Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Ice maker is not working
My GE profile side by side refrigerator is 1.5 yrs old.
the ice maker is not working. i have replaced the filter re-set the on/off switch....I don't know what else to try..before i have to spend a fortune..did not purchase extended warranty..
tks
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
gfgfgf
Posted on Sep 30, 2010
GE Profile Refrig model PSC23SGRC ice maker stopped making ice. Water is ok, just stopped? Is this common? Its only 4 yrs old
Your model has an electronic ice maker part number Click Here=> WR30X10093 When the electronic ice maker fails you usually need to replace the complete ice maker. You can test the ice maker by filling the tray with tap water. If the water freezes aand then drops the ice then the water control on the back of your refrigerator is the reason. The water control valve is Click Here=> WR57X10032 Either way let me know your results, Thank You, Sea Breeze
Jan 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Nov 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
In my GE Performance refrigerator side-by-side Ice is being made, but no water is dispensing. The GE Smartfilter is atleast 5 yrs old. I just replace new filter still not working
If the water stopped before you replaced the filter we have something to consider is that the water control valve on the rear of the back of your Profile and down where the water enters the refrigerator you will see two coils and a set of female plugs attaches to each coil. Most likely the coil for your water dispenser is defective and and the side for the ice has not failed. When telling you the correct model of your profile is needed to give you the replacement part number for your dual water control valve. In a few moments I will show you an example of the part that I am talking about, Thanks, Sea Breeze
Oct 12, 2009 | GE Profile Performance 25.2 cu. ft....
GE Profile stopped making ice. 2 yrs old
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath freezer needs to be 0 degree F to start ice maker
Aug 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker stopped working w/red light blinking
The blinking light is an indication that your built in water filter needs to be replaced, it's in the refer. side, middle top or rear of refer.
May 25, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My water dispenser suddenly has stopped working.
Yes, it could be the water filter. Also check to make sure the water is turned on and that any lines to the refrigerator aren't kinked or crushed somewhere. It's also possible that you will not be making any ice as well if your appliance has an ice maker
Apr 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile TFT25 PR. Ice maker quit producing
Had the same problem. Replace the water filter and is should begin making ice again.
Mar 05, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
539 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
