Question about Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 4100 squeaky sheet feeder
I know something needs to be lubricated in the Auto Document Feeder (sheet feeder) of our Intellifax 4100, but I'm not sure where or what lubricant to use to stop it squeaking. I'd like prolong its life and not hear the squeak anymore. It does get a fair amount of use. Thanks for help. Bob P.
  • Bob Pegram Aug 01, 2007
    Thanks! I'll be looking on the Brother site for repair / rebuild instructions. If I find them, I'll post the URL here. If I don't post that soon, could you tell me/us where to get them? I have learned not to "learn how to take it apart" when I also want to FIX it!
    Bob P.
    P.S. The cost estimate is also quite useful. I'll spring that on my boss, either way it goes... 8-)
  • Anonymous Mar 05, 2008
    Mine sqeaks too...once every second when printing. When I open lid and turn rollers by hand no sqeak? Could problem be in the fuser rollers?
  • 328 Answers
The doc feed asm needs to be rebuilt. Only white lithium grease is used to lube the gears and avery light oil on the shafts. All parts are available from brother. I can get the parts if you have trouble obtaining them. It is relatively easy to rebuild and I charge in my area of Clearwater Florida, about 100.00 parts and labor.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 01, 2007
WILL NOT FAX LARGE QUANITY OF PAPER
Don't know what you mean by "large quantity" of paper.???
The ADF (Automatic Document Feeder ) has a Max. capacity of 20 sheets(depending on paper thickness.)
Jan 12, 2011 | Brother IntelliFax-2820 Laser Fax
My Brother Intellifax 4100 sends faxes that appear with a solid black line on the side--i think it's the right hand side. It prints copies the same way. How can I fix it?
if the faxes going out have the line but coming in print out clear then the glass at the document feeder is dirty and probably needs cleaning.. check under the feeder cover and look for a glass piece where the documents go in this picks up dirt and typex and when it scans the document it thinks its on the original.. a soft cloth and some glass cleaner should clean it off..
Jul 11, 2010 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 1" black line on right in send & copy modes
lift up your document feeder and check for something on the **** glass
Nov 16, 2009 | Brother IntelliFAX 4100 Laser Fax
Lines on fax going out, fine receiving fax
check the scanner glass under the cover where the documents are fedd through if you lift the lid on this you should see a thin slip of glass if this has ink or usually tipex on it the lines will be on every fax that goes out.. there might be a small roller over this that has a clip each end you can take this out for acces to hte glass
Jul 31, 2009 | Brother IntelliFAX 4100 Laser Fax
Original jammed in fax feeder of Brother Intellifax 2800
lift document feeder cover and look for paper. if no paper is present there are one or two switch levers that are on the bottom of feeder cover. make sure they can move freely and are not stuck.
May 27, 2009 | Brother IntelliFAX 2800 Laser Fax
When sending a fax on our Brother Fax-4100 the person on receiving end of the fax says it comes across totally black What is the problem??
If you make a copie. on your fax.
That is the same quality that you are sending over the phone line.
If the copie is total black
lift the document feeder see if there is anything on your optical glass.
But my experience tells me that the lamp has gone out also know en as the scanner asm.
let us know what hapens
Apr 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Black line on all faxes I send to recipients
open the document feeder and look for wite-out on the small scanner glass.
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Document feed doesn't
drive gear is wore down on bearing surface good luck finding one
Apr 11, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
633 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
