Question about Akai PDP4206EA Television
Brownout killed my TV, looking for a replacement Main Board...
I recently had a brown out here at home and even though my plasma TV was connected to one of the those el cheapo 2000 joule surge protectors, it still fried the Main Board. The TV blanked out for a minute and when it came to, the picture was blood red. I had troubleshooted and issue similar to this when I bout it and it turned out to be the Main Board (with the cpu). Apparently the flash had become corrupt and was providing incorrect information to the CPU. I suspect the Flash has become corrupt again, but the backup I made using my Willem doesn't seem to work now. I have tried a few backups that I have mand and Removing, programing, and resoldering this the flash is really taxing on the PCB and chip and now it won't even turn on. I get a steady green power light on the front of the TV, but hitting the power button or the remote doesn't seem to put things in motion. I suspect the chip has given out and it won't boot the CPU.
Has anyone seen anything like this? Did I kill something else? Does anyone have a backup flash that they can email me for an Akai pdp4206ea? Does anyone have a replacement Main Board? Would you be willing to trade? I have a working video board for my Akai pdp4206ea (I bought it during troubleshooting a B/W issue with this same tv and it turned out that it wasn't the problem). I can overnight the part to you if you wish.
I need the video board, can you sell me that ? jpadilla_mercado@hotmail.com
Posted on Jul 13, 2009
Samsung TV plasma 60" just quit working while watching it PN60E6500EF it look at the capacitors all are fine any ideas ?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sep 25, 2015 | Samsung PN60E6500 60-inch 3D Plasma TV
How do I fix my power on issue with my LG Plasma TV
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jun 08, 2015 | LG Televison & Video
What parts probably need replacing on my Pioneer plasma PDP-5010 FD after a home lightening strike?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 03, 2017 | Pioneer PDP-5010FD 50 in. Plasma HDTV
My samsung 50 inch T5054 Plasma shuts itself off
Power supply or something connected and the clicking is likely a mechanical relay that is not bad but not engaging.
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
Jun 01, 2012 | Samsung HPT5054 50 in. HD-Ready Plasma...
LG 42PQ30 plasma tv wont turn on anymore, when you plug the tv in it makes a click noise and when you hit the power button the blue light comes on then changes to red after couple seconds. Note the...
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_15_2012_1_19_09_pm.jpg
May 15, 2012 | LG 42PQ30 42 in. Plasma TV
Panasonic Viera TH-42PZ80U Plasma TV wont turn on from the control or switch
Power supply is of course first suspect here. Some general information:
ISSUES:
Answers to issues:
May 05, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
I heard small pop then lost power while watching my lg 50pg20. No red or blue lights on the power switch. What could be wrong?
you are describing a power supply defect. IT may be as simple as the main fuse. I believe the one in this set is a 6.5 amp located on the ps board right by cord connection. IF after replacing the fuse opens a second time you will need to replace the power board.
p[lease leave feedback
Feb 20, 2011 | LG 50PG20 50 in. Plasma HDTV
I HAVE A samsung hpt5054x xaa 50" PLASMA TV THAT LOST ITS PICTURE DURING AN ELECTRICAL BROWN OUT. I HAD A SPIKE PROTECTED OUTLET BOX BUT THAT DIDN'T HELP. THERE WAS AN ELECTRICAL SMELL COMING FROM THE...
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 01, 2017 | Televison & Video
Dell W5001C 50 in plasma - vertical black line
the y-boards are not the problem. its the e or f board located on the bottom of the panel open the back cover and look at both for potential burn spots around the silicon sealant. if one or r brown, theres your problem. ebay the board number and get it fixed.
Aug 18, 2008 | Dell W5001C 50 in. Plasma HDTV
Power problem with an LG 50PC3D Plasma 50" TV
YOU PROBALY HAVE A BAD Y SUSTAIN BOARD OR POWER SUPPLY. POWER NEEDS TO BE DISCONNECTED FROM THE Y SUSTAIN AND THE VA & VS VOLTAGES CHECKED.
Jul 29, 2008 | LG 50PX4DR 50 in. Plasma TV
Televison & Video Logo
173 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
