Have u checked color settings of the camera? Press the button which u use to change the image resolution. After this, u press the left/right navigation buttons and u will reach the color changes, i.e., B&W, Chrome, or Color. Your camera settings might have been changed. Gud Luck.
if u see white screen and lcd show info and signs and pictures also turn out to be blank when u see them on pc
CCD Failure has occured !
dont worry i have the same problem with my S5000 i contacted fuji and they repaired it free of charge bcoz it is a known problem in thousands of cameras of different brands just call them in ur area and they will do it free of charge
see this http://www.imaging-resource.com/badccds.html
for support in usa or select different region www.fujifilm.com
it is not a driver problem bro if it is not showing anything i mean u take pic and it is black or dis colored its a CCD failure u cant help it go to fuji repair centre and bang on their head its a hardware fault 1000's are facing
take pic and it is black or dis colored or lines on it its a CCD failure u cant help
1000's are facing
There is a little blue button next to the LCD button, directly above the display screen. There are alot of controls when you press, like color, B&W, shutter speed, etc. Thanks
This is a CCD sensor problem ( see enclosed image of one taken out of a Cannon camera with similar specs to yours ). Contact Fuji agent as this is repaired under warranty .
This appears to be loose connector to the motherboatd from the screen. Try gentle squeezing of the casing near the bottom of the body This may do the trick- otheriwise it is a workshop job and frankly not worth the cost - the money would be better spent on a more uptodate camera.
