Question about Dryers
Clothes get caught between frame and drum
Clothes get caught between the front door frame and drum, then they twist from being caught and I have to throw them away because the tear.
Is this the dcvh515 GE? Mine began doing that and then started making a high pitched scraping noise that sounds like it's coming fron the door gasket/seal.
Posted on Dec 21, 2008
Clothes getting caught between drum abd frame - above door on right side. Also drum is squeaking.
these are the parts, Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Apr 17, 2011 | GE DCVH515EFWW Electric Dryer
Our cloths are snaging between the dryer door and the front wall on the handle side of the door (left side). There so stuck that they rip a hole in them when we free them.
Sounds like you front drum support / bearing is wearing out. When the support wears out, a gap occurs between the drum and drum support, That is where the clothes are getting caught, Does your dryer squeak when running? If so, then replace the front drum support / bearing. Cost about $35 - $40.
Jan 24, 2011 | GE DCVH515EFWW Electric Dryer
Articles of cothing get caught between the rotating drum and the frame--I'm sure these are not the correct structural terms. Too often, when I open the door, something will be caught and hanging, and I...
Your drum seal between the drum and the body of the dryer needs replacement, this is what causes the clothes to stick and tear holes in them.
I hope this helps
Please rate me
Aug 10, 2010 | Frigidaire Electric Dryer
My dryer eats my clothes by twisting them up between the drum and door. is there an update to fix this?
the front of the drum rides on a felt pad. as the pad wears down it creates a gap for the clothes to get caught in. you just need to replace this felt. sometimes called front bearing sometimes called felt seal.
Jun 26, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Clothes are getting caught in the felt around the
sounds like your front bearings are worn turn of power remove front panel and replace hope this helps
Nov 12, 2009 | Washing Machines
My Frigidaire dryer makes a banging noise
What you have here is a drum bearing issue. Read my award winning essay on this subject right ova HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 09, 2009 | Frigidaire GLER642A Electric Dryer
Frigidaire Dryer. Clothes are damaged by either being ripped when caught on dryer drum. Clothes also are marked with hard to remove rub marks.
Open the dryer door. Reach in just inside and feel for the felt seal that goes all of the way around the drum. The culprit is usually the top portion of the seal which supports the end of the drum near the door is worn out. This allows the drum to tip down and leaves a gap at the bottom. Clothes get caught in this gap and get rubbed and marked or rubbed clear through. Remove the front of the dryer and replace the seal. On some models the top 1/3 is replaceable. This portion carries the weight of the drum and is what wears out.
Jun 06, 2009 | Frigidaire FEQ1442ES Electric Dryer
Clothes get stuck between dryer and barrel
If your clothes get stuck, marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
May 31, 2009 | Electrolux Kenmore 5.8 cu. ft. Super...
Drum spins off center and clothes get stuck between drum and casing
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
May 28, 2009 | Kenmore Dryers
My dryer is destroying my clothes,
There is a gap between the lip of the drum, and the dryer housing. Usually the gap is not large enough for clothes to get caught up..
I think the drum should be removed, and the drum bearings checked for excessive wear. This can cause it. There are like 6 rubbing blocks at the front, that the lip of the dryer runs on. This is what I mean by bearings. There will also be a single drum bearing at the back of the drum, check this also for wear or damage.
Hope this helps.
May 06, 2009 | Frigidaire Electric Dryer
Dryers Logo
499 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
