LEAKING LG1814CW WASHER
LEAKING FROM UNDER THE TUB...ALOT...WHEN DRAINING...A CLOG SOMEWHERE
There is a removable basket at the bottom of your washer. This may be leaking if it is not tightened up.
Posted on Jun 13, 2010
Whirlpool code F02
The F02 error code on a Whirlpool washer indicates that the control detects a long drain time. This can be caused by excessive suds in the tub, a restriction or clog in the drain system or by a number of other component failures.
If the Whirlpool washer did not drain, check for excessive suds in the tub. After the suds dissipate, you can normally run a rinse/drain and spin cycle. Causes for excessive suds include not using HE (High Efficiency) detergent or using too much detergent (even if it is HE type).
If the washer will not drain and you do not detect excessive suds, you could have a clog in the drain system. Check the drain hose and the washer drain. You may need to manually unlock the washer door and then pull the large item filter on the pump to check for a clog. To manually unlock the washer door, Always saftey
unplug the washer ,to disconnect electrical power and remove the bottom front service panel as shown in the top of the image below. Carefully reach up along the inside of the front panel and pull down on the tab that is under the door lock mechanism until it clicks. This will unlock the washer door. Open the door and manually drain the water out of the washer with a wet/dry shop vacuum. Once the washer is drained, arrange some towels to catch residual water that will drain out and remove the large item filter as shown in the image below. Check for a clog or restriction that could be preventing the washer from draining properly.
If you find no clog or restriction in the drain system, you may have a bad drain pump that needs to be replaced. A problem with the electronic control board could also prevent the washer from draining.
If the washer is draining properly but you are getting this code, you likely have a problem with the water level pressure switch or the control board.
Aug 15, 2016 | Whirlpool Washing Machines
I attched the photo below. Please tell me what's the problem with the washing machine BalayTw860
fault code indicates a problem with the washer's drain system, and you must troubleshoot the problem to determine how to fix the washer and clear the code.
F/02 error code potential causes
Check the drain hose and make sure it is not plugged or kinked
Check the electrical connections at the pump and make sure the pump is running.
Check the drain pump filter for foreign objects
If the above does not correct the problem replace the pump
The F02 error code on a washer indicates that the control detects a long drain time. This can be caused by excessive suds in the tub, a restriction or clog in the drain system or by a number of other component failures.
If the washer did not drain, check for excessive suds in the tub. After the suds dissipate, you can normally run a rinse/drain and spin cycle. Causes for excessive suds include not using HE (High Efficiency) detergent or using too much detergent (even if it is HE type).
unplug the washer
If you need more help, resubmit your question with additional details and the full model number of your HE3 washer.
May 18, 2015 | Washing Machines
Why is water leaking back into tub
the issue is ur water inlet valve has no filter nd has trap some filtrate,,,it neesd to loose the four srews , clean replace nd eventually replace the filter which uve misplaced
Jul 09, 2014 | LG WM-2277HW Front Load Washer
Why is my Kenmore Elite HE 2 flashing F 02?
The F02 error code on a Kenmore HE3 washer indicates that the control detects a long drain time. This can be caused by excessive suds in the tub, a restriction or clog in the drain system or by a number of other component failures. If the washer did not drain, check for excessive suds in the tub. After the suds dissipate, you can normally run a rinse/drain and spin cycle. Causes for excessive suds include not using HE (High Efficiency) detergent or using too much detergent (even if it is HE type). If the washer will not drain and you do not detect excessive suds, you could have a clog in the drain system. Check the drain hose and the washer drain. You may need to manually unlock the washer door and then pull the large item filter on the pump to check for a clog. To manually unlock the washer door, unplug the washer to disconnect electrical power and remove the bottom front service panel as shown in the top of the image below. Carefully reach up along the inside of the front panel and pull down on the tab that is under the door lock mechanism until it clicks. This will unlock the washer door. Open the door and manually drain the water out of the washer with a wet/dry shop vacuum. Once the washer is drained, arrange some towels to catch residual water that will drain out and remove the large item filter. Check for a clog or restriction that could be preventing the washer from draining properly. If you find no clog or restriction in the drain system, you may have a bad drain pump that needs to be replaced. A problem with the electronic control board could also prevent the washer from draining. If the washer is draining properly but you are getting this code, you likely have a problem with the water level pressure switch or the control board.
Jul 04, 2014 | Kenmore Elite 45986 Front Load Washer
F21 is flashing
This means the water is not draining out like it should. I solved this problem initially on my washer (my drain pipe was clogged), but now (about 4 months later), I have a flashing F21 and 5d, because of a clog some- where. I can drain and rinse (after this cycle, the door will unlock), and the tub spins, but I can't complete a cycle. Lots of debris has come out with rinse water, but I still seem to have a clog somewhere. I can complete a wash load by manually switching the settings.
Dec 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
I have an lg1814cw front load washer...it is leaking from the tub when trying to drain..I have cleaned the filer on the front, but it leaks under the tub.
im not going to tackle this yet,,because i need a little help...unplug unit get a flash lite,,and take back cover off,,..and you should see where is leaking from ,,than we will take it from there...
Dec 21, 2008 | LG WM1814CW Front Load Washer
Front Loading Washer won't drain
The problem is most likely change in the drain pump and sump area (rubber boot going from tub to pump). It is axcessed by removing the lower front panel. Disconnecting and reconnecting the hoses to the pump are real tricky!!!!!!!!!
Jan 16, 2008 | Washing Machines
Washer machine
you have a clog in your drain system and when you have a large volume of water it will back up into your tub and possibly your toilet. the only fix would be clearing out your clog.
Dec 03, 2007 | Estate TAWS800JQ Top Load Washer
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
