Question about E-Machines eMachines Desktop PC
Can't pm anyone or see my display window - E-Machines eMachines Desktop PC
  • George Bill
    George Bill May 11, 2010
    This is a prime example of a post that we cannot answer, there is no information in it, wo are you trying to pm. what are you trying to see, we don't know how to help you. Do you mean your messaging program doesn't work are you connected , you need to give all the info, brand of computer when the symtoms started what application you are using etc, we cannot help you with no effort on your part
    President:
  • 2,692 Answers
Reinstall PM.
Posted on Dec 22, 2008
How to remove e-studio 2508a time for maintenance
The conditions of the PM display consist of the codes of the setting mode (08) for "the setting value
treated as a threshold of the PM display", "the counter indicating the current number of prints and
driving time" and "the setting value which determines the display conditions".
08-6190: Setting value of PM counter [process unit (K)]
08-6191 : Setting value of PM time counter [process unit (K)]
08-5554 : Setting value of PM counter [developer material (K)]
08-5555 : Setting value of PM time counter [developer material (K)]
08-5562 : Setting value of PM counter [parts other than the PM parts of the process unit]
08-5563 : Setting value of PM time counter [parts other than the PM parts of the process unit]
May 07, 2018 | Office Equipment & Supplies
Has anyone had scuming on back side of sheet only. if so what was the fix.
Sir/Mam,
Yes you mite need to have the upper and lower fuser rollers replaced. When was the last time a Preventive Maintenance (PM) Kit 250K was done. every 250K copies the machine needs a PM and the developer needs replacement. The drum is replaced every 500k. Is there a tiny wrench being displayed in the upper right of the op screen? If so PM required.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 31, 2014 | Konica Minolta Bizhub 600 750 Image...
How do I set the time on Timex T231 clock radio?
Setting The Time of T231
NOTE: The time can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the MODE/ALM RESET button until the display briefly shows 'OFF' and then reverts to the time.
1. If the display is flashing, press the HOUR / REV button to advance the display to the correct hour. If the display is not flashing press and hold the CLOCK button until the display begins to flash, then press the HOUR / REV button to advance the display to the correct hour. Observe the PM indicator to confirm that you have set the hour correctly. If the PM indicator is 'On' the hour on the display is PM. If the PM indicator does not appear the hour on the display is AM.
2. Press the MIN / FF button to advance the display to the correct minute.
3. When the correct time is flashing on the display press the CLOCK / PRESET button once more. The display stops flashing and the clock begins to run.
Oct 01, 2014 | Timex Audio Players & Recorders
Change time display fro AM to PM
Reset the time using 0-11 for the AM hours and 12-23 for the PM hours. For example, for 6AM use 6 and for 6PM use 18.
Mar 08, 2012 | Sharp EL-1750PIII Calculator
Jvc model av36f702 it jumps of evry time im trying to put it on with the remote . i tink the timer is set to 0 secones .can i reset the tv.
press display button & it shows the following
07
NOW 12:20 PM
SLEEP TIMER OFF/on
ON/OFF TIMER EVERYDAY
ON TIME 7:00 PM
OFF TIME 10:00 PM
• The current channel or AV input (Channel 07)
• The current time (12:20 pm)
• Sleep Timer status/minutes remaining (The Sleep Timer is off)
• On/Off Timer status (Set to turn on everyday at 7:00 PM, off at 10:00 PM)
• Each Press of the DISPLAY button changes the display mode:
Press the SLEEP TIMER button & set it to OFF
Dec 22, 2010 | JVC AV-36F702 36" TV
I am using my sbicapsec online account for the first time. After i log into the trading login, I am getting the following diagnostic message. Dec 15, 2010 3:03:41 PM : Loaded all market watches...
Browsers are out of date. Since you did not post the operating system, you may not be able to install versions of the browsers that are needed to display secure and html 5 data.
Mar 03, 2017 | Computers & Internet
I'm having a problem with my thermostat. It's a
Set Current Time and Day
1. Press TIME button once. The display will show the hour only.
EXAMPLE: PM
2. Press and hold either or until you reach the correct
hour and AM/PM designation (AM begins at midnight; PM
begins at noon).
3. Press TIME once. The display window will show the minutes
only. 1F80-361 pdf
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 14, 2010 | Heating & Cooling
Iluv iMM153 please describe how I change the time from 24 hour
i have the exact same problem, i the picture of the product, it says pm on the side of the display, and its can say pm ont he display !!
Dec 11, 2009 | Audio Players & Recorders
Time displayed in window
With the printer turned on, hit the "Setup" button, then use the "Options" button and the right cursor button below it until "Set Fax Functions" appears in the window. Then hit "Enter" and follow the prompts to first enter the date (00-00-00) using the number buttons, then the time (same buttons). Set either a.m. (1) or p.m. (2) using the same buttons.
Sep 03, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Emerson Radio CKD9906
I hope this will help you, I just found the Users Manual to this Model online myself, as I needed info on setting the Alarm.
I am also going to upload the full Manual, just incase anyone else needs it.
Cheers!
Peachess
Setting The Time Of Day
• Connect the power cord to your AC outlet. Make sure to use an outlet that is
always ‘live’. Do not use an outlet that is controlled by a wall switch.
• When the unit is plugged in for the first time the
display will show flashing “12:00” (AM).
1.) While the display is flashing, press the HR. button to set the hour. Be sure
to observe the PM indicator to set the hour correctly. If the PM indicator is ‘On’
the hour displayed is PM.
2.) Press MIN. button to set the minute correctly.
3.) Press the TIME button once. The time is set.
The display remains ‘On’.
Note: You may proceed to re-set the time again by pressing the TIME button
once during Power-off or CD, FM, AM, Buzzer modes.
Important Notes !!
If you press and hold the TIME button any time, the clock will change to
European 24-Hour format, and 12-Hour USA format.
May 10, 2008 | Emerson (CKD9906) Clock Radio
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
