Question about Mitsubishi CS-40307 40" TV
Mitsubishi tv 40" cs40307 vertical shrink problem
My picture shrinks vertically when hot to about 3" then pops back to full picture
please help
  • irishman8685 Jan 01, 2009
    i have the same tv and i am having the same issue i can hear the program but have a horizontal bar across my screen, i assume its something loose because if i bump the tv the bar will move for a second
    Champion:
  • 252 Answers
Thats problem is only a lose connection,if you know how to used a soldering iron ,solder the vertical section of your tv.
Posted on Jan 26, 2009
Why does my TV keeps shrinking the picture?
The problem is failure of the vertical sweep circuit.
Nov 24, 2015 | Televison & Video
My 45 inch Mitsubishi rear projection tv's picture
Good day!!!
try to see the button below and find the trimmer try to look at it and find vertical hold adjust it..if not helped just go to this link www.fixya.com/users/bugoy31
good luck..
Feb 04, 2012 | Mitsubishi Televison & Video
Panasonic TX-68PS12A Picture shrinks in vertical direction at top and bottom over period of 15 minutes until vertically compressed picture occupies approx 1/3 of the screen in a central band
Ur Vertical/Horizontal ic is cold solders,U know how to solders?Take the tv aparts use a back handle of the screw driver tabs around find out where V/H the cause resolder that.
Oct 22, 2009 | Televison & Video
Pictures shrinks.. Panasonic TC-20LM Television
Shrinking picture is a voltage regulation problem in the switch mode power supply, Possibly a cap used in the feedback circuit. Or an over current condition on the B+. This is a very tech intense repair because there is no magic bullet. If it is shrinking on bright scenes then you can bet it is a regulation problem, bright scenes draw more current from the power supply causing this effect. I would not suspect the horiz output because the regulation for this circuit usually comes from the main switch mode power supply. One diagnostic is to monitor the B+ going to the horizontal output and see if it fluctuates. If so you can bet it is a cap or optical coupler in the switch mode circuit.
Oct 10, 2009 | Panasonic Televison & Video
TV screen shrinking from top to bottom.
My Dearest, j30;
It sounds like you have a problem in the 9 volt circuit which feeds the vertical output ciruit; CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
This is not a repair that a novice should try, but if you call a factory authorized service center and have them come out and give you an estimate; AND tell them what the problem is, you will look know what you are talking about!
Aug 11, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Picture broken and shrinking
You need to change your vertical IC, along with some capacitors around the vertical IC. Capacitor with value 220UF, 10uf, 470uf and finally 1000uf. Doing this will fix the set. Total cost under $40
Best regards
Circuitcity
Nov 29, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Zenith console tv model sentry 2 27 inch
Resolder the vertical deflection section. Change pump up capacitor if it has one...100uf is a typical value. Is the vertical output some flavor of LA783x ?? May need to replace. A model # would help.
Nov 04, 2007 | Televison & Video
Mitsubishi CS 40503 TV
  • sometimes the entire screen is normal size
  • from this statement it is clear that there is a loose contact in tv
  • please check for loose contact in some components
  • loose contact in connector
  • loose contact in print.
  • if you are not tech person then take help from him.
  • hope this will help.
  • good luck.
Oct 11, 2007 | Mitsubishi CS-40503 TV
Picture is shrinking from the bottom
Hi you have lose solder in yor vertical section have a tech resolder it or that problem will cost you .hope you have already have it remedied.
Nov 14, 2006 | Toshiba 36A40 36" TV
Televison & Video Logo
330 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
