Question about Cameras
Olympus sp510uz I have no sound on my video. picture great but no soud and yes I did have sound in the past.
2 Suggested Answers
SOURCE: Olympus sp510uz no sound on video
From SP510 camera switched off:
1. Turn dial on top plate to movie mode (selections from the menu screen apply to the mode the camera is set in);
2. Switch on SP510 power;
3. Press "MENU" button on back plate;
4. Select "Camera Menu" from screen if not already on it, using navigation buttons on back plate
5. Scroll down yellow "Camera menu" tabs to microphone picture (below "Digital Zoom"), which may be showing "off". Select OK and toggle yellow tab from "off" to "on", then press OK button.
6. Microphone tab should now show "on".
7. Return to main menu (press MENU button).
8. Return to image screen (press MENU button).
9. Test to see if video now records sound.
10. If is still doesn't record sound, try "reset" from video menu screen (this will reset the movie mode to factory settings, including microphone on).
Posted on Feb 07, 2010
Olympus sp510uz
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Nov 29, 2013 | Cameras
My Olympus x-42 doesn't take a picture. View from monitor is perfect but when I take a picture, all there is is a white screen
Some symptoms of a defective CCD (Charge Coupled Device) include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value.
Click on or copy and paste the link into your browser... CCD Sensor Problems
In this link, other owners with this problem obtain certain commets:support/canon_fs100_fully
Hope this helps.
Aug 15, 2012 | Olympus X-42 Digital Camera
Does the olympus fe 4020 g camera have a microphone for sound when recording a video
according to the user manual. yes it has a microphone built in and is located below the camera lens
see the picture attached
Dec 20, 2010 | Olympus Cameras
The digital card should hold 32 pictures but is only holding 7. It has always taken the full 32 pictures in the past.
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok.
Jun 18, 2009 | Olympus Stylus 710 Digital Camera
Where does the Olympus XD Picture card go in my computer?
you need a Home > Computers & Software > Memory Card Readers > Olympus 200830 xD Picture Card Memory Card Reader > Product Details Buy it from one of these stores: * B&H Photo-Video-Pro Audio Overall Rating: 9.8 $29.95 * Amazon.com $35.49 * Buy.com Overall Rating: 8.7 $34.17 Olympus 200830 xD Picture Card Memory Card Reader Olympus 200830 xD Picture Card Memory Card Reader Price Range: $29 to $49 at 10 store.......sodeep
Jun 09, 2009 | AOpen Olympus 64Mb xD-Picture Card (AX4C...
Picture error message on olympus 1200
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the Picture error message and the card can be used again. The picture error message indicates that this image is now corrupted and unable to be viewed through the camera.
Apr 23, 2009 | Olympus SP-500 UZ Digital Camera
Olympus 850sw- write protect and picture error
Sounds as if the memory card has corrupted data on it now. You will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup Menu - right arrow to Format- Press Ok. You will see format yes or no. Choose Yes and press ok. This will clear the write protect and picture error messages and the card can be used again.
Dec 29, 2008 | Olympus Stylus 850SW Digital Camera
Dec 21, 2008 | Olympus SP-510 UZ Digital Camera
No sound recording during video recording with olympus fe 170
To my knowledge, an Olympus FE-170 has no audio recording capability and records the video on 15FPS.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 30, 2008 | Olympus FE-170 Digital Camera
Grainy pictures on my Olympus sp510uz digitial camera
Unfortunately the response you received from Olympus is correct. The Image stabilisation system used in your camera does not use the best approach to overcoming camera shake - rather than a more expensive sensor based system it downgrades the picture quality and in dark (relatively) situations the result is grain in the picture. See bottom of Page 25 in the Advanced Manual (found on the CD which came with your camera). A similar problem occurs if you turn on and use the Digital Zoom available in the camera. Unless absolutely vital for a particular shot turn both off.
Try it and see the benefit.
Mar 26, 2008 | Olympus SP-510 UZ Digital Camera
Cameras Logo
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
