely your EOC is damaged and needs to be replaced. Since you didn't give us a model number we can't give you any more info. Good luck
Mar 14, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
My built in whirlpool oven has no power
What is the model number of the unit?
Nov 05, 2012 | Ovens
My oven is not ligthing up
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 07, 2010 | Frigidaire Ovens
I can't get the stove to heat up! The pilot light is on and the burners all work
check the bottom pilot ligth in the boril at the back to the top that poilt ligth it for the ovens
Oct 18, 2010 | Ovens
Both elements in oven don't heat up.
Have you checked the breaker box to see if a breaker has tripped? To reset it you would need to make sure it is fully off then turn back on. You can also check to make sure that the elements are not corroded and causing loss in contact. If the breaker is good and the elements are making good contact. You can check the element contacts with a multi-meter by removing one element and checking the power to the element at the back of the unit, just remember that this is a 220 volt system, so be very careful with the contacts. If there is no power registering it could be that one of the wires for the power to the elements has shorted out.
Oct 14, 2010 | GE JKP86 Electric Double Oven
Oven not workiing
If it is a double oven, then there will not be a plug fitted to it.
It should be hard wired directly into a main 30 amp switch box
If there is no power at all, then it could be a faulty main switch unit, or
the fault could be at oven connector block.
You really need a meter to check for power, both at the switch box and the oven itself.
Another possibility is a fault with the timer unit on the oven itself.
Apr 05, 2010 | Neff U1421 Double circotherm Electric Oven
GE JTP27 Electric Double Oven Logo
56 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
