Question about Frigidaire Refrigerators
Frigidaire fsc23f7dsb Had brown out and now led inside fridge is saying E for Freezer temp and F for fridge temp
  • foster999 Dec 21, 2008
    Did not receive a solution:
    Had a brown out, power came back on. Lights are on in fridge, but fan and motor are not running. LED for temperature settings are reading: E (for freezer temp) and F (for fridge temp). I have turned the fridge off and back on again - no change.
    yes
    Genius:
  • 2,920 Answers
There is a three prong relay on the backk of the fridge that may have gotten burnt when you had the brown out. youll have to to have it checked
Posted on Dec 21, 2008
    Sergeant:
    Novelist:
  • 327 Answers
How do I change temp readout from c to f on a refrigerator frigidire that is 10 years old model FSC23F7DSB
Hello Joel, thank you for your post!
I understand that you would like to change the temperature readout on your Frigidaire refrigerator, FSC23F7DSB. In order to change your temperature display you need to hold the fresh food arrow up and then press the freezer up arrow 3 times within 5 seconds. I hope this information is helpful. -OOS
Mar 18, 2015 | Frigidaire Refrigerators
Refrigerator water dispenser has water to bottom of door but will not dispense
water is frozen up in door. try turning temp to freezer up a little.
ive been able to thaw line by using hair dryer on inside of freezer door
Mar 11, 2013 | Frigidaire FSC23F7DSB Stainless Steel Side...
Freezer temp. keeps rising
try to turn off the freezer and adjust the temp. settings to a minimum.. Make it 20 minutes for your fridge to turn off before you turn it on. If the temp. keeps on rising, refer to your freezer manufacturer to repair the thermostat inside of it.
Aug 27, 2011 | Frigidaire Refrigerators
Compressor humms for about a minute then clicks off. neither the fridge or freezer are cold. What should I do?
compressor is faulty. It controls both the fridge and freezer. you have a minute chance that if you switch the fridge off for 30 min. and retry it would have cooled down enough to restart.
Jun 05, 2010 | Frigidaire FSC23F7DSB Stainless Steel Side...
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Does outside temperature affect performance of freezer
Top mount refrigerator installed in a garage and the food in the freezer is defrosting when
the temperature in the garage goes below 55 degrees fahrenheit.
On top mount refrigerators you cycle the compressor and fan/fans from the food
compartment temperature. When the room temperature gets colder than 55 F, you have
long off times waiting for the food compartment to warm enough to trip the cold control.
This long off time is allowing the freezer temperature to get high enough that food can start
to defrost.
There is a kit for refrigerators installed in applications where the temperature can go as low
as 34 F and still maintain good freezer temperatures. The kit part number is 5303918301
and it contains a heater that mounts in the control box and an instruction sheet advising
how to install the heater.
Kit 5303918301 contains:
Part # 5303950194 Instruction sheet
Part # 241532101 Heater
Nov 21, 2008 | Frigidaire FRT21H8 Top Freezer...
I have a frigidaire sisde by side refrigerator model # FSC23F7TDW. My Temperature control is reading the the freezer & fresh food temp in centigrade. How do I get the Temp display to read in...
Same Guest as above posting this ... By the way, I have a FLSC238DS5 ... I spent 45 minutes on phone w/Frigidaire this afternoon (Phone#: 706-860-4110 Option 1 --> then Option 3). Didn't get anywhere. They say there are 3 solutions that should change it from C to F: 1) In between LED readouts for "Freezer Temp" and "Fresh Food Temp" there is a mode button that is hidden under the plate that you can press w/your finger OR 2) Hold "Fresh Food Temp" Up Arrow Key down, within 5 Seconds press "Freezer Temp" Up Arrow Key 3 times and it should change C to F or vice verse. Didn't work for me so she said 3rd option was to have a service tech come and diagnose. She said there would be a charge. I am not paying to have somebody come here to resolve this issue. That is when I asked her to escalate it to a supervisor which she did. Hopefully, I get a call back & a solution. Stay tuned ...
May 24, 2008 | Refrigerators
Frigidaire Fridge PLHS69EESS2
Could be a jammed fan or something could have moved inside to block the opening. Some units have deflectors in the openings...did one of those cover the opening on the fridge side? Did you overpack your freezer and block the air flow from there to the fridge?
Dec 29, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
