Question about Sony KP-61HS30 TV
TV has panaramic view/ 3D view.
Came home and turned TV on and the edges are fine but the center seems to be smaller. It is not in view, it has a 3D view before you put the 3D glasses on. It also is double vision like this.
  • 2 more comments
  • Ken Mangione Dec 21, 2008
    The exact model number on the back of TV is KP-61HS30. Serial number is 9738226.
    can you tell me where i can find where to buy the part numbers that you supplied?
  • skyseeker Jan 16, 2009
    hi there i am having problems ...... is there a pic of these repair !!! any help on it !!!!
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Let me know the exact model number of TV, written on label pasted on rear of TV.
  • 10,594 Answers
Symptoms shows its problem of failure of convergence out ICs on D board.
Find IC8001 and IC8002 on D board and replace them as per following part number...
8-749-019-08 STK392-560
You also need to check following pico fuse PS8001 to PS8006 (6 fuses) as few can be blown off and requires replacement.
You should do above said repair if you have knowledge of electronics, have experience of big TV repair, have necessary tools and know that electric shock risk is involve in TV repair.
Let me know if you need further help.
Good luck.
Posted on Dec 21, 2008
Does my Sony kdl55w829b 55 inch HD 3D Smart tv have a built in 3D transmitter to use with the active 3D glasses ? If so how do you activate 3D viewing ?
This TV has the active 3D transmitter built in to it in some regions. It is included for the model sold in the U.K.
You need to register the Active 3D glasses before they will work with the TV. To register the glasses, turn on the TV and bring the glasses within .5m of the TV. Then press and hold the power button on the glasses for 2+ seconds (until the power button blinks alternating green and yellow). When the registration is successful, a message will show on the bottom of the TV and the green light will stay on for 3 seconds. This will need to be repeated if you use the Active 3D glasses with another TV and then use them again with this TV.
Now you need to activate the 3D feature on the TV. Press the 3D button on the remote or press the control bar on the Touchpad remote and slide the touch pad to the 3D icon and select it. Then choose your 3D option. You may also need to adjust the 3D display settings from the Home button. Press Home and select Settings. Then choose Display and then 3D.
The manual for the KDL-55W829B is available here: http://www.sony.co.uk/support/en/product/KDL-55W829B . The Help Guide, http://download.sony-europe.com/pub/manuals/tvhc/14HE468112-EN-Print.pdf , has the information on using the 3D feature starting on page 56.
I hope this helps.
Dec 19, 2014 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
How do I connect Sony S590 3D Blu Ray to Analog TV & Sony DAV-DX255 Home Entertainment Center
It depends what connections the TV has. If it has HDMI sockets then you should be able to connect the player via one of them. The sound should be connected using an optical lead from the player to the Sony Center.
However you will not be ever be able to play a 3D movie till you have a 3D TV. It will simply not work.
So at the moment you have purchased a an expensive 3D player which can only play back normal Blu-Ray's and DVD.
Feb 04, 2018 | Sony BDP-S590 3D Blu-ray Disc Player with...
What kind of TV supports 3D?
You need to look for TV's labeled 3D ready feature a screen capable of displaying 3D content, and have the necessary emitter built-in. One important thing to keep in mind is that you'll need more than just a 3D TV to watch 3D at home - you'll also need pairs of 3D Glasses for anyone watching, as well as a 3D video source, like a 3D Blu-ray movie.
Jul 29, 2012 | Furniture
I just purchased a Philips HTS5580w/F7 home theatre. It is stated as being 3D ready but requires a software update. I cannot find the update for this model on Philips website
There is no software update as it is already able to play BluRay 3D as detailed in the Manual.
Before you start, make sure that:
• your TV is a 3D TV, and is connected
to your home theater through HDMI,
• your disc is a Blu-ray 3D disc, and
• you have 3D glasses that are
compatible with your 3D TV.
or the 'Fault' could be that the 3D is turned off
From Page 18 of the Manual
Play 3D discs in 2D
1 Press ( Home ).
2 Select [Setup] > [Video] > [Blu-ray 3D
video] > [Off] .
3 Press OK .
4 Play your Blu-ray 3D disc.
» The 3D video is displayed in 2D.
If it is selected as Off then obviously turn in On.
Please leave feedback
Cheers
Andy
Apr 26, 2011 | Philips HTS5580W/F7 Theater System
Vizio VX32L image distorts on edges like looking in a metal bowl.
I had a similar issue. Realized that the TV's "WIDE" setting was changed from "Wide" to "Panaramic". It was this panaramic setting that was causing the distortion on both sides of the screen. I had to switch it back to "Wide" using the "Wide" button on the remote to toggle back to "Wide" setting. Once I put it back to "Wide", problem went away. Hope this helps.
Jan 12, 2009 | Vizio L32 32 in. LCD HDTV
I just replied your question. You can see it by clicking HERE.
Dec 21, 2008 | Sony KP-61HS10 61" Rear Projection...
Hitachi 57SWX20B 3D Effect due to green light convergence problem
I'm trying to fix the issue on my 43FDX20B. So far, I'm able to move the lines up and down, but can't get the left/right motion to fix it. The attached link has the dynamic mode instructions, so you can correct this issue yourself.
http://home.comcast.net/~leebailey00/Hitachi_DCAM_Manual.pdf
The only thing I didn't have was the screen overlay jig the manual talks about. I decided to create one myself and use the screen as a beginning template. I went to our local hardware store and picked up some home window weather covering. The roll cost about $15, is a clear strong plastic and the template was very easy to create. I used a straight edge after I put dots on the plastic and measured the lines for being square and equal after I took it off my tv. Good thing is that if you don't like what you make the first time, you have a 25' roll to use to try again (ha).
Mar 01, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Punch! 3d custom workshop - windows vista
Here´s the patch:
http://punch-alternatives.com/base/index.php?option=com_content&task=view&id=140&Itemid=143
Dec 12, 2007 | Punch ! Home Design Architectural Series...
Sony KP-61HS30 TV Logo
273 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
