Xp wireless manager prompts for WPA2 key. I enter code from sticker. No connection . If I go into advanced settings the network has a shorter code saved under network key. I try to replace with the longer WPA2 code but it is always overwritten by smaller code after i revert
SOURCE: missing drivers after reinstall
Yes :c)
Go here and select the type of notebook you have, whether it's an intel processor or an AMD processor. Follow the links to download your audio, network video, and wireless adapters as well as the motherboard drivers. Run each download and it will tell you step by step on how to install the manual ones and most of them will install automatically.
Thanks and please take a moment to rate as fixya.
SOURCE: Acquiring Network Address
reset the modem and the wireless router by powering them off for 30-60 seconds, then plug power back in. Wait a minute or so for the devices to reset then go to the PC and try to connect again
Good luck
SOURCE: Secure Wireless Connection Says It's Out of Range
Follow the steps in the SecureW2 user guide to make sure that "Enable IEEE 802.1X authentication for this network" is enabled.
User guide here: http://www.securew2.org/wiki/UserGuide
SOURCE: xp drivers for nokia 6300 usb port and modem
Hi Nic,
Go to this site and download drivers for your USB:
http://www.driversupdate.org/?gclid=CJWxyPOpuZoCFQWfnAodUlL4cg
I am not familiar withat Nokia suite. Do you know if it is dial up or DSL? When you press that button, do you hear white noise and then a dialing sound?
If this does not solve all your problems, please reply.
Sirwriter
SOURCE: DELL E6400 Connect to wireless Modem problem
I have the EXACT same problem on the same computer.
I'm not an expert so I searched online but didn't really find a lot of responses to this Dell issue. One suggestion was to turn off Intel PROset and let Windows manage the wireless connection.
That worked for me.
When in the Intel PROset menu, click on Advanced, then click on "Let windows manage your wireless set-up."
Alternatively, you can toggle between the two software by pressing F10.
This solution worked for me.
