Question about Coleman Powermate Premium Plus 6250W Portable Generator
My Coleman OHV 3000 will not start
If I spray starter fluid in the carb, it runs for a few seconds then stops. Fuel flow to carb seems to be the problem. I have clean fuel and a new spark plug properly gapped.
Is there a fuel line filter I can't see?
Is there a cleaner I can put in tank that may clean carb.?
This generator has always been hard to start.
With the help of carburetor cleaner and starter fluid I was able to start but if open the choke(push it in) it stops. I will check the float.
Thanks-
NKT
Posted on Aug 19, 2012
    Problem Solver:
  • 13 Answers
Dont use starter fluid ,will ruin engine.Sounds like the float in the carb is stuck.and keep lookin for a filter.
Posted on Jan 06, 2009
I have a cub cadet GT 2550. Has new battery cranks but will not start. Thinking it's not getting fuel. Checked fuel filter and fuel flows through.
If spraying starter fluid in the intake causes it to run for a few seconds, then you have a fuel problem. That starter fluid is the fuel. If it didn't have spark, it still wouldn't run. I would start checking the carb and make sure nothing is stuck or plugged.
Apr 18, 2017 | Motorcycles
Coleman power mate won't start. Plug is good, fuel is getting to carb. If I use starter spray it will run for a few seconds and die.
sounds like a sticking float or clogged needle jet inside the carb.
i'm currently working on exactly that same issue
Dec 01, 2016 | Coleman Electrical Supplies
Clogged fuel filter
take the line of the carby and check the fuel flow first
indicates that the carby is not filling ( jammed needle and seat) or the main jet is blocked
Jun 29, 2017 | Troy Heavy Machinery
2005 sportster 1200 carburater not getting fuel
1. remove the full line from the carb, turn on the petcock and watch it flow into a container. Make sure that the petcock is in the correct position and that the tank has at least a half tank of gas. If the petcock does not flow gas, the tank/petcock has a fuel flow issue. If the petcock has a smaller rubber line connected (vacuum controlled) to it, it will need vacuum applied to it before it will flow fuel. Vacuum can be applied using a hand held vacuum tool (purchased at a auto store) or light suction from the mouth will do.
2. If the petcock does flow fuel, remove the inlet to the back of the carb and spray a 1-2 second burst of starter fluid into the carb and attempt to start it. If it attempts to start after spraying it with starter fluid, the carb is plugged and needs to be cleaned.
Aug 06, 2012 | 1979 Harley Davidson XLH 1000 Sportster
Where do I spray the starter fluid (air intake?) for Chrysler Silhouette. Ran out of gas and it seems carburetor needs starter fluid to kick it..not sure where air intake is locater.. or where to open carb...
there is a large tube that goes to your throttle body (you do not have a carb), remove it and spray there-be careful, starter fluid is highly explosive, spray 2 or 3 short bursts into the top of the throttle body opening, and install the tube (you don't have to tighten the clamp). You may have to repeat this a few times, if you can only get the car to run for a few seconds 3 or 4 times, and it will not run on it's own, you have a fuel delivery problem, and no amount of starter fluid is going to fix it.
Dec 28, 2010 | 1994 Oldsmobile Silhouette
I replaced the carburetor, spark plug, and put in new gasolone on a Toro Recycler (5 yrs. old) and it still won't start. The ignition is only one year old. Seems like I'm not getting any spark and the fuel...
Hi. Replace the air filter. Then use some starter fluid and an assistant. Spray some starter fluid into the air intake as you start it up and keep spraying so that it runs on the starter fluid for a few seconds until it really takes off. J.
If this does not do it then you will have to have the carburetor rebuilt as it has hardened gunk in it.
Aug 01, 2010 | Garden
No feul
there is usually a tiny filter on the pickup on the fuel tap, you need to remove the tap from the tank to get to it. Before that pull the fuel line off the carb and open the tap and see if it flows. If fuel runs out , leave the tap alone
There also may be some jets blocked in the carb
May 05, 2010 | 2003 Yamaha YZ 250
Tecumseh 17.5 hp ohv engine won't start
check valve clearance. if ok you going have change carb.sometimes i rebuild a carb everthing seam ok but carb wont work right so i have get a new carb and it works fine evertime
Jul 20, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
It won't stay running
You need to either clean the carb really good (take it apart) or rebuild it or both. Sounds like your needle is gummed up and not letting fuel through.
May 29, 2009 | Honda Pressure Washer PSI 3000
Coleman Powermate Premium Plus 6250W Portable Generator Logo
430 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
