Question about Canon PIXMA MX310 All-In-One Printer
155.0.0 error with Canon MX310 scanning issue
I am running wireless with my printer now - using my time machine capsule. It prints fine but when I tried to scan a picture I said cannot communicate with scanner. Cable my be disconnected or scanner turned off?
thanks for helping
Phyllis, Issaquah WA
  • Skyken Dec 25, 2008
    It worked in the past. Removed and reinstalled s/w and put usb in a different usb port on the computer. It will copy so I know it's not an internal h/w issue.
  • yvd0 Jan 25, 2009
    same here
  • 46 Answers
SOURCE: scanner error
if you put the installation cd in the drive and then if it autostarts close it down, then go to device manager and the properties of the scanner and update driver let pc search automatically and it should reinstall it and then all should be fine i hope , had the same problem on my all in one device
Posted on Sep 24, 2007
SOURCE: error 21550 pixma mp160
I found a solution for this problem
change your usb cable.
you must use a Anti noise usb cable
it's only solution
Posted on Nov 19, 2007
SOURCE: canon pixma mp830 will not scan
I am experiencing the same problem, from the equipment id does not scan
Posted on Jun 09, 2008
SOURCE: Scanning error - cannot scan error code 2,155,0 ???
I had the same problem with a new Canon MP970. Printed ok, but couldn't communicate with the scanner - error 2,155,0.
Canon phone support didn't help, and suggested it was a firewall problem. I uninstalled, and re-installed, turning off firewall, virus software, and everything. No luck. Tried several USB cables, no luck.
Then I uninstalled again - as well as a couple of old drivers and software associated with two now deceased printer/scanners.
This time I plugged the (same) USB in and turned on the device, using Windows' own hardware install wizard.
Now it works fine (at least for now... touch wood).
So - the problem might be either conflict with other printer/scanner devices installed, or with Canon's installation software.
Posted on Aug 02, 2008
SOURCE: Scan problems with Canon MX310
I had the same problem. After replacing the USB cable with a good one the scanner came back to life.
I suspect scanner has a higher requirement for USB data transmission thats why printing and copying work but scanning does not.
Posted on Sep 20, 2008
When attempting to print, my Canon MX310 seems to run fine, but the paper is blank. No errors reported, but just blank paper
Have you tried running the clean heads and prime functions. If the printer has set for a while, things may have dried out. Or, perhaps the cartridges are out of ink?
Jul 19, 2016 | Canon Office Equipment & Supplies
Is there anyway I can scan when my Canon MX310 has run out of ink?
Hi .if you have your printer connected to your PC you should still be able to scan into your PC . I don't think that running out of ink will make any difference unless you want to print what you scan . Scanning is not making copies it is just scanning into a PC you don't use ink to do that.
Mar 11, 2015 | Canon PIXMA MX310 All-In-One Printer
Why Canon MX310 won't scan error 114.0. how to fix
I have this copier too but only use it as a copier in my classroom. It's a stand alone. But can't print. There is no software to install on a computer so I don't know how to fix it if there's no software.
Feb 26, 2012 | Canon PIXMA MX310 All-In-One Printer
Connected Canon MP610 to Apple Time capsule via USB. My Macbook pro prints wirelessly perfectly, as does my sons Vista Laptop, however my daughters vista laptop and my wifes XP laptop print black fine, but...
Hi richardhaley,
Isee that you are having issues with your Canon MP610 printer.
You mentioned that your printer is connected to an Apple Time capsule via USB and that it works fin on your Macbook and on your sons Vista Laptop but prints the colored shifted to the right on your daughter's Vista and wife's XP Laptop and this is connected via USB.
If I may ask have you tried printing wireless using your daughters Vista Laptop and you wife's XP Laptop to see if the colors are still gonna shifted to the right.
Also you mentioned the drive that the driver you are using is from bonjour but still you have the same problem.
Here is a link where you can download drivers specific for the versions of windows your daughter's Vista and your wife's XP would have, you will need to select exactly the OS operating system for the driver that you need also there is a software for each Operating system as well maybe you can download that as well for both system for you to be able to recalibrate the printer from the 2 machines.
I hope that this will help.
Thank you for choosing Fixya,
mvincentc
Jun 06, 2011 | Canon MP610 Photo All-In-One Printer
Canon mx310 won't print wirelessly from laptop. all of network is working except this. pls help. Linksys is the router, Dell running Vista is the laptop, Canon is the printer.
The MX310 is not a wireless printer. I own it and have never seen that feature anywhere in the specs either. Try the MX860 (my roommate owns it and it's VERY nice).
Oct 30, 2009 | Canon PIXMA MX310 All-In-One Printer
Attempting to print to a Canon MX860 remotely results in the file printing at a very reduced scale Attempting to print email message The printer is connected to a Apple Time Capsule. The Time Capsule is...
Change the scale in the print options. The print options can be seen when you start to print something. There will be an option asking "print to scale"...select that and you should be fine.
Nov 03, 2017 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
HAving trouble printing
Check and make sure you did buy the right one first.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
i have found the way to scan items from a Canon MX310 (on windows)
1.On windows go to control panel
2. click hardware and sounds
3. then hit devices and printers
4. then click on the Canon Inkjet MX310 seriers
5. then you will see scanner management click on scan Photos or docs
6.then place the photo or doc under the scanner and hit scan!
That is all the steps you will need.
17 years old computer tech.
Aug 16, 2008 | Canon PIXMA MX310 All-In-One Printer
Can't Scan with MX310 hooked up to Time Capsule
If you mean you connected it to the airport, that only supporting printing, not scanning. Have to plug it into the computer.
Jul 02, 2008 | Canon PIXMA MX310 All-In-One Printer
Can't print to mac wirelessly (could do it a few days ago)
I had the same problem until recently. You have to install the drivers FROM THE CD that came with the printer, instead of selecting the drivers from the default list. Then, when selecting which printer driver to use (you'll have two options) choose Canon IJ and NOT Canon MX310 series. This is a problem with their MX310 driver, which is solved using a default/generic Canon InkJet (hence, the IJ) driver. Hope this helps!
P.S. This only works on Mac OS X. I have yet to figure out how to print wirelessly through Vista. Will keep you posted.
Mar 28, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
2,460 people viewed this question
Clive
Clive
old marine
old marine
