How to solve problem SC 565 Gestetner MPC2500
SC565 error
  • 86 Answers
SOURCE: Gestetner 3218 Aficio 180 Fuctional Problem SC 543
Enter SP mode - Clear button (yellow key), 1 0 7 and hold and press stop button (orange key).
Enter SP5-810 (SC code reset) and select “1”.
Then hold down the “Photo mode” key and the enter key(hash) at the same time for at least 3 seconds (it is not necessary to turn the main switch off andon). If the machine beeps 5 times, the reset was successful. If it only beeps twice, the reset failed, and you need to repair the machine.
Possible causes are the fusing thermistor in the fuser unit, or the power supply unit defective.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
SOURCE: Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Posted on Feb 16, 2009
  • 86 Answers
SOURCE: Hie I have a Gestetner
Enter SP mode by pressing;
  • Clear (yellow) button
  • 1 0 7
  • Press and hold the Stop (orange) button for 3 seconds.
  • Switch off and on the machine.
If SC 552 (Fusing warm up error) appears again, possible causes are;
  1. Fusing thermistor defective or out of position or dirty with toner
  2. Fusing lamp open, and
  3. Power supply board defective.
Posted on Feb 03, 2009
SOURCE: Gestetner DSM645SP Error Code SC 322
After research it seems this problem is not easily fixed.
  • 1297 Answers
SOURCE: Error code SC 542 on my Gestetner Dsm622sp
Fusing unit problem.Verify the heater lamps,thermistor and thermofuse continuity.Enter in the SP mode turn OFF the main switch,unplugged the machine wait 10 sec.,plugged and turn ON the copier.
Posted on Sep 26, 2009
What is error code sc565?
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
Jun 25, 2016 | Ricoh Compatible 4 Color Set Aficio MP...
Error sc 565 mp c2030
Hi
The first thing I tend to do with any fault on a computer or related hardware, is to turn it off, unplug it from the power supply, turn off and unplug the rest of the system components. Wait for a few minutes, plug the equipment back in and turn all components on and then reboot the computer. After this I start to look elsewhere for fault diagnosis and repair.
In your case I found a list of codes for your machine here:
Error Codes Ricoh Aficio MPC2030
Here you can view the specific codes by using the drop down menu in the middle of the page. You can also change the make & model of machine by using the drop down menus near the top of the page. Also you can download a pdf format Service Manual for the machine by using the link just above the error table.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 31, 2014 | Ricoh Office Equipment & Supplies
Error sc 551
Replace both the thermistors and reset SC code
Sep 05, 2014 | Gestetner Office Equipment & Supplies
What is sc 565 on a sp c820
SC565
*Heat lamp consecutive on error
- Broken main fuser connection
- Check HR thermistors
- Heat roller lamp defective
- Power Supply defective
May 10, 2014 | Ricoh Aficio SP C820DN Laser Printer
Error code SC 565 Ricoh MP 2550
SC565
*Heat lamp consecutive on error - Broken main fuser connection
*Heat lamp consecutive on error - Check HR thermistors with SP1-106 001 (ctr) and 002 (ends)
*Heat lamp consecutive on error - Heat roller lamp defective
*Heat lamp consecutive on error - Power Supply defective
Mar 11, 2014 | Ricoh Aficio 2022 All-In-One Laser Printer
It is a problem with the lamp in the fuser pressure roller.
Aug 26, 2013 | Gestetner Office Equipment & Supplies
Hie I have a Gestetner DSm615 which is giving me error code SC:552.How do i solved this problem?
  • 1 0 7
Feb 02, 2009 | Gestetner DSm615 Digital Imaging System
3,348 people viewed this question
k24674
Marvin
Marvin
