Question about Nikon D50 Digital Camera
Nikon D50 I am trying to take pictures with my Nikon D50 and I turn it on and it is on auto and the button wont press and the shutter wont work - it is with both lenses - so I cant take a picture - not sure why - battery is full Is there a charge for this service? Thanks for your help!
  • 1 more comment
  • johannahlynn Nov 03, 2007
    I have the same problem! Camera was working great for about a
    year and now all of a sudden this happened, can't understand why!
    Sometimes it works fine for about 3-4 pics then locks up on me.
    any more suggestions?
  • jimjarmo Dec 12, 2007
    Same here - worked fine for about a year, then a couple of weeks ago went awry. Similarly, it sometimes lets me take a few pics, then freezes. Or sometimes it will take a pic after I hold the shutter release down for about 5-10 seconds (and, no, I've not got the timer on inadvertently). Local camera shop (London UK) says it will be mid-Jan before they can get it repaired and could cost £200 (around US$400). So, no camera for Xmas and - as another poster said - looks like I was sold a turkey!
  • Anonymous Mar 31, 2014
    how can I stop this
I have this problem too - Nikon have looked at the camera and said I set up a custom setting so that the focus only works when you press the AE/AF Button (!). I also had a problem with the flash not working - its looking like this is a known problem. I think I was sold a Turkey
Posted on May 16, 2007
\my D50 is not following through when I press the shutter release on auto focus-am able to take a pic on manual. When pressed, the camera makes a whirring noise but does not finish
Your lens might have an issue caused by some sort of shock or impact. Before anything just try to gently turn the focus ring on the lens while on auto focus to see if it pops back into place. Sometimes this actually takes care of the issue. Just DON'T FORCE IT. If this doesn't solve your issue then contact a Nikon authorized service center because your lens is going to need repairs. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 07, 2011 | Nikon D50 Digital Camera with 18-55mm and...
I get "Err" on the
The ERR message indicates a camera malfunction. In my D-90 manual it says that it can be cleared by releasing the shutter. The only way to do that is to turn the camera off and back on. Rarely, that won't work and you have to remove and reinstall the battery.
The manual also says that it this have frequently or persist to contact a Nikon authorized service center. I would contact Nikon tech support at www.Nikon.com and discuss the problem them before contacting an authorized service center.
Jan 25, 2011 | Nikon D50 Digital Camera
Nikon D50 While shooting pictures the shutter button stopped work
TURN ON CAMERA. SEE IF THERE IS A MESSAGE. NOW, TURN OFF CAMERA. TAKE OFF LENS. REPLACE LENS- MAKE SURE YOU HEAR A "CLICK" TURN ON CAMERA AND TRY AGAIN. OK?
Mar 03, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Can't reset nikon D50 default settings
Press MENU and select the pencil icon to get to the Custom Settings Menu.
First select the "Detailed" mode under Menu > Setup (wrench) Menu > CSM menu, otherwise you'll only to get the first few items!
[R] Menu Reset: This returns everything below to factory default.
Dec 24, 2008 | Nikon D50 Digital Camera
Help!
well there should be a button with 3 small lcd screens press that , and turn the back wheel until a small clock appears, than press the shutter and run to the place .. in front of the lens becarefull that if you use a 18-70 lens it iwll onlyo work good with a tripod. (otherwhise the lens is to haevy and you will be on the picture but without the face
Apr 14, 2008 | Nikon D50 Digital Camera
Nikon d40x shutter problem
May be a weak subject to focus or the flash is not ready when you press the button.
Set the camera to auto(green) mode.Try it with a contrast bright subject for as many time as possible.
If the problem persists turn off the camera and reset the camera using the button near usb connection.
Then go to seller for replacement.
Mar 17, 2008 | Nikon D40x Digital Camera
Nikon D50 Does Not Autofocus
replace the lithium battery 1.5X2 . then press then ok good, but does not work the drive motor was broken.
Nov 05, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Shutter
I had the same problem but replaced the lens with a different lens and it worked just fine.
Aug 27, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
D50 won't take a picture!
I was having the same problem.. And since I could not afford to take it to the shop, I tried everything I could think of...
Then I fixed it!!
It seems that the slide door behind the shutter was stuck for some reason... If you remove the lens.. (make sure the camera is in manual mode)... snap a shot so the shutter is up.. then gently slide the panel in the back down....
Once I did that.. the camera was working again.... Hope this easy solution works for you guys....
Feb 03, 2007 | Nikon D50 Digital Camera
Nikon D50 Digital Camera Logo
332 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
