Question about HP Pavilion a810n (PP164AA) PC Desktop
HP CD Drive Will Not Open
The "DVD/CD Writer Combo" Drive on my HP computer will not open.
When I push the button for it, I can hear it make a little clicking noise, but I don't think the disc inside is stuck.
This has happened before. The disc drive wouldn't open for WEEKS then one day when I tried to open it, it just did, like nothing had happened.
Please help! It has been stuck for almost a month now and I'm really frustrated.
The second drive, "DVD- Rom" will still open just fine.
  • Anonymous Jan 13, 2009
    i pushed the eject button but it just wont come out. How do i fix it??
  • 34 Answers
Take a pin/needle, and stick it in the small hole which should be somewhere on the front of the dvd rom. This should open the drive a bit, so that u can pull it out. then close it, and try if it opens then. If it doesnt, then you will have to grease the sides of the slide (from the bottom) a bit with vaseline. open and close it manualy a few times, and try then. If it still dont work then, then you may need to replace the little black bellt which it has just underneath the tray, towards the front of the drive.
Good luck
Posted on Dec 21, 2008
Lightscribe dvd drive won't work. the eject command does not make it open either. seems to be jammed. if i break it down can it be "unjammed" without ruining it?
Actually it's probaly just got some dust or something in it. What you do to manually open it is take a needle, thumb tack, or safety pin and simply insert it into the tiny hole above the eject button on the dvd drive itself. You'll feel the tip of the button when you push the pin into the hole then it will pop the door and the drive will open properly. This has gone on for cd/dvd drives for years. Usually just the cause of dust or what have you being stuck in the mechanism.
Jul 01, 2013 | Computers & Internet
I have an HP DVD+R/RW 16x10x32x4x2.4x8x Drive and i am trying to find the drivers for it to see if it works on my computer. I have tried typing up the Product Number and HP Part Number on the HP website,...
DVD-RW 16X HP DVD Writer 740b Drive Firmware Update ftp://ftp.hp.com/pub/softlib/software7/COL16063/pv-42566-1/sp26595.exe
you must be logged in as the computers administrator to install this update
or
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07165&cc=us&dlc=en&lc=en
Update your HP desktop computer to have the latest software and drivers available. HP provides many software and driver updates free of charge
hope this will help you
  • You must be logged on as an administrator to install this update.
  • HP DVD Writer 740b drive.
  • Blank floppy diskette, recordable CD (CD-R), or USB Thumb Drive.
  • Released: s.gif 2006-08-23 Version: s.gif HI24 Compatibility: s.gif Microsoft Windows XP
    Aug 21, 2011 | HP/5.25 16x10x32x4x2.4X8x IDE Carbon...
    I have an HP dvd1040 Lightscribe DVD RW burner. It's been working fine ever since I bought it over a year ago. All of a sudden, today, it won't open. What can I do to get it to open?
    there should be a small pinhole on the front of the drive.
    insert the end of a paper-clip straight into the hole, you should feel a little resistance. push in a bit until the drive bay cracks open. use your fingers to pry it the rest of the way open.
    Nov 07, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
    Drive light goes on and disk turns in drive, but computer is not recognizing drive.
    hi
    check with original CD (silver)
    if you mean you cant find your dvddrive Icon in mycomputer open the case and check your dvd writer cable (is connected correctly)
    if there is two dvdrom in your case
    or both connected in one cable (ide)
    you have to set your drive master and slave with the jumper's in back side of dvdrom
    Jun 12, 2010 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
    Sony DVD ROM will not open, light comes on and tries to open but will not. Other DVD works fine. What with the Sony DVD?
    try to find a tiny hole on the drive( near LED or eject button) and insert a niddle or some kind of hard pin which can go inside of it push little bit hard (drive will open) , dont keep your drive empty if not in use put any useless DVD ROM in it so that it will get open when you want to use
    Apr 24, 2010 | Sony CRX320EE-88B CD-RW/DVD-ROM Combo...
    My dvd-writer/cd-writer combo will not open?
    look a tiny hole in the front of the CD/DVD drive use a paper clip to pull out the tray, when you have the tray out use the EJECT bottom in the drive to close and wait 3 seconds and press again to open, do this at least 3 times.
    Fosg2000
    Feb 24, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
    Dvd writer/cd writer will not eject the cd
    Look at the drive where you normally eject the disk you will see a pinhole near the button now get a needle or a pin and insert it inside the hole and push slightly and this will eject your disk. You can also open My Computer and right click your dvd drive and select eject.
    Dec 30, 2009 | HP Pavilion a620n (PC028A) PC Desktop
    My liteon combo sohc-5235k won't open its door
    Straighten-out a thick paperclip and push it into the small hole just below the tray, usually towards the center-left. It must be pushed in straight, and when you meet resistance, use a little force. This is the drive's "emergency open" system.
    Get the disk out and then replace the drive with a different brand like Samsung, HP, Plextor, etc.
    May 13, 2008 | Lite On (SOHC-5235K-BKRTL) CD-RW/DVD-ROM...
    HP Pavilion a810n (PP164AA) PC Desktop Logo
    430 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
