Question about HP Computers & Internet
I have a HP m7000 and there was a power outage, and now it won't even start at all anymore. Is there a fuse or something. It has no response to being turned on or off. All cables appear functional.
  • sherlock852 Dec 21, 2008
    But how do you check the charger, the batteries?
  • sherlock852 Dec 23, 2008
    Thanks - yes very helpful and prompt!
    President:
  • 2,110 Answers
First check ur charger ,then ur battery is working or not...If both are ok then ur motherboard needs to be replaced...
Posted on Dec 21, 2008
  • Sibananda Jena
    Sibananda Jena Dec 22, 2008
    Sorry I thought its a laptop....
    So first check the power supply SMPS inside the cabinet(for that u can lokk inside the cabinet for fan movement or any lght glowing )..If it is ok then ur mother board needs to be replaced...
My hp pc m7000 doesn't show any files on my monitor why
Hit the windows key and see if anything comes up. If so someone deleted everything on the desktop.
May 07, 2014 | HP Media Center M7000 Drivers Restore...
Will m7350n memory chips work in a m7000
A) HP Support > HP Pavilion Media Center m7350n Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=1818343&cc=us&dlc=en&lc=en&jumpid=reg_r1002_usen_c-001_title_r0001
Product information > Product specifications > HP Media Center m7350n Desktop PC Product Specifications,
Memory
PC2-3200
That is DDR2 Sdram at 400MegaHertz. (400MHz)
Has 240 gold plated contact pins on the bottom.120 on each side.
One Locating Notch on the bottom also.
Problem is I find no HP Pavilion m7000, or HP Pavilion m7000n; Desktop PC.
Look on the back of the computer for the white Service Tag.
What is the Product Number?
P/N = Product Number
Post back in a Comment.
I can tell you that if it's a Pavilion m7060n Desktop PC, it will work,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00306958&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=459895
Same thing if it is a Pavilion m7070n Desktop PC,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00306962&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=459896
Be SURE you FOLLOW Anti-Static Procedures, when working on your unplugged from power computer.
Everywhere on the Ram Memory module ('Stick'), EXCEPT the gold plated contact pins at the bottom; is the BODY.
The Body is coated with a see-through protective plastic.
Handle the Ram Memory module by the Body.
Refrain from touching the gold plated contact pins.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 11, 2013 | Computers & Internet
Honeywell thermostat won't turn the furnace on after power outage.
probably tripped a limit switch or a low voltage fuse would kill your display on the tstat, you should have battery power on your stat though.unless you have knowlege of electrical you better call a technician
Dec 09, 2012 | Honeywell Programmable Thermostat Heater
Our Ruud ac won't come on after a storm and power outage? I have flipped the breaker with no luck. Any suggestions?
there is a fuse on the circuit board on the inside unit. Typically a power surge will pop it. checking that fuse is the best place to start
Sep 29, 2012 | Ruud Heating & Cooling
HP Media Centre M7000 won't fire up
if its completely dead buy a new power suppley. else its the motherboard that is defective. check your warranty first.
thinks you can test is to remove all your memory and bios battery then try to start
Mar 07, 2012 | Computers & Internet
We a Kenmore Elite clothes dryer (Model # 110 70972990). Monday there was a power outage that happened while the dryer was running. Hours later when the power was back on, we tried to finish drying, but...
There is a thermal fuse. If your lint filter is on top of the machine it is in the rear of the machine behind the removable panal near the exhaust port. If the filter is in the door the fuse is behind the kick plate on the top of the blower housing they are usually white plastic. But a power outage won't blow the fuse
Oct 19, 2011 | Kenmore Dryers
Flashing green light on power supplyonly fans come on at start up
just open ur pc case replace the ram and all connections for 5 to 10 min clean dust inside pc and also clean ram and put back in to pc and restart i hope ur comp will be right back to normal!
Aug 02, 2010 | HP (152769-001) (152769001) 250-Watt Power...
There was a power outage in the middle of the night. My computer was turned on during the outage (Presario 2200). Now it will not turn on ; it is plugged in (was in a surge protecting power strip during...
Please try to remove the battery and than try to switch on the laptop directly from mains power and if it works than its your battery problem or if it still not starts than there is possibility of some components of your laptop may fired due power fluctuation. So go and contact service station.
Jan 08, 2009 | HP Compaq Presario 2200 Notebook
The light
If you cant turn it on then its probably a bad power supply. So i would bring it to your local pc shop, a power supply for a regular home computer shouldnt run to much, and labor for it should be less than 1 hour. So you could get away with around 100.00.
If i read your last message wrong and you can turn it on, then do as i suggested and test the voltage read, but if its clicking, then somethings wrong, computers only click when somethings broken.
Aug 07, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
69 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
