Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
Bissell turbo revolution
When the vaccuum picks up dirt it goes on top instead of the large container. The sponge like filter is always dirty due to this. Can it be wash or does it need to be replace and if so where can I find a replacement?
    Problem Solver:
  • 7 Answers
You can wash that sponge filter by hand but you must let it dry compleatly before putting it back in the machine, I found a filter pack for the lift off vacume at walmart, make sure teh bottom filter is clean as well. the lift off vacume has 3 filters there is one filter in the tray under the dirt cup, one in the top cup, and the hepa filter in the back the 2 foam filters must be clean or you can have reduced suction, the lift off vacume I have I found thrown away because they never cleaned it outthe brush was dirty and full of strings the belt was worn, the hose under the vacume was full and stopped up the hose in the back was compleatly stopped up all filters were compleatly clogged, and the hepa filter was missing entirely. Not to insult you or anyone but i've found that a lot of people are jsut to lazy to clean their vacume out it fills up with dirt they throw it away and get a new one, i've gottten many like new vacumes for this reason, this bissell is working like brand new now. and I just replaced the belt and all filters in it saving me approx. 150.00 for a new one
Posted on Dec 30, 2008
Bissell powertrak revolution dirt not going into cup
If the unit is not blocked between pickup and filter have a good look at the filter to see if air is passing through it---paper throwaway or foam filter the can be washed?
The ones that can be washed etc will have instructions right on them.
Nov 02, 2012 | Bissell 6591 Power Trak Revolution Bagless...
Don't picK up the dirt and has a noise
Have you changed the filter? What kind of noise? Unusual high pitched noise? There could be debris stuck in the hose or the secondary filter/screen could be clogged. What were you vaccuuming when this happened?
Mar 13, 2011 | Bissell Vacuums
Is blowing dust out as I vacuum
In your manual:
Visible dirt escaping from cleaner
Possible Causes: Remedies:
1) Dirt Container full 1) Empty Dirt Container
2) Filters missing or installed incorrectly 2) Check Upper Tank, Pre-Motor and Post-Motor
Filters for correct installation
3) Dirt Container installed incorrectly 3) Pull out and re-insert Dirt Container correctly
Feb 01, 2011 | Bissell 6591 Power Trak Revolution Bagless...
Dirt gets caught up in filter instead of in removable container
That is the problem with the bagless cleaners. The dirt goes through the cup, directly to the filter. There is nothing to keep them seperate. You can try putting a single layer of paper towel against the filter. It will provide a breathable barrier for the dirt but, it will clog too.
Aug 24, 2009 | Bissell 3576 CleanView II Bagless Upright...
Seems to be picking up dirt but not very well & there is nothing in the canister to empty.
more that likely the top filter is clogged. step one. remove the clear plastic dirt holder. step two. reach inside the upper dlear jug, still attached to the unit and twist the large disc you see counter clockwise about a 1/4 turn. pull it down and it should be covered in dirt. clean and wash out the filter and your machine should work like new. If this doesn't help let me know what you see. If it does , please rate this answer. thanks
David
May 19, 2009 | Bissell 6594 PowerForce Bagless Upright...
I have a Bissell Lift-Off Revolution upright vacuum cleaner. The dirt is sticking around the black round sponge filter which is in the upper part of the cleaner. It isn't falling into the bowl like it...
Actually, that is the purpose of that filter. These filters keep the dirt, and debris from entering the vacuum motor, making the repair cost much higher. You can rinse this filter, let it dry and use it again. That filter is also inexpensive, so that you are encouraged to replace it often, But I have included a link to your owner's manual if you need anything else.. or contact me and I will try to help more.
http://www.bissell.com/images/UserGuides/3750_905.indd.pdf
Jan 22, 2009 | Hoover U8145-900 Savvy Bagless Upright...
I cant find my manual to clean my Bissell lift of revolution
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Jan 03, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Loss of suction bissell vacume
that is normal for the vacume to shut off if the motor overheats you must keep teh dirt cup clean and empty and all the filters clean, when you empty the dirt cup if you have a lot of pet hair take the hose off and make sure that it is clean as well, and do not try to pick up any of those cleaning wipes that will stop it up real quick
Sep 29, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell Powerforce bagless 6594 W filter cleaning and reassembly
the sponge filter goes around the plastic part with tons of vertical slits on it
Aug 08, 2008 | Bissell 6594 PowerForce Bagless Upright...
Hair gets stuck in upper filter basket instead of going into the lower basket that you are supposed to empty. It is a Bissell 37604 Lift-Off Revolution Pet Bagless Upright Vacuum Cleaner
Check both filters. If one or other is increasingly dirty, wash or clean it out. Also check the air waves leading to the bagless bin canister part. If one air way is blocked the remaining dirt will try and access the bin other way due to the natural vacuum suction aspect.
Apr 19, 2008 | Vacuums
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
109 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
