Kenwood KW85 Air Conditioner
Problem for Kenwood KW85 Air Conditioner
Kenwood kdw243a dishwasher has an e3 error code
By kgmoreau on Dec 21, 2008
No idea what the error code means.
the only thing that looks odd is the rinse liquid indicator is now on, although I added liquid.
Once the door is closed, a bleep comes up about 20 times and stops.
Once on light wash the dishwasher did try to start, only to stop after a minute.
No idea what is going on, it worked great so far and only is one year old.
Same Problem
Apr 21, 2009
-   exactly the same. It stops and I notice that the soap is still there so I run a rinse. Planning to call them to fix it.currys as just bought it.-   Guest
Apr 16, 2009
-   kept draining, took side off and water out have tipped 45 degrees put side on now getting e3 code also rinse aid light is white weird any ideas really appreiciated thanks in advance-   hopeforbest
Mar 04, 2009
-   exactly the same. It stops and I notice that the soap is still there so I run a rinse. Planning to call them to fix it.-   Guest
Feb 16, 2009
-   kenwood dishwasher e3 code on lcd display,dishwasher stops have to restart it keeps on doing it can any body help ........ i will have to finde a wife to wash my pots so please help-   dazwood
Jan 24, 2009
-   I also have the same problem. There was water in the bottom of the dishwasher, when I turned it on the E3 error came up and the water was drained away. The pump just wont stop. Any ideas?-   Guest
Best Solution
posted on Mar 16, 2009
Very Helpful)
jostro65
Rank: Apprentice
Rating: 100%, 2 votes
i have same prob,seen this elsewhere folks. apparently it's the temp sensor which MAY have failed. http://www.howtomendit.com/answers.php?id=134096
has to be cheaper than an expensive call-out and worth a try.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Apr 16, 2009
Not Rated)
hopeforbest
Rank: Apprentice
Rating: 0%, 0 votes
For perso who pump wont stop for, take off side after unplugging, there will be loads of water in bottom, soak out with towel, should work ok after this
Was this helpful?
Yes
No
Popular Solutions for Kenwood KW85 Air Conditioner
Questions and Unsolved Problems for Kenwood KW85 Air Conditioner
Do you recommend Kenwood KW85 Air Conditioner?
Answer
Answer
hi my kenwood dishwasher kdw243a is not releasing the tablet door and not getting hot ?
Answer
my friend needs more information on how to set the controls on a altech althc014 thermostat. he... (More)
Answer
I need an interal water bucketfor a Kenwood Kw85
Answer
I get the message E3 and can't get it to cool.
Answer
No matter what I try, I can not get the compressor to run. It won't even go on cool. The message is... (More)
7 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 13, 2009
Yep, exactly the same problem. Help, don't want to spend a fortune on an engineer...
Comment by jhdgkss, posted on Dec 28, 2008
Hi there i have the same problem i think its a problem with the outflow of water tried moveing the outlet pipe no luck.
Describe your Air Conditioners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in , PA
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
