Question about Jensen KDC-9520 CD / Cassette Player
Can I plug in a electric antenna? - Jensen KDC-9520 CD / Cassette Player
  • 944 Answers
If you check the wiring at the back of the unit, there will be a blue wire coming out of the stereo that is probably not connected to anything, and often will have a plastic insulator stuck on the end. It may even have a label on it saying "antenna" or similar. This lead will put out a signal for a motorised antenna. To connect it, you would need to connect the blue lead to a relay which would be able to switch on power from the battery to the antenna motor - many motorised antennas will have that relay built into the base - check the wiring instructions that come with whatever antenna you get. You can also just wire a motorised antenna to a separate switch, only needing to connect the signal coax cable to the stereo - just be careful that the antenna motor has a switch that shuts it off when it is fully in, or fully out - else you could burn out the motor. Hope this helps, please ask again if you need mre info :)
Posted on Apr 06, 2007
SOURCE:
Don't understand blue antenna wire what does it connect to I wish to plug in a external antenna as well
Blue antenna wire connects to an electric antenna which will activate when the radio is switched on
Aug 13, 2015 | Car Audio & Video
Eton e5 sw shot
The SW FET preamp transistor, Q1, on the underside of the circuit board blows if a static electric discharge hits the whip antenna. In my case, a cat rubbing against me & the radio on a very dry winter day did it in. The back & circuit board has to be removed to get at it. The micro transistor & the solder connection are very tiny, so hard to replace. The antenna jack should still work, because the preamp is only for the whip antenna's SW reception. An easier solution would be to just run a wire from the antenna jack to the whip antenna, but you would no longer have the whip's preamp benefits, or just use a longwire antenna connected to the jack for SW. Also beware plugging into the jack disables the AM ferrite antenna inside, so you might not want anything plugged into it for AM reception because the internal ferrite seems to perform better than any external antenna.
Jan 17, 2013 | Eton E5 Radio
Plugging in FM antenna makes unit turn off and flash PROTECT
You better be sure where you're plugging that antenna and that it isn't electrically 'hot'.
Jul 31, 2011 | Teac MC-D95 CD Shelf System
The powered antenna is making grinding noise and wont move the antenna down unless given assistance. Is there a way to fix the battery or disconnect it to just leave the antenna up? The antenna is located...
There should be three wires going to the motor. Power, ground, and a "turn on" wire. turn the radio on to get the antenna up. pull back the panel where the antenna is at. disconnect the wires from the motor. it should be a single plug. your done. if there is a concern about the wires touching metal, tape the plug with electrical tape. put the panel back.
please rate if this was helpful
May 12, 2011 | Car Audio & Video
Electric motor under hood started running continuously. Seems to be retracted antenna. Pulling relay IEC 1627522 under dash left side stops it. Radio doesn't receive. Radio hasn't been used for months. ...
under left side of front hood sounds like air pump for rear struts a leak in the suspention system & u may have a antenna issue also un plug antenna in trunk & listen for motor under hood if it thear disconect air pump under hood.
Feb 07, 2011 | 1985 Cadillac Seville
My antenna broke off when I went through a car wash, how do I replace it?
if part is still left where antenna was take a pair of pliers and turn counterclockwise(left) to remove old piece left. go to most auto parts stores and they should have an original equipment replacement antenna
Jan 14, 2011 | 2004 Mercury Sable
Power antenna does not work. does it run off a
Yes there is a fuse for the antenna. Check the fuse and if it is good you will have to get to the electrical plug for the antenna, and check for current and ground. If all check out the antenna went bad.
Oct 01, 2009 | 1992 Toyota Camry V6
I replaced a standard antenna with an electric antenna in a 199 Ford Contour. All the mounting brackets were there, but the wiring harness was not. I need to know how to wire the electric antenna (wire...
If it is a three wire electric antenna. The Ground wire is usually black. To find out which is the trigger wire simply connect the black wire to ground and then power one of the other wires, if you here the clicking of the relay you know this one is the trigger wire and the other wire is the power wire.
Sep 04, 2009 | Car Audio & Video
How to replace thunderbird antenna
please rate service.
Automatic Electric Antenna
Removal
  1. Lower electric antenna (18850) .
  1. Remove rear retaining screws of RH front wheel splash shield for access to antenna lower retaining bolt.
  1. Remove lower retaining bolt.
  1. Remove radio antenna nut (18865) from top of motor tube and remove electric antenna through fender/splash shield access.
  1. Disconnect signal cable and motor wire connector(s).
Installation
  1. To install, reverse Removal procedure.
  1. Tighten top radio antenna nut to 6-8 Nm (54-70 lb-in).
  1. Tighten lower electric antenna retaining bolt to 5.8-7.8 Nm (51-69 lb-in).
  1. Check operation of electric antenna and radio chassis .
mast
Mast, Power NOTE: A power antenna mast which is bent or broken can be replaced without replacing the motor and tube assembly.
Removal
  1. Remove radio antenna nut (18865) and radio antenna stanchion (18919) .
  1. Loosen retaining nut inside tube using 14 mm (9/16 inch) socket, and slide nut part-way up mast.
  1. Raise antenna to run plastic drive wire at bottom of mast out of motor. Note direction of teeth on plastic drive wire.
  1. Saw off damaged portion of antenna mast. Remove burrs from mast and slide nut and contact tube off stationary tube.
Installation
  1. With the teeth on the plastic drive wire facing toward motor on antenna, push end of plastic drive wire of replacement mast assembly down into tube. Push it around curve at bottom of tube until end enters drive mechanism.
  1. Run motor down while pushing on plastic drive wire until about 305 mm (12 inch) of wire has been drawn into the tube. Stop motor and insert bottom of antenna mast into tube. Lower mast.
  1. Slide contact tube and radio antenna nut down antenna mast. Tighten nut to 0.45 Nm (4 lb-in).
  2. Raise and lower antenna several times to ensure proper operation.
Jul 09, 2009 | 1995 Ford Thunderbird
1999 Mazda 626 antenna won't go down, hums.
Spray the antenna with a spray lubricant (WD40) or similar. and let it sit for an hour.
Then start the car and see what happens.
The antenna is probably full of filth or corrosion..
If that doesn't work take the side cover off the trunk on the side where the antenna is and you will find a plug in electrical connector near the motor that winds the antenna up and down, pull that plug out and the antenna will stop trying to wind itself down..
May 09, 2009 | 1999 Mazda 626
Jensen KDC-9520 CD / Cassette Player Logo
95 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
