Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Refrigerator, s/side, too cold, etc
Admiral 21.6 CF, HMG62163 (about 1990-91, s/side) started freezing most foods on lower two shelves as well as in drawers, even with temp at warmest settings. Freezer is running extremely cold, too--ice cream is like a block of ice. Circulation fan seems to run overtime. Can't tell what compressor is doing. Concurrent with the extreme cold temperatures, the water dispenser and ice maker stopped working; I.e., no water to either unit and ice motor (auger) wouldn't turn over. After 2 or 3 days, the ice water worked. Next day the ice maker worked fully. Then water disp started working intermittently for a day or two. Food on lower two exposed cooling shelves still freezes but ice maker is okay for now. Are these other issues thermostat-related? Can you recommend a good troubleshooting or repair manual, or is "The Admiral" ready to be retired? Will dirty grills cause such problems? We've not moved/cleaned under or behind refrig for 9 or 10 years. (We've never been able to adjust flow of cold air to vegetable bins to keep food from freezing. We accepted that as a stupid engineering flaw re baffles, controls, etc., within weeks of buying the unit.)
  • Darryl Love Apr 24, 2007
    Thanks for your response. I have done that since my initial post and it may have helped, somewhat. At least, the refrig doesn't freeze as badly as it did. I played with the temp settings, baffles, etc., too.
    Let me ask you about this: I took out the temp control to make sure it was working. It gets continuity, as it should, but the switch seems "backward." E.G., there is an arrow pointing toward colder--the opposite way should be warmer and eventually "OFF." But the control actually click off when turned in the direction of the arrow, or "colder." I haven't had time to check whether "WARM" is cold and "COLDER" is warmer--this didn't seem like a possibility. But could the temp control be manufactured "backward?" We've never been able to use the veggie bins since we've owned it, despite the controls. Any thoughts?
  • Darryl Love Nov 20, 2007
    Thanks, jomong.
    And can you believe I still have the cover off the controls, etc., because I never got around to fixing this mess. So, I will replace the temperature control. But, on the thermostat, I may have to go back to the library book to be sure of what I am doing. However, I assume you mean the loop and the small grey metal box it comes out of, which is connected to the switching assembly. Am I correct? If so, thanks for the tips.
    Problem Solver:
  • 11 Answers
Hi! your problem was temperature control,it is malfunctioning.. replace your termostat.
Posted on Nov 20, 2007
Unplug and let defrost. You should also clean the grills off in back and get all cob webs off from underneith. that might help
Posted on Apr 24, 2007
Admiral american fridge freezer constantly blowing cold air into fridge compartment.
Changing the freezer settings won't really make a difference because regardless its still going to be freezing. The way the machine works is the freezer cools the fridge, and there should be a control in the fridge that operates the baffles in the airway between the freezer and fridge and reduces the amount of air that enters into the fresh food section.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 17, 2012 | Admiral 26 cu. ft. Side-By-Side...
Our amana side by side works well, in fact too well. It freezes salad greens in the vegetable drawers and now freezes things like yogurt on the open lower shelves too. We've turned dow the settings to...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Apr 07, 2011 | Amana SXD524VW Side by Side Refrigerator
Our Whirlpool GI5FSAXVY refrigerator is freezing items. The temp control has been set to 38 degrees forever. It appears that things on the lower shelves are freezing more than things on the upper...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 12, 2011 | Whirlpool GI5FSAXVY Stainless Steel ...
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Everything in fridge freezes intermittently
Your vent has and electronic vent controlled by a setting on the control board. The electronic vent or circuit board are most likely the reason for the problem.
I will help you if you want, Sea Breeze
Jun 30, 2009 | Admiral 26 cu. ft. Side-By-Side...
Refrigerator side too cold
YOU MAY NEE TO REPLACE THE COLD CONTROL {T-STAT}
Jan 25, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Feb 07, 2008 | Admiral 26 cu. ft. Side-By-Side...
The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Jul 09, 2007 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
466 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Jose Pino
steyr1
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
