Question about HP Pavilion dv6000z Notebook
My notebook heats a lot!!!!!!
Is it true that the AMD processors produce much more heat than their INTEL counterparts???
i have a HP Pavilion dv 5 1106 ax notebook with an AMD TURION X2 RM-70 processor inside.
i recently downloaded this software SPEEDFAN to keep a check on my notebook temp.
i was surprised to see the temp hovering around the 80 C and the 90 C.(a max of 94 C when i was playing a game,playing music,browsing simultaneously).
even while i was just writing this to you...........temp was in the early 80's C.
Is this a normal temperature????
What harms can a high temp like this can have to my notebook in the long run??
In the worst case should i consider of switching to a CORE 2 DUO.......i mean replacing mine with it if that is possible????
    President:
  • 1,073 Answers
First of all, AMD in generall gets hotter than INTEL, but thats very high heat you having there. My mind goes to the cpu, maybe its not that good isolated whit the zinkpasta.
Second, you cant change from AMD to INTEL without changing the MoBo, there is diferent sockets on AMD and INTEL.I have a Ferrari loptop myself with an AMD, i can fry eggs on it from the heat when i play games. Therefore its very importat to clean the fan as often as possible. But 80 degrees celsius is way to much. With that temperature you soon will burm the HDD and or the MoBo as i did on mine.
Good luck to you
Posted on Dec 21, 2008
    Scholar:
  • 130 Answers
Hello, here is the deal, AMD and INTEL both have CPU's that have low heat. In your case you would have to buy a new laptop to switch from AMD to INTEL. The laptop motherboard take's only one socket type, for exp.. you would have to get another TURION at faster speeds or less speeds in the same socket family. Try to keep the vents open, sometimes the vents for the air from the fan come out the bottom not the back. You might want to invest in a laptop fan stand.
Hp a6750y After surfing the web for about ten minutes the computer locks up then you have to rebot it
Ok. Starting with the simple first. This machine has an AMD processor installed. They, by historical design, tend to run hotter than their Intel counterparts. Before I went crazy, I would open the machine and inspect the cooling fan and heat sink to determine if they have been clogged by dust and debris. Heat is the worst enemy of a PC, and CPUs will shut down when too hot. If you see clogged fins in the heat sink, get some canned air and blow out the debris. Hopefully that will solve the problem. If you smoke near the machine or keep the machine on the floor, it will clog up much faster than normal.
Dec 03, 2013 | HP Pavilion a6750f PC PC Desktop
What is the best processor to get for upgrade?
Here is the Fastest processor that will physically fit Turion 64 X2 TL-68, but this will use more power and generate a lot more heat. The best I would advise is the Turion 64 X2 TL-60 This draws the same power and will increase the speed to 2Ghz on 2 cores. So the extra heat produced should be minimal and your battery life should be very similar.
Aug 02, 2013 | HEWLETT-PACKARD HP Pavilion DV6325US AMD...
Difference between DV6000 Intel mothearbord and DV 6000 AMD motherboard
The DV6000 is a moniker for an entire series of laprop computers, each with a unique model number that has some variation the DV6XXX. Some will have Intel Core Duo, some Intel Celeron, some AMD Turion 64, and some AMD Mobile Sempron processors. Features, speed, and cost will vary appropriately with the Obviously the AMD and Intel boards are different and you cannot swap processors between boards. Here is a link to the HP Maintenance Manual for the DV6000 series laptops. It lists all the Mainboards used with the series and what processors go on them. It is useful for ordering replacement parts and gives instruction on disassembly and repair.
http://h10032.www1.hp.com/ctg/Manual/c01035677.pdf
Oct 19, 2011 | HP Pavilion dv6000 Motherboard
Describe your HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook Problem SCREEN WONT TURN ON LED LIGHTS OF POWER BUTTON...
The dv6000 series was commonly affected by the video card heating up and reseating itself. This was usually a soldering issue. You have a few options, You can either replace the motherboard, or have the motherboard reflowed. Unfortunately the video card itself is not detachable or individually replaceable.
I personally would recommend the second option as purchasing another dv6000 board will likely end you up in the same situation a year or 2 later.
A repair / reflow services on ebay
Dv6000 Repair
This repair tech only does amd processor models, Not intel.
Hope this helps.
Aug 29, 2011 | HP Pavilion dv6000z Notebook
My hp dv6000 in going hot after a few min. why?
This is the intensity of heat the processor and the inability of the cooling fan can cause overheating in this failure in part card that beats the screen and my advice to you, but you run the machine a lot that can solve this problem
Apr 17, 2010 | HP Pavilion dv6000z Notebook
My notebook overheats!!!!!
I have never heard of that about AMD cpus, on the contrary it has always been the Pentiums who overheated, nevertheless, it does sound like you are running a little hot, I would suggest a laptop cooler like an Xpad, that should cool it down down at least 5-10 degrees, try it you will be amazed what a difference they make.
Dec 21, 2008 | HP Pavilion dv6000z Notebook
Amd turion x2 rm 70 mobile processor
I will be glad to share my little knowledge in this senario.
Basically, I am personally a fan of AMD processors who is the first to manufacture 64 Bit Processors for Desktops and Notebooks.
However, if you remember, Intel started concentrating on Performance and not on Speed after AMD was able to design processors which were able to outperform Intel processors with slower speeds.
So, you need to look into Performance and not into Speed of the Processor.
Coming to the processor installed in your notebook, it is normal but I recommend you to use Windows XP than using Vista since Vista need more RAM and processing power when compared to XP.
Also, Windows Vista Home Basic is the basic version among the Vista family with very little features.
Coming to the Heating issue, this is common for all Notebooks to heat up when used for long time since the Notebook parts are palced in a very small where if any part heats up, it is passed to other parts too.
Make sure that the Cooling Fan Vents in the Notebook are not filled with Dust.
You can find these vents located at the rear of the notebook from where the hot air should be emiting from inside the Notebook.
I recommend you to use a Vaccume Cleaner or Air Blower to blow away invisible dust which might be blocking the airflow.
Also, make sure that the Notebook is placed on a flat surface like a Table so that there will be air flow from the bottom of the Notebook and the Cooling Fan will be able to **** in the required air from the bottom and dissapate the heat generated by the internal components.
Also, check for any BIOS Update is available for your Notebook related to this issue and update with the same.
You need to contact HP Chat Support and get the exact BIOS Update for your notebook since updating the BIOS with incorrect Update will make the Notebook useless.
Hope this gives some idea about your doubts.....
Nov 02, 2008 | HP Pavilion DV5234US Notebook Laptop
Amd turion x2 rm70 vs intel core 2 duo t5750!!!!
I read this and don't believe you - yes the AMD dual core gets hot - yes AMD processor are HOT processors - is intel better - no there on par with AMD - the thu put rate is so close it doesn't matter - now vista basic is just that BASIC - if you want to bump it up - home premium 32 or 64 but ultimate 64 should get it going.
Oct 30, 2008 | HP Pavilion DV5234US Notebook Laptop
I got an AMD turion x2 64 processor in my new notebook n after reading reviews comparison to core 2 duo i m really tensed!
You made a good choice. In the CPU arena right now, the difference between the two CPUs is a toss up. The slight advantages of one vs. the other in benchmark tests is nominal and actually artificial..
What happens with an AMD CPU is with the associated GPU onboard. And with a 64bit processor, the number of apps and games that take advantage of 64bit CPUs has always been limited but they are growing. This will only become more and more numerous.
The main architectural difference in the two was in how the two cpus communicated and the AMD was first to use a bus between the two cores and the Intel had to go to the onboard memory controller and back. That was in the first inception. Still, AMD has been far in advance of Intel and Intel has played catch up in tricks inside the cores and how the north and southbridge took advantage of the cores' architecture.
Needless to say, I'm an AMD power user and my gaming rig has an AMD dual core on an Asus/Nvidia board and an Nvidia PCIe 9800 GPU.
In the long run, all modern notebooks require you to own a pad cooler to use these in your lap or not, they all produce heat. So, just get a good one designed for your laptop so it snaps into place and will keep your rig nice and cool.
At a LAN Party you won't suffer from having a dual core AMD cpu, you'll hold your own and it will be an even playing field and the wins will go to the person with the fastest fingers... as it should be.
Sleep easy friend,
Worldvet
Oct 26, 2008 | HP Pavilion DV5234US Notebook Laptop
Compare which is better hpDV900 amd -HPDV2000 intel
IF THE CONFIGURATION STATED BY YOU IS CORRECT THEN I WOULD SURELY GO FOR DV2000 BEACUSE OF HIGHER MEMORY(3 GB) AND AN INTEL PROCESSOR BECAUSE THE AMD PROCESSOR OF DV 9000 WILL GET SO HEATED AFTER ABOUT AN HOURS USE THAT YOU WONT BE ABLE TO KEEP IT ON YOUR LAP ... HOWEVER I STILL DOUBT THE CONFIGURATION .. CAUSE ACCORDING TO ME THE CONFIG OF DV2000 IS INTEL CORE 2 DUO T5500 1.66GHZ 1GB RAM AND 100GB HDD WHICH IS NOT AT ALL PREFERABLE BY ME
Sep 11, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv6000z Notebook Logo
126 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
