Question about Master Heaters B155DST
There is low pressure on the vaccume pump - Master Heaters B155DST
  • 232 Answers
Correction- the pump is not a vacuum pump. I produces positive pressure. Follow these instructions. It's easy.
Posted on Dec 22, 2008
WHERE IS THE VACCUM PUMP ON A 05 FORD F250 6.0
Your engine is a vacuum. You can not pump vacuum. Only remove pressure.
Oct 03, 2014 | 2005 Ford F 250 Super Duty
What is the pressure of the locking front hub when doing the leak test On a 2000 ford 250 super duty truck
The 4x4 system works on vaccum and not presure. If this is not a Diesel you may have a vaccum leak. Check your vaccum hoses from the wheeles back up to the intake for cracks. If this a Diesel Super duty the 4x4 system works off a small vaccum pump out under the hood on the passanger side right over the tire. There is no pressure it is vaccum. Run the A/C and see if the A/C is blowing up on the windshield or out the vents were it should. Change it to the floor and see if it changes, If it does not change the vaccum pump is not working. Check your fuses first. If they are ok check for voltage at the the vaccum pump. Check your ground as well. If you have voltage and the ground is ok the pump is bad.
Nov 23, 2011 | 2000 Ford F250 Super Duty Crew Cabs
The pump works well to the pool but once we hook up the vaccum it has low water pressure
THIS IS WHAT VACUUMES DO THEY RESTICT WATER FLOW, YOU NEED THE PIECE THAT ATTACHES TO THE HOSE TO REGULATE THE AMOUNT OF SUCTION. YOUR LOCAL POOL SUPPLY SHOULD HAVE IT ,, AROUND 10 BUCKS .. KOOL FIX .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL HIT THE YES BUTTON IF I WAS OF HELP THNX J
Jun 07, 2011 | Pool & Spa
My 34700Z is not discharge low side existing pressure, wen i select vaccum the low side hose have pressure and stop to make vaccum
Please Check the following 1# Check ISV tank may overfill,if so manually discharge extra pressure from the tank.2#Check High & Low side small recover solenoid (in small manifole assy.) it's may neet to rebuild.3# Check Recover/Vacuum/charging (in main manifold assy.)solenoid,rebuild if need.4# Check ISV tank liquid hose is connected properly & make sure it's not too much tight OR loss.5# Check high side coupler is opening properly.Hope this will help you to solve the problem.
Apr 13, 2010 | Robinair Cool Tech 34700Z Recovery,...
Car is acting like it is not getting gas... i broke the line above thetank and there is gasoline under pressure.
Have a fuel pressure test done, you may have some pressure from breaking the line, but may not be enough. It should be between 40 and 50 lbs of pressure. If it is low, the fuel pump is weak, if it's high, the fuel pressure regulator is bad, or a vaccum leak to the regulator.
Nov 13, 2009 | 1995 Toyota 4Runner
AC blow out hot at low rpm
when you are stoped does the car idle fine. when the rpms are low the compressor does not get the pressure up high enough. you may need to get you idel turned up a little or your vaccume advance may have a vaccume leak.
Jun 24, 2009 | 2004 Saturn VUE
Low oil pressure after engine warms.....
A 1999 Yukon DOES NOT have a vacuum advance. It is computer controlled timing. Low oil pressure is the result of some or all of the following : worn oil pump, worn cam bearings, worn crank bearings. Oil pressure also normally drops as engine warms because the viscosity of the oil changes with temperature.
Jun 22, 2009 | 1999 GMC Suburban
2000 mercury grand marquis air conditioning won't work
1st Thing,
Located Someone With a Set Of A/C Gauges 134A Freon,
Make Sure Your A/C System Has Enought Freon In It, There Is a Low Freon Pressure Switch
In The Electrical System, Usually, 50-60 PSIG or Less On The Gauges, Will Indicate Low Freon, When Freon Is Low The Compressor Is Dis-engaged To Prevent Compressor Damage.
1] Low Freon
2] Bad Low Pressure switch
3] Blowen Fuse[s]
4] Electrical Problem[s]
[a] Digital Climate Controlled ?
Climate Control Self Diagnose From Button's On Unit, OEM Manual Explains This,
If Yor Auto Has Digital Climate Control.
5] Bad Compressor DC Coil
Note: Does The Compressor Engage, Click-On When Button Is Pressed, But Getting
Only Warm Air?
Is One Of The Compressor Aluminum Tube's Cold, Be Careful Other Is Really Warm/Hot,
If Cold and or Sweating, Dripping Water [Normal], You Are Blending Hot Air w/Cold
Air At The Heater Blend Box, Making Warm Air.
If This Is So, If A Vaccum Controlled Temp Unit, Check For A Vaccum Hose Bad,
Should Be Either 1or 2 Vaccum Lines Going Into Firewall To Feed The Controller
Unit, If OK, Might Be a Bad Blend Box Diaphram, [Control's A/C air, Blocks Off
heater Coil Hot Air].
If Your Auto Is Vaccum Controlled, Can You Changed From Bottom, Dash,
Defrost Air Flow?, Yes, No Vaccum Lost Feeding Controller, Still Might Have
Bad Diaphram Blending Hot Air w/Cold If Your Have Cold Alum-Tubing In
engine Compartment.
If Digital Climate Controlled, Might have Diaphram's, Vaccum Controlled or
electrical Servo's Controlled vs Diaphram [Vaccum] Controlled.
This Might Help, Hopefully, This Is Just For Starter's, There More To Some System's
and Without The OEM Mgr's Manual[s] You/Be Would Be Lost, especially w/Electrical.
Later, God Bless
Apr 24, 2009 | 2000 Mercury Grand Marquis
Low suction to my vaccume
backwash the pool then let it prime again and try the vacuum
Apr 16, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
A/c warm low and high side pressures wrong
it could be one of 2 things.
you didn't vaccum it all the way or there is b clog in the system. next time u flush it run about 1/8 cup of rubbing alcohol through it . then push clean air through it. then refill it. if that doesnt work replace the seals on the compressorlow and high side lines/manifold.
Dec 15, 2008 | 1999 Chevrolet Blazer
Master Heaters B155DST Logo
101 people viewed this question
Top Master Heaters Heating & Cooling Experts
T bone 1963
Gil Shultz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
