Question about Cuisinart DFP-14BC Custom Food Processor
Cuisinart Food Processor Custom 14 turned off
I ahve been making butter and the machine turned off..I know there is a reset button but I can't remember where
  • 8,596 Answers
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Posted on Jan 07, 2009
  • ewhite5 Jun 08, 2011
    Awesome, this was just the info I needed. Apparently it was operator error...
The food processor stops working after use. I know there is a reset "hole" to make it start again. I can't see where it is and cannot find it in the manual. Please tell me where it is so I can...
Not all food processor have a reset button, some don't have. You have to be make sure that the unit is in fit, suited because it will on the interlock switch (the safety switch) before it operates normally.
I hope I give you idea regarding your food processor problem.
Mar 27, 2011 | Cuisinart DFP-14BC Custom Food Processor
I bought a peanut butter maker (model #PBM-200) for about $85 and it does not work. After trying several times I even tried grinding up the peanuts in a food processor before putting them in the peanut...
Where did you buy it? Return it, pretty much everything you buy has a certian warranty. Get your money back or replace it with a new one...............
Jan 04, 2011 | Food Processors
The robot coupe will stop working periodically during use. The reset button on the bottom pops out after it has been used for a short while. I run a kitchen and it can be very frustrating trying to get...
It is overheating, probably because it is being overworked. Some common problems are overloading the bowl, or forcing too much food into the hopper on top. Once it overheats, it will kick out again rather quickly the next time unless the motor has time to cool. If you are shredding cheese, slow down on the amount of cheese forced into the blade. If you are trying to mix heavy dough you are probably overloading the bowl as well. This machine can't handle over a pound of pizza dough without overheating. The reset button is there to keep from burning the motor out. If you continue to reset and force feed the machine, it will burn the motor out. Good luck, hope this helps.
Sep 11, 2010 | Robot Coupe R2U Ultra Food Processor
How to disassemble the Sunbeam Oskar processor to wash.
Ours is hard to remove, too. I just hold the base with both hands, then put my left thumb and right index fingers on the parts of the bowl where it attaches to the base. Then push it, if I remember correctly, clockwise. This works far better than gripping the entire bowl.
Jun 30, 2010 | Sunbeam 4817 Oskar Food Processor
Cuisinart overheated while trying to make almond butter
If someone can make mayonaise and know how they can make plaster the way to start the proces , then they know nothing about to make beem breezes or almond butter the engine of this kind of tools are not made for the heavy work a a little but good suggestion is like a Hobart dough mixer thats not a food processor like that DLC-5 because is made for shakes and normal fruits and vegetables or some kind of meat no problem But not for heavy emulsification operations if start to make butter from cream then you must beware of the slowly power increase comming force you can hear the difference in sound , the same problem if you have a Kitchen cutter do not cut out full fat young cheese on it at most only for a short time , because the armature and field magnet of the motor become much too hot when cream changed into butter then stop the machine quickly and when there are heavy nuts almonds are coming too its much too much force for it the commercial group Home appliances a little suggestion is cut only the nuts in the dlc-5 and doing make butter and more heavyer jobs with this kind of tools Hobart A200 20 QT 20qt Mixer Bowl 200 20 Mixing Pizza Bakery Dough
Jul 19, 2017 | Cuisinart DLC-5 Food Processor
Just purchased Oster 3322 food processor and cannot get it to work. Have used various brands and know that this unit has been properly assembled. Neither the 'on' or 'pulse' buttons will activate the...
Oster is a good brand. Unplug it and try to turn thhe motor by han using an attachment. Or, tap the unit with a run button depredded. Here is why. Sometimes new brushes on a motor have a coating on the conrtact surface. It is vry thin and it is not permitting a good electrical contact. If you can't turn the motor, slap it a couple of times with it on. Once it starts, let it run for 2 or3 minutes and you troubles are over once the brushesseat and clean up. Good luck and remember to unplug when hands are on or near the attachments.
Oct 27, 2009 | Food Processors
Won't start
Make sure the work bowl handle is locked in place so that it is facing the front of the processor (same side as the on and off switches).
Make sure the feed tube of the lid is facing toward the back of the processor and that the plastic or metal rod of the pusher sleeve is facing the back of the processor.
Note: this assembly only applies to the Cuisinart DFP-14 series - every Cuisinart has a slightly different assembly for it to turn on.
Sep 13, 2009 | Cuisinart DFP-14BC Custom Food Processor
Cuisinart DFP-14BC Custom Food Processor Logo
1,007 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Bruce Showalter
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
