Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Lost Password I lost my password. I have my user name but need to access the router so I can set up an online game. Is there any way I could get my password back or set the game up without a password?
  • Cornelia Derham Apr 06, 2007
    Thanks.
  • Anonymous Dec 07, 2008
    still cant get in
    Scholar:
  • 121 Answers
Press and hold the reset button on the back of the Router for 15 seconds. This will reset the unit back to its factory default settings.
Posted on Apr 06, 2007
  • Joshua Hori
    Joshua Hori Apr 06, 2007
    no problem!!
    Thanks for the rating! :D
How do i delete a bt broadband account,??
Here is how to reset your Linksys wireless router to the factory default settings in order to clear any existing properties.
  • Note: All your settings will be lost including WEP encryption information, MAC Address filtering information, and any SSID information you have entered. The router user name and password will revert to the default of admin as the user name and no password.
To reset your Linksys BEFW11S4 router to the factory default settings:
  1. Hold the reset button on the back panel of the Linksys router for 30 seconds. All your settings will be lost including WEP encryption information, MAC Address filtering information, and any SSID information you have entered. The router password will revert to the default of Admin and all user name information will be removed.
flioqsktle4l2on3s2rwrurpaery4ednch7fnrcft2qykek7dl9puwp12tebm2epxiv1cic0cgjbtccmwjiymzmxbli0zgzkwq5ytgrmzmeowlrkzmtdjf24rlu2laabtaaaaaelftksuqmcc
  1. When you access the router utility to change the router settings from the default values, be sure to leave the User name field blank and enter admin in the Password field.
Aug 18, 2014 | Linksys Wireless-G Broadband Router
WHEN I HHOK UP MY ROUTER I LOSE CONNECTIVITY TO MY DEKTOP. ALL WIRES SRE CONNECTED PROPERLY
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Jan 12, 2011 | NetGear WGT624 Wireless Router
I need to reset user name and password
There are 2 way to reset username and password
1. Access router by typing the router address in internet browser and look for the option for resetting user/ password
2. you may reset router to factory setting from the reset button on the back side of the router. use a paper pin to press the button for few seconds, the lights on the from would blink and the router would restart with factory setting. Please not that ALL SETTING WOULD BE LOST...
HOPE IT HELPS...
Nov 02, 2010 | D-Link DIR-615 Wireless Router
I have a belkin 802.11g router but have lost the manual, I need the gateway starting http; to enter in to the internet so I can access it
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
Or
http://192.168.0.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
If you are still not able to see use name and password screen then RESET it Press RESET button for 10 seconds it is in back side of router Then try with above ip.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 22, 2010 | Belkin (F5D7230-4) Router (587009)
I lost my wpa key? Can I find this somewhere?
For belkin router http://192.168.15.1
or
http://192.168.2.1
Click on wireless settings then WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
If your password showing in * or # format then add new password with above method.
Mar 18, 2010 | Belkin (F5D8231-4) Wireless Router...
How to access my router settings or info
please read here. The default user name is always admin and the password is either admin or blank. if you have lost you password then you can press the reset button to restore the factory settings. Note that this will remove all configuration you have made to the router.
Feb 27, 2010 | Linksys WRT160N Wireless Router
I lost my wireless router setup cd and cannot make it work! Please help!
You can set your router settings without disk too.
You need to configure your router.
http://192.168.0.1
or
http://192.168.1.1
If you need user name and password for connect to your service prtovider then configurayour router as PPPOe .
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Feb 08, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
Cant get router settings due to lost user name and password need to open ports
There should be a recessed button on the back of the router that you need a paper clip or something similar to access. Press that button down for about 20 seconds and it will reset the router to default settings. Then use the default login/pw to reconfigure it. There is no way to recover a lost password from a router. If you know the exact model of the router, you can download the user manual from dlink's website.
Oct 13, 2009 | Computers & Internet
Default user name/password.
Try username as admin and password 1234
Jan 22, 2007 | Hawking HWBA11 802.11b
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
239 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
