Question about Plumbing
Plow goes down too fast and hard
E-60 unit can I adjust this?
  • 15,935 Answers
On the front of the pump where there are two 11/16 hex plugs... one has a filter behind it, and the other (closest one to the valve block) is where the drop speed screw is located..
Be sure to do this adjustment with the blade on the ground!....
Remove the plug and use a 3/16 allen wrench to reach in and turn the drop speed screw. Turn it counter clockwise to increase the drop speed. They're fairly sensitive so only turn it about an 1/8 at a time...
Make sure you reinstall the plug before you recheck the drop speed or the back of your blade will get a bath of plow oil..
Posted on Dec 22, 2008
I have a unimount western snowplow.it raises and lowers right.it swings side to side right.but when it is on the groundi cann'tpush the cylinder down to shorten the chain.
Lift the unit full up. Place blocks under the plow blade and let it down on said blocks. You can now do what you wish with the chain adjustment.
Oct 09, 2017 | Cars & Trucks
My fisher minuteman 2 plow will go up and left and right but will not go down
Most of those systems don't have a driven retraction on the piston. It is gravity feed back. There is a valve that is sticking or out of adjustment. http://library.fisherplows.com/?cat=38
Jan 24, 2015 | Cars & Trucks
I have a fisher minuteman plow it will go up, left and right but will not go down what is wrong with my plow
If you have a Minit Mount two it's probably the valve sticking. It's electronically controlled so if it clicks, then the solenoid is working and the shuttle in the valve is stuck. Can be disassembled and cleaned. New ones are best but pricey.
Fisher minute mount plow
does the pressure release close to raise the plow?
Jan 05, 2014 | Dodge Cars & Trucks
Service traction control comes on and off
The service traction control uses the same abs sensors to determine wheel speed rotation relevant to the other wheels then it adjusts braking to maintain even wheel rotation. The problem is that while you are plowing one or more of your tires are spinning faster than the others and when the computer sends the command to adjust for the slippage, it is not seeing any response. I don't believe that there is a problem with your traction control but it would not hurt to have it checked. My suspicion is loss of traction due to icy roads.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 10, 2013 | GMC 2012 Sierra 2500HD CREW CAB 4X4
Headlights are too low. When plow is up, can't see.Do they make risers?
The weight of the plow in the up position pulls down the front of the vehicle making the headlights too low. Level Ride air shocks are likely the only solution to this problem as any headlight adjustment will put the beams too high with the plow in the down position.
Dec 02, 2013 | Vehicle Parts & Accessories
Have plow on farmall super A . Plow wont dig in it just slides on top of ground
the angle of the 'mould board' or cutting edge of the plow,and the 'down pressure' or weight applied determine the 'cut'.adjust top of plow towards direction of travel to increase cut.dry,compacted soil can be very resistant.
Oct 02, 2009 | Farmall Toys
Plumbing Logo
147 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
