Question about Apple iPod nano
Now the sleep option isn't even there...
Hi again. I'm the same person who posted the "won't sleep" problem. Anyways, it still wasn't working, so I restored it and now the sleep option isn't even on the screen! Everything else is there, but the sleep option just vanished! Please help!!
  • 33 Answers
You got your sleep off go to the main menue and go to sttings and there will be a sleep option it will say on or off you want to click it on ~Grim ~Zach
Posted on Apr 30, 2007
SOURCE:
No sleep mode on acer monitor
This is annoying, but try to go back on factory default setup.
Apr 15, 2014 | Acer Computers & Internet
Cordless Mediaboard Pro - how to turn auto-sleep mode off?
I can see you've posted on the Logitech website and I think that will be your best bet. I work in a shop that sells these and I've got one in front of me but I don't have any idea how to change the sleep settings, or if it's even possible :\
I bet there's some really complex coding you may have to input, even then it's not guaranteed to work
Feb 28, 2014 | Computers & Internet
My HP w2007 has started clicking to Monitor Going to Sleep and then going blank. I have never known how to wake it up so I have to turn the whole computer off and restart. HELP
Hey there, Normally simply pressing a random key on your keyboard or moving your mouse should wake it up, if it doesn't though I think the easiest way to solve this is to simply turn off the sleep mode after x amount of time.
If you have windows 7, press the start button and type in "power options", go ahead and open power options and there you will be able to set the time it takes before your PC shuts down, and you can also set it to never.
If you still wish to use this feature but just want to be able to it's a bit tricky and it won't even work for all PCs but if the keyboard waking isn't working, then it's probably because your pc does have this feature. When your PC is off, boot it up again and enter the bios by pressing F10 i believe it is for HP. And somewhere you should be able to set which devices are allowed to wake up your computer, all devices are probably disabled now, so go ahead and enable the keyboard to wake up your computer. Now save and exit, and the next time your PC goes to sleep mode you should be able to wake it up by pressing a key on your keyboard.
I hope I was able to assist. If I was, please don't forget to rate this solution.
Jul 28, 2011 | HP Pavilion F1523 15" LCD Monitor
I have a new EOS T3i. It's my first digital camera. I took out the battery to preserve it. When I reloaded it, the camera wouldn't let me take any pictures. The message said the card wasn't...
That sounds like an issue with the memory card. Yes you will lose all current photos on it when you format the memory card. It's also safe to leave the battery in the camera as DSLRs don't drain power when the camera isn't in use.
Jul 23, 2011 | Canon Cameras
Everytime I lock my computer,shut the lid or leave it untill it goes black, it will not come back on when I touch the mouse pad. However when I got this laptop it worked and when I opened the lid and...
Well by default Closing the Lid will cause computer to go to Sleep mode and you can't wake it up using mouse. However you need to press power button to wake it up.
But as you said it was working the way you explained then seems like Power settings on your computer are changed
To check the settings Got0 -Control panel and click on power Options Goto - Advanced and find the Lid open/close actions You can change it there If you don't want your computer to goto sleep mode with the lid close, you can simply disable it.
Hope this worrks
Jul 14, 2011 | Computers & Internet
Okay, so I'm not even close to being savvy with computers. Anyways, my netbook keeps on restarting and won't let me go on to the desktop. Safe mode, safe mode with networking, and all those other...
Do a Windows repair by following below steps:
1- Boot up form the CD
2- Windows installer will start loading some files to your hard drive, when it finishes go for "To set up Windows XP now, press ENTER" so press ENTER
3- Press F8 to accept the License Agreement
4- Now Windows installer will search for installed Windows OSes on your hard drive and should find yours and lists it at the bottom, highlight it, then press R
Wait for the repair process to finish. I hope this solves your problem.
May 11, 2011 | Microsoft Windows XP Professional With...
Toshiba satellite laptop won't wake up from hibernation even after holding power botton down?!
If pressing down and holding the restart/start button doesn't wake it up you might try Control + ALT + DELETE keys (together) - that will reboot it though. And if that won't work then you might have to pull the battery to reset it.
It seems that some laptops have a problem with vista and sleep mode, in particular, and sometimes hibernate too. You can try going under POWER OPTIONS under Control Panel and setting everything back to default, saving it, then resetting it again. Also it's best to avoid using sleep mode if possible to avoid problems.
If the problem developed after a recent install or updating you may need to go to an older store point to fix the problem. Personally, I just avoid using these settings as much as possible and use regular shut down and a screen saver for times when I need to step away from laptop for short periods of time.
Apr 27, 2011 | Toshiba Satellite Pro L300 Notebook
Power on
I am very sorry - I posted an answer to the wrong person - I wondered why my post never showed up!
For YOUR problem, I want you to try removing the battery and the power. Then just plug in the power without the battery in.
It should come up as normal, and then shut it down. Replace the battery. Then restart.
That should help your situation.
Jul 03, 2008 | Acer Aspire 5100 Notebook
Apple iPod nano Logo
305 people viewed this question
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Dapid Candra
Dapid Candra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
