Question about Fossil BQ9183 Wrist Watch
Removing links How do I remove the links on my watch? I notice only certain links have arrows. What are the arrows for?
  • 1 more comment
  • chanse May 10, 2008
    need to remve links from brown ip stone fossil watch, style no. es1861
  • Anonymous Jun 05, 2008
    fossil CH-2510 removeing links
  • Anonymous Jul 13, 2008
    need to remove links on fossil watch AM4078
It?s very tough to remove the links, I would recommend taking it to a dealer If you have to, you will either need a fine punch (or very masonry nail), a medium hammer, and a piece of wood a couple of inches square, a rag or wash cloth. A sturdy flat blade watch makers screwdriver. The ones from a dollar store may not work, and a pair of pliers. There are two types of links, both of them are a pig to remove, expect lost fingers, lots of swearing and possible scratched strap. Version one, The one I think you have, Place the watch strap flat on something hard, put a cloth under it so it will not mark, the outside of the strap will be on the cloth and you will see the arrow, there is a rectangle with a nipple recessed inside. Place the blade of the screwdriver between the nipple and the edge of the rectangle, press down and wiggle between the nipple and the edge and twist, there will be a locking pin which comes out of the side link, in the direction of the arrow. Wiggle away until you can free the locking pin. It?s simpler to put them back. Version two, Place the rag folded a couple of times on the block of wood Place the strap on the rag so it?s on it?s side, hang the watch over the edge of the block so the strap is flat against the block and there is nothing touching the watch (hanging in air) Look at the edge of the strap, see the small pin, in the fold of the metal, punch it out (down into the cloth) enough to then grab it with the pliers, I actually drilled a small hole in the block of wood so the pin would be pushed into that rather than against the wood, but don?t drill holes in your dining table! I would still recommend taking it to a dealer,
Posted on Apr 05, 2007
  • Ian jolliffe
    Ian jolliffe Apr 05, 2007
    Typo, sorry
    Should read
    (or a very SMALL masonry nail),
Shorten the band on a Mossimo watch
Thank you for contacting FixYa.
  • Place the watch face down on the cloth. This will help keep your watch from being scratched.
  • 2
    Examine the links closest to the buckle. These links will have small pin holes on each side of the link, as well as a small arrow engraved on the inner side of the band. These indicate the direction the pins must be removed.
  • 3
    Place the driving tool (a thumbtack will work) inside the pin hole in the band and push the pin out in the direction of the arrow. Remove the pin carefully from the other side.
  • 4
    Repeat Step 3 to remove any links needed to adjust the band properly.
  • 5
    Reattach the band to the buckle. Attach each end of the buckle back to the bracelet, driving the pin in the opposite direction from how it was removed (opposite the arrow).
  • Best regards. Jewel
    Sep 15, 2010 | Bulova Watch
    How do I adjust the length of the bracelet (watch band) for a Casio EF106D-2AV bracelet watch?
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Aug 21, 2010 | Casio Edifice EF106D2AV Wrist Watch
    Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    http://www.pulsarwatches.com/home2.asp#FAQ
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    Adjusting a casio s940db watchband
  • On the inside of the band, locate the links with the arrow etched on them. The arrows mark the removable links.Lay the watch on its side on a flat surface with the arrows pointing downward. Be sure to leave about 1/2 cm of space between the bottom of each removable link and the flat surface. Using a 1/32" flat head jeweller's screw driver (or metric size 1.0), insert the tip of the screw driver into one side of the removable links' pin holes. You will find that the pins have an end that looks like a screw head. This is misleading - press down very firmly on the other end. Press downward firmly to make the pin pop out the other side. Be careful not to lose it.Remove the pin on the other side of the arrow-marked link.Repeat as necessary to remove half the needed links. You will remove the other half from the other side of the band to maintain equal band length.Flip the watch over so the arrows are pointing upward.Align the holes in the remaining links. Insert the rounded edge of one of the pins into the open link hole. The pin will go in without trouble until the top.Holding the pin in place, carefully flip the watch over again and firmly push the pin fully into placing using the flat surface. The pin will snap into place.Repeat for the other half of the band as necessary.
  • Sep 26, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
    Watch band sizing
    OK, I make an attempt:
    I saw on other pictures on the web that the links have small holes at the side. There should be some links with arrows r another marking. These are usually the links that can be removed to shorten the strap.
    If there is a small arrow on the link, it means that you can push out the pin inside the hole in the direction of the arrow. Then the link can be detached.
    You can push it out with a blunt sewing needle (break off the tip).
    Remove links on both sides of the watch when resizing it.
    Hope that helps.
    Critter
    Dec 26, 2008 | DKNY 1009 Wrist Watch
    Wrist band adjustment
    In addition to the Pin there is also a small inner "locking" collar about 2mm long that fits into the center section of each link.
    I did not notice this collar at first and it fell to the ground when I removed the first link. Without this piece the Pin's will just slide through the links with no locking mechanism.
    It fits neatly into the inner portion of the link directly opposite the arrow that shows the direction of removal on the band.
    Jul 01, 2008 | Casio G-Shock G7000D-8V Wrist Watch
    I just bought a fossil watch ch2331 and need to remove a link. how do i do it?
    Some of the links are removable on this watch & some are not. Look inside the band you should see some tiny arrows on the removeable links. You need to push the pin through in the direction of the arrows & remove the link. Then to put the band back together you need push the pin through in the opposite direction of the arrow. Make sure the widest part to the pin goes in last or it won't fit.
    Mar 09, 2008 | Fossil CH2331 Wrist Watch
    Removing links
    look at the arrows, then get a thumbtack and a small hammer and a thick cloth. then put the pin in according to the arrows. start tapping it with a hammer, dont tap it all the way out, just enough so you can pull it out with a pair of pliers.hope this helps!
    Dec 28, 2007 | Watches
    Shorten watchband
    I have a similar watch and removing the links are not easy. There are pins in certain links that have arrows on the inside of the band. I used a push pin to remove the pins in the direction of the arrows. Snip the end of the push pin with a wire cutter or pliers so that it fits into the hole and tap the top of the push pin with a small hammer until the other end of the pin is exposed enough to extract it with a set of needle nosed pliers. Repeat for other side of link. When the pin is extracted, twist the link inward and it should snap out.
    Remove the link and reverse the procedure, placing the pin in the opposite direction as it was extracted. You may have to tap it gently with the push pin and hammer to get it to go into the holes flush.
    It takes a little while and some patience, but if you can get someone to hold the band for you while you tap the pin, it will be easier. Also, if you remove the spring loaded pin from the band fastener so the band can be laid out straight, it will also be easier. Good luck!
    Mar 30, 2007 | Timex Outdoor Casual Expedition®...
    Fossil BQ9183 Wrist Watch Logo
    383 people viewed this question
    Top Fossil Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    john h
    Are you a Fossil Watch Expert? Answer questions, earn points and help others
