Question about Samsung CLX-2160N All-In-One Printer
I have a Samsung that say Transfer Belt Error
Samsung Printer:
My Samsung printer is showing Transfer Belt Error My new printer wont print webpages from IE 7, it will print everything else but webpages.... why?
PLEASE HELP ME WITH THIS!
  • Anonymous Apr 17, 2009
    Najgori moguci model , katasrofa, mada imam resenje, nabijte ga nogom najace sto mozete, i vidjecete da ce se bolje ponasati.. 100 %
    Problem Solver:
  • 4 Answers
Hi guys.. iam Aqeel from pakistan.
i've just solved that stucking problem today and tellining u guys who are facing such problems over thr.
All you need to do are two steps:
1- detach the paper tray and push it back correctly.
2- open front door and remove toner cartridges, on left inner side u may see a light sensor which detects the toner cartridges.. simply clean this section by a small cotton bud. and left side of toner unit thr is a sensor door, behind that door there is also a light sensor bulb, which needs cleaning by a cotton bud.
thats all
i hope this will help u fixing that problem.
bbyee
Posted on Jan 20, 2009
My printer can`t print and shows me to 'Check the transfer belt'
Your printer monitors the life of your transfer belt. When the transfer belt reaches the end of its
life, the printer displays
80 Belt Exhausted. This message indicates it is time for you to
replace the transfer belt. For best print quality, make sure you replace the transfer belt when
80 Belt Life Warning.
Press
Go to clear the message. The Supplies message appears on the second line of the
display to remind you that supplies need attention. You can open the Supplies Menu to see
80 Belt Exhausted
or 80 Belt Life Warning messages.
The printer continues to display the
Supplies message until you replace the transfer belt. To
replace the transfer belt, use the following steps or the instruction sheet supplied with the
transfer belt.
Nov 26, 2012 | Samsung CLP-610 Series
Have a transfer belt error What to do?
To fix this error, you will need to replace the transfer belt and/or reset the transfer belt count on your printer. If you are happy the the print quality of the printer, then you can try to reset the transfer belt count and that will clear the error. Otherwise you need to get a replacement transfer belt and swap it out before resetting the count.
To remove your existing transfer belt, you need to open the front panel, and remove the imaging unit by pulling the green handle. The belt is located above the imaging unit. Pull the belt down to release and then pull it straight out of the machine. Take your new belt and slide the back into the machine and push the front of the belt up to lock in place. Then you need to reset the belt count.
To do this, follow the steps below.
1. Enter Tech Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press OK
6. Enter Password 1934
7. Arrow to Transfer Belt and press OK.
Hope this helps you.
Apr 02, 2011 | Samsung CLX 3160fn All-In-One Printer
How to fix transfer belt error in my samsung CLX3160fn
3. Select Tech Menu
4. Select DataSetup
Feb 27, 2011 | Samsung CLX 3160fn All-In-One Printer
How do I fix a transfer belt laser error? unplugging the power cord does not work What does this transfer belt look like? where is it located in my samsung CLX-2160N laser printer? thanks!
The transfer belt is a consumable like the toner, you will have to buy a new one once its run out so your printer is telling you it has so buy a new one. They look like a small conveyor belt from a supermarket and is generally located under the toner or fuser unit housing.
Mar 28, 2010 | Samsung CLX-2160N All-In-One Printer
Transfer belt error problem
*Check patch sensor *Alternatively your IBT belt needs to be replaced
Aug 24, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Internal error on samsung clp 300
what you need to do is get a new transfer belt, if you email the company they should give you a new one.
Feb 02, 2009 | Samsung CLP 300 Laser Printer
Hi
I have a utility to reset the consumables errors on this printer, but only if the component is past its lifecount. (60k for transfer belt)
Its called CLP-300_Reset_RLCv04.exe or just RLCV-04.exe (if you can find a copy)
If you need a copy, let me know and I'll find some way to get it to you.
I've used it for transfer belt reset and it works.
Dec 19, 2008 | Samsung CLP 300 Laser Printer
Transfer belt error
Rather than turn printer off, unplug from power source, wait a few minutes and plug back in. It's worked twice for me so far...
Sep 12, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung printer error
Time to buy a new transfer belt. samsungparts.com
Apr 29, 2008 | Samsung CLP-500N Laser Printer
Samsung CLP600 - wants me to install a transfer belt
"install transfer belt" message" appeared right after black toner was relpaced with a non samsung toner(new chip too)--installation of new transfer belt did not solve problem--- i went back and reinstalled the original samsung chip into the toner cartridge---the "install transfer belt" message is gone and the printer works but has a "low toner" message----i guess i learned my lesson the hard way---anyone in the market for a new transfer belt???........wj
Mar 31, 2008 | Samsung CLP-600N Laser Printer
Samsung CLX-2160N All-In-One Printer Logo
454 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
