Question about Xantrex Technology Xantrex Xpower 1750 Plus High Power Inverter
Fues blown in xpower inverter 1750 plus
What cause all eight fues inside the inverter to blow up
  • 3 Answers
These fuse are often intend to protect voltage inversion. (reverse voltage)
So, if the eight fuse are blown, then maybe the voltage red and black wire were not connected to the correct polarity.
then again, even if these fuse are intend to be use as reverse protection, it may occure that transformer short out, transistor short out and many other short circuit inside the inverter as occure.
So replacing all eight fuse might not restore the unit function, they may even blow again.
Also, reversing polarity that cause the fuse to blow might have damage the transistor stage.
I am still, investigating few other problem with those unit.
I don't have all answer yet.
regards,
Hitheck
Posted on Apr 13, 2009
  • 74 Answers
There must of been a power spike.
Posted on Dec 22, 2008
Xantrex power inverter 1750
The 14 AWG Positive wire should be connected to one side of a 30 A relay (typical fog lamp relay available at most automotive stores). The relay's other 30 A contact should be connected to the battery positive post via a 10 AWG (up to 6 ft/2 m)
Sep 07, 2008 | Xantrex Technology Xantrex Xpower 1750...
Xantrex powerpack 400 pluse air compressor needs new piston were can i find one
http://www.xantrex.com/power-products-support/overview.aspx
That link will probably not get you much help but it is all Xantrex offers for out of warranty products. You may be better off to find a small compressor at Walmart or autoparts store and see if you can adapt it to the space in the PP400.
Sep 03, 2012 | Xantrex Technology Statpower XPower...
Serial#C11088451 no a/c output after switch is turned on from recepticle & battery charge % or output power watts display not working
Check inverter fuse, the fuse contacts and, check switch itself. I have seen numerous failed switches of the same configuration on other devices
Dec 30, 2011 | Xantrex Technology Statpower XPower...
Wont charge
My powerpack will not charge at all. I have used the cars charger as well as the typical wall plug in. I have left it plugged in for a week and only get an alarm sound and no power is coming out. Any suggestions would be greatly appreciated.
Feb 28, 2011 | Xantrex Technology Xpower Powerpack 400...
My powersource400 have never last more than 4 hour and that is with a destop and a 75 watt bulb.
Assuming a car battery with a capacity of 70Ah at its nominal voltage of 12V, the total energy stored in it amounts to 12V * 70Ah = 940Wh.
Your Xantrex XPower 400 Inverter is designed to deliver continuous power of 320W at a specified efficiency of 90% (I doubt that, this degree may be achieved for ideal conditions of load / outside temperature / air humidity / current beer price, but not for the whole power range, but let it be 90% for the argument's sake).
Lets assume your desktop needs 150W of power (no high end CPU or graphics board involved), plus the 75W light bulb, plus 10% loss due to power conversion, gives a total of ~280W power need.
This is well inside specs, so no problem here.
However, your battery can deliver this power for 940Wh / 280W = 3.8h only until its completely depleted.
Your observation of four hours of time from full charge to depletion is thus quite exactly what you can expect, you have no reason for complaints unless you were promised a longer time under the conditions you give.
Oct 19, 2010 | Xantrex Technology Xantrex XPower Power...
14.1VDC going into inverter but no ACV coming out. Red fault light is on. Disconnected fan motor and checked with meter and shows open even on high ohm scale.Are Xantrex fan motors known to go bad?If the...
If you don't have enough current to run the inverter, even at 14.1 v, it will go into protection. Make sure the wiring is heavy enough to provide the current needed to run the inverter. There should be a label on the fan saying what vosges it needs to run. Try powering up the fan outside the inverter.
Nov 24, 2017 | Xantrex Technology Xantrex Xpower 1750...
Porta wattz 1750 inverter
turn the unit off and then disconnect the negative from the back and turn th unit back on that way the inverter will use all the charge kept inside.
Reconnect the negative and start the unit ...I did that to my unit and for fun I asked tech support for help they told me that I need to buy ne one...After I reset my unit I been using now since for over 2 years...sometime it come back one every few months if I have high voltage coming and I redo this again and it works...save your money
Oct 31, 2007 | Statpower PW-1750 Triple Outlet 1750 Watt...
Xantrex Technology Xantrex Xpower 1750 Plus High Power Inverter Logo
635 people viewed this question
Top Xantrex Technology Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Xantrex Technology Car Audio and Video Expert? Answer questions, earn points and help others
