Question about Canon imageRUNNER 2200
How to set output of scanned docs to default to PDF format using Canon irc3380
  • 92 Answers
Hello, go additional function,next programming communications,next common TR, next send out file,choose file to pdf
Posted on Dec 22, 2008
How to set the default copy mode on a Canon irc3380 so that it starts up in black & white copy mode rather than color?
First adjust main screen as you want if to be (ie black and white mode). Once you have your default selected go to additional functions. Go to the copy selection and with in that list there is the section to save default settings. Now when you restart machine B/W and all other setting will be default. Good Luck
Jun 16, 2011 | Canon imageRUNNER C3380i Color Copier
How do I set-up scanned output default to PDF format?
in the software settings, there is option to save as PDF as default
Jan 24, 2011 | HP Officejet 5610 All-In-One InkJet...
How do i get my Canon 5080C scanner to scan in a PDF format?
Assuming you are using CapturePerfect Scanning software, you need to select the output as PDF. If you want multiple pages in a PDF file, you need to select 'multipage' option.
S. Mohan
Nov 09, 2010 | Canon DR 5080C Path-Through Scanner
Don't know how to use OCR scan function.
Greetings,
i beleive we have the complete setting detail with us.
1. Press the [Send] tab.
2. Press [Address Book] ([File] or [E-mail] also acceptable).
3. Choose an e-mail address. Press [OK].
4. Press [File Format]. Set to [PDF OCR]. Scan Settings
default to 300 x 300 dpi.
5. Choose [Send Settings]. Add [Name] and [Subject]
to the e-mail.
6. Or choose [Doc. Name OCR] to automatically name
document using initial characters of document text.
7. Press [Done].
8. Place the document on the platen glass or in the ADF.
9. Press [Start] to send document.
Regards,
TechSup1
May 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Change default output from jpeg to pdf
You can't without very expensive Optical Caractor Reader software to convert it. All that scanners do is print thousands of dots that they see from a document into a picture in JPEG format. All they see is dots, not text.
Apr 15, 2009 | Canon PIXMA MP780 All-In-One InkJet...
How to scan a document using Canon MX310 to Microsoft Word
you can try it by using the scanner option on the control panel. If you are using windows operating system, go on start menu, select control panel and double click scanners & cameras. Double click the scanner online and start scanning the documents. Save it in the format you want but it is usually default as jpeg.
scanned documents usually saved as .pdf file if you run the scan option directly on the printer. By pressing the SCAN button the printer. So do not use this option if you do not want the documents to be saved as pdf files.
Mar 30, 2009 | Canon MX310 Office All-In-One Printer
Setting PDF as default scan setting on Canon Imagerunner 3035
Additional Functions (hardware button on the panel)
Communication Settings
TX Settings
Scroll down to 2nd page
Edit Standard Send Settings
File Format: PDF
Scanning Mode: Black 300dpi
Mar 06, 2009 | Xerox CopyCentre C123 Copier
Samsumg SCX 4521F does it pdf?
If you are using the SmartThru software, the otpion to change the scanned format is in the same screen where you state the name of the document and settings for color, resolution, and others.
Be blessed.
Sep 17, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Grayblue Background on scans
A color scan will give real output as it is. If the background is grey, the output will also be grey. If you select 256 Color output, there may be small change in color, as compared to the original. If you select grey output, all colors will be converted to Grey. If these files are converted to PDF, it will be same, except in ODF format.
If you select B&W you can save the file in TIFF format. Unlike grey or color, each pixel can be either black or white only. To scan in black and white you must select right brightness. By doing os you can eliminate background (technically noise) and capture foreground(data)
S. Mohan
Oct 19, 2007 | Canon DR-1210C Scanner
Canon imageRUNNER 2200 Logo
645 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
