Question about Riso RZ220 Duplicator
E11 on riso gr 1700
What is e11? Before the machine has this error, my copy lose a image on the outside edge of paper and after that it give me e11 and machine stop running.
I check master on the drump, there is the image on it but ink are evenly on the master except the edge that i lost the immage.
Anyone know how can i fix this problem
Thank you
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
When machine displayed E-11 it’s interrupted the operation.
Its means Pressure Control Motor Lock –
If the Pressure centering sensor does not detected on & off within 5 seconds from the start of the machine.
This problem is the engine of pressure, this is located by uncovering the back, more or less in the middle and bottom, there is a small motor that is attached by screw(s). When the machine is turned on its intial position should be detected and if not , the sensor can be bad or the starting position is dirty or broken cable, or motor cables are bad, inspect them, reset the code and turn the machine off and back on.
Posted on Jan 14, 2009
    New Friend:
E 26 in GR1700
Posted on Jun 30, 2015
Riso gr 1700 e01 error
Riso has the answer on the back page of the manual
May 09, 2014 | Riso RZ220 Duplicator
Our school owns a Riso RZ machine and theirs a problem with it; the code is A-06 it also has this -403. Could you please help?
our school owns a Riso EZ 200ep machines and their problem with it ; does not want to pull a master roll and give the code error A-06 and -403. Could you please help me on this.
E-mail me; nambwex007@yahoo.com
Jan 04, 2011 | Riso RZ390 Duplicator
Diffrent picture between the original document and master picture
You have to go to your page setup and set for the size you are printing. Also you have to go to the machine and look at the size the paper setting is at.. they have to match.. You may be printing 11 x 17 when the paper setting on the machine are letter.. This will do this...cause the machine will auto adjust to fit onto the settings on the machine.
Jul 22, 2009 | Riso Office Equipment & Supplies
Riso gr 3770 error T14
how can i solve the Error T14 for Riso Gr 3770
Thanks
May 12, 2009 | Riso RZ220 Duplicator
Riso gr 3750 error T14
Means a clamp error. Inspect the clamp on the drum to make sure it moves smoothly and that that clamping mechanism in the back of the machine works as well.
Apr 06, 2009 | Canon PC-140 Black and White Copier
Riso GR3770 will not pull the paper through once it passes the initial feed assembly. The paper ''picks up'' just fine, but after the lead edge enters the machine, it kicks off impression and gives a...
what happens sometimes is the rear side of the registration (shiny silver color) roller becomes worn down so bad that the spring cannot grab properly. the registration roller, in this case, would have to be replaced.
the way to check is by getting to the back of the machine, and if this is the cause, the spring should be a little wobbly on the shaft. with a new roller, the spring fits snug, and grabs properly for it to feed.
Mar 31, 2009 | Riso Office Equipment & Supplies
Riso GR 1700 OK light will not come back on ,nor will it release
switch on the machine and press the astrex button left of the zero button. The code that comes on the display would be helpful. or you you could shoot in the dark and reset the machine by switching off holding down the 2 top right side buttons and switching on the machine. Then release the buttons and off and on with machine.
Mar 25, 2009 | Riso RZ220 Duplicator
Risograph GR 1700 E02
check the Paper Feed Tray.. is there something in the way? does it go up and down? if it is all the way up or down maybe it got pushed off the rail?
Mar 11, 2009 | Riso Office Equipment & Supplies
Paper Jams
clean with a soft cloth and alcool the Paper Sensors, specialy the paper sensor (one under the drum), and also the clean the stripper pad, Pickup roller, Scraper roller, Gide roller, Timing roller in the firts paper feed drive mechanism
If you need the manual instructions post a mail at: Salasidis@sch.gr
Feb 25, 2009 | Riso RZ220 Duplicator
Error Code T14 on Riso GR3770
The machine is not alinged. I had that code this evening and the guy came here and in no time he fixed it. is your drum going in the machine? if so then turn off the machine and while pushing down the clear/reset button turn the machine on
Oct 16, 2008 | Riso RZ220 Duplicator
301 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
