Question about Aiptek ISDV2.4 Flash Media Camcorder
Every time i insert the memory card my camera freezes up and i have to take the batteries out in order to get it to cut off or function until i remove the card.
  • 34 Answers
Plug your camera, with card inserted, into your pc and run a scandisk to it.. Right click the drive and then properties, then scan disk. Select fix all and let it run. If that doent work, then try a new card. They are very inexpencive now adays.
Posted on Dec 21, 2008
DC shuts off when memory card is inserted
reformat the card. the card is corrupted.
Mar 23, 2014 | Cameras
Says Memory Full, yet there are no photos in it... there's nothing to delete.
Format the memory card - locate the format function in the menu. Usually in order for the card to function for the first time inserted in the camera, it need to establish a file system unique to the cameras'. The internal memory can be formated as well if you want it erased too.
Jan 16, 2011 | Polaroid i1437 Digital Camera
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
I have put fresh batteries in my Canon Power Shot S1 camera and it still will not come on? Can you help me?
Contact failures may have occurred between the camera and the batteries.
Confirming that the [Memory Card / Battery Cover] is securely closed
If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.
Close the [Memory Card / Battery Cover] securely, and then turn the power on.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.
If your camera uses four AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries.
1. Be sure that the camera power is off.
2. Slide the battery cover lock in the direction of the arrow, and push the battery cover slightly forward. Then open the cover.
batts_step1.gif 3. Insert the batteries as shown.
batts_step2.gif 4. Close the battery cover.
batts_step3.gif * For the PowerShot S2 IS, PowerShot S3 IS, and PowerShot S5 IS the batteries are inserted in a slightly different order, please refer to the decal inside the battery door for the correct order.
Installing batteries in cameras with 2 batteries. If your camera uses two AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries. Please see the various examples to find which type matches your camera.
Example 1:
  2. Slide the battery/memory card cover lock in the direction of the arrow (1.gif), and press down while opening the cover (2.gif).
  3. Insert the batteries as shown and close the battery / memory card cover.
Example 2:
  2. Slide the battery cover lock in the direction of the arrow, and open the cover.
* For the PowerShot A300 and PowerShot A310 the battery polarity is reversed.
Dec 05, 2010 | Canon Cameras
When I insert the sd memory card into my Mitsuba dc500t digital camera, it won't function until I remove the memory card. Any suggestions as to why this occurs and how to correct the problem so I can...
On MEMORY Card Problem, Make SURE its the SMALL Insert SD Card you are using & Not just a SD Card!
I Have same Camers & it should fix your Problem to use from 2 to 8 GB Memory.
Good Luck,
Apr 21, 2010 | Mitsuba DC500T Digital Camera
Kodak m1033 cameraturns on shows date and time have been reset camera buttons and controls do not function
Ii understand your problem description as the camera turns off immidietly after having shown the date and time.
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Nov 25, 2009 | Kodak EasyShare M1033 Digital Camera ...
No memory card, set time
The date/time battery is "built in" (not replaceable) to this model according to page 13 in the manual (available here). It is supposed to recharge when you have the regular battery installed, but if you leave the regular battery out for more than "approximately three weeks", the internal battery may go flat.
I'm not sure this has anything to do with the memory card issue, though. Check the battery problem by inserting a freshly charged battery, turning on the camera and setting the correct date and time, then turning off the camera and waiting an hour or so (with the main battery still in the camera). Turn the camera back on, and if the date and time have to be reset again, your internal battery may be bad, and the camera would need to be serviced.
Dec 09, 2008 | Canon PowerShot SD870 IS Digital Camera
Camera freezing
try a new memory card. also try to reformat the memory card. dont take images you care about until resolved.
i would try to remove the battery for about 10 seconds, and then reinstall, then reformat the memory card. if you still have the same issues, replace the memory card. it that does not cure it, you have a warranty repair to manage.
good luck
Dec 23, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Memory Card
Did you format the card in the camera?
Jan 11, 2007 | HP Photosmart R707 Digital Camera
When a camera is inoperable or fails to function, or an error code appears in the liquid crystal display (LCD)
Follow the steps below in the order presented: Perform a power reset on the camera. Performing a power reset on the digital camera will normally correct issues such as the camera locking up or not turning off. When the power reset is performed properly, the camera will prompt you to update the camera’s date and time. This is an indication that the memory has been cleared and no further reset time is required. The power reset procedure must only be performed on a camera that has been running on battery power. If an AC power adapter is being used, the power reset procedure does not apply. This is due to the fact that the internal capacitor is fully charged. To execute a camera power reset, perform the following steps: Turn off the Digital Camera. Remove the Compact Flash Card or Secure Digital Card, if one is being used. Turn on the Digital Camera. CAUTION: To avoid damaging the camera, ensure the shutter button is not pressed during the following steps. Turn on Live View on the rear LCD. CAUTION: Care should be used when performing Step 5 to ensure that the camera is not dropped. Open the battery door and remove the batteries with the camera turned on. Re-insert the batteries after five minutes have elapsed. Turn on the camera. The camera should request an update for date and time (with the exception of the HP Photosmart 120 and 912 series cameras). Format the memory card. Navigate to the delete menu which varies with each camera, and format the internal memory and/or the memory card. CAUTION: Reformatting the memory card erases all of the files that are stored in the card. All photos, scripts, and miscellaneous files are deleted permanently. To preserve the existing images, use a spare card or a card that is already formatted.
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Open Questions:
Aiptek ISDV2.4 Flash Media Camcorder Logo
Top Aiptek Video Cameras Experts
Level 1 Expert
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
