Question about LG WM1814CW Front Load Washer
I have an lg1814cw front load washer...it is leaking from the tub when trying to drain..I have cleaned the filer on the front, but it leaks under the tub.
  • cherienjohn Jan 02, 2009
    I am not sure during which cycle the leaking is occuring, but the front filter is clean and the leak is coming from the bottom in the back.
  • 640 Answers
Im not going to tackle this yet,,because i need a little help...unplug unit get a flash lite,,and take back cover off,,..and you should see where is leaking from ,,than we will take it from there...
Posted on Jan 03, 2009
MY front load washer is leaking from under the washer. I have tried doing the monthly cleaning as it states in manual but this has done nothing.
There are several possibilities--the rubber seal between the cabinet doorway and the outer drum may be pulling loose or is punctured in some way. If the cabinet has a removable lower panel on the front, take it off and inspect the pump, the water hose from the drum to the pump, and the drain hose that runs from the pump out the back to the house drain for any possible leaks. If the leak occurs when the tub is filling with water, the hose that runs from the water inlet solenoids to the tub may be split or pulling loose. Open the cabinet top to check this. Hope this helps!
Jan 06, 2011 | GE Washing Machines
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Leaking tub in front
If this is a Whirpool toploader and it is leaking from the front, this is commonly caused by a damaged drain pump. These pumps are sealed units and are not serviceable. So, if it IS leaking, the pump must be replaced. The following link explains how:
http://www.fixya.com/support/r397094-replacing_water_pump
Of course, the real determination will be exposing the internal components of the washer to get a better view. The link provided has all the steps required for removing the washer casing to expose the internal components. This will give you a better idea in determing where exactly the source of the leak may be coming from.
Run a small amount of water in the tub before you unplug the lid switch connector. The washer will not run with the lid switch disconnected, so you will need some water in the tub to see where your leak may be.
The drain pump is located in the front of the washer directly below the wash tub. Check the drain hose connections and the pump housing. As stated before, if the pump is leaking it must be replaced. Replacements can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Check the wash tub for any cracks as well, followed by a check under the center potion of the tub. If the leak is along the wash tub any where, the tub may have to replaced. If the leak is coming from UNDER the tub, you may have a leaky tub seal. These repairs are not difficult, but are labor intensive. We'll cross that bridge if needed.
Read through the link and let me know if you have any questions. I hope this helps you.
Aug 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaking wash machine
Depending on where exactly the leak is coming from, it could be a drain hose, drain pump, or tub seal. If this is a top-loader, here's how you can tell:
1. If the leak is coming from the BACK area under the washer, this can be caused by a leaking fill hose, dispenser hose, drain hose, or fill valve.
2. If the leak is coming from UNDER the center area of the washer, this could be your tub seal, a crack in the tub, or an air dome hose leak. NOTE: If the air dome hose is leaking, the washer will fill continuously and not turn off.
3. If the leak appears to be coming from the FRONT under the washer, this could be your drain pump, or drain hoses.
Posting a model number, could assist with determining how your washer is configured. I suspect you may have a drain pump leaking as this is the most common cause, but I want to be sure.
Apr 27, 2009 | Washing Machines
Water leaking from under washer
Hi
You'll need to open the machine and check for the leaks in the hose connected to the drain pump. Also check if the clamp connecting the drain filter and hose is tight. Also check these things for leaks---
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you'll need to replace it.
Please do rate this solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LEAKING LG1814CW WASHER
There is a removable basket at the bottom of your washer. This may be leaking if it is not tightened up.
Dec 21, 2008 | Washing Machines
Water leak
Remove the lower panel under the washer door and inspect the interior. The panel is removed by loosening and removing the screws under the bottom front edge. With the screws removed the panel will drop down, then off. Inspect the following areas:
- Check all hoses for leaks, cracks, holes and loose connections. Check the seal where the drain hose from the bottom of the wash tub connects to the intake of the drain pump. Make sure the drain hose from the pump to the standpipe is connected snug to the pump and is not leaking.
- Check the drain pump to ensure it is not leaking. The clean out reservoir cap (if not fitted properly) can leak around the seal.
- Check the door bellow (gray rubber boot) to ensure it is not leaking. HINT: A tale-tell sign of bellow leakage is wetness showing up on the front washer counterweight. This is a concrete block mounted to the front of the wash tub. It is not supposed to be wet.
- Check the pressure switch air hose to ensure it is connected to the air dome on the side of the wash tub. This is a small rubber hose that runs from the pressure switch in the top left rear of the washer (viewed from the back, with the washer top panel removed) to the bottom right hand side of the wash tub. However, if this hose were to come off the air dome fitting, the wash tub would continously try to fill and water would begin to pour from the bottom of the wash tub. If this does not sound like your symptoms, disregard this step.
- Check the seam where the wash tub shells meet. There is a rubber tub gasket that seals the two tub halves together. If the seal is bad, water will begin to collect and drip along this seam.
- Check the tub for cracks. This is NOT common, but it can happen.
The following link explains the step-by-step process of checking and cleaning the drain pump:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I mention this link, because it gives you some guidance on how to access the pump and how avoid the possible mess involved with water pouring out of the pump.
If you discover the door bellow as the the cause for your leak, please refer to this link:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
I hope this leads you in the right direction and helps you resolve your problem. Please post back if you have any further questions.
Aug 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leak
It sounds like you have a leak somewhere around the door bellow. This is the rubber boot that seals the wash tub to the door frame. Pull the folds back and inspect around the entire perimeter of the rubber. You could have a small rip or tear somewhere. There are a series of small holes in the bottom of the bellow that are supposed to be there. This is the allow any standing water to drain back into the wash tub. If you cannot find any obvious signs of leaks, remove the lower panel under the door. This is accomplished by removing the screws under the bottom edge of the panel. With the screws removed, the panel will drop down, then off. Start the washer on a normal wash and watch for any leaks. If the door bellow leaks, the front counterweight (usually a concrete block) will begin to get wet and drip. This could also be an indication of the bellow clamp around the wash tub being loose. If the leak starts to pool under the washer and run out the front, this is usually an indication of a drain pump leak or drain line leak. Please inspect the washer with the panel removed and the washer on a load and post back and let me know. Go to my profile and use the "Ask Me" feature for a quicker response. I hope this helps you.
PS One other item. On the left hand side of the door bellow is the a dispenser tube that penetrates through the bellow and allows water to enter the wash tub. Sometimes the dispenser tube is not seated all the way into the rubber (should be seated past the flange) and it will dispense water behind the rubber instead of into the wash tub. Just something else to consider...
Jun 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaking
There are several things that will leak under a GE washer. The the usual suspects are drain hose connections, or hoses that have cracks or holes. I would inspect the hoses first as this would be the easiest fix. The other thing that can causes problems is the wash tub seal on the bottom of the tub. If the spanner nut (under the agitator) comes loose, the seal will unseat and the tub will begin to drip (I've had this one happen to me). Another cause can be the wash tub itself (I've also experienced this one). Inspect the wash tub for cracks. The tub can develop stress cracks and begin to leak. Especially if this is a washer that was involved in a move. To access the inside of the machine, the front should come off by pushing under the front lip of the machine with a putty knife. There are metal clips that hold the front to the top. Look in the crack with a flashlight to locate them. Push in with a putty knife to release and the front should just come off. I hope this helps you.
Jul 05, 2007 | GE WBSE3120B Top Load Washer
LG WM1814CW Front Load Washer Logo
113 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
