Question about Zenith A60M91W 60" Rear Projection Television
No power!! tv working excellent until the other day, turned it on at the side because remote switch doesnt work, and NOTHING no power, just the red light at side of tv,....so obviously not fust in plug,...checked fuse in tv,..its fine,...it just wont power up the tv,...one min its perfect next i cant turn it on,...please sumone help, im lost with out my tv!
jomaru
  • 337 Answers
SOURCE: No Power to TV
There is no reset button on these new sets,your set has complete power problem since you have no lights no clicks,this might have happen because of lightning or power surge,either one creates a lot of damage,if you are familiar with tv service you can check the main fuse,he should be close to where the power cord comes in,if you find the fuse blown it needs to be replaced with an exact replacement for AMPS rating and VOLTS rating as well as size,if the fuse is blown black we might have more problems ahead in the circuit and it will blow up again as sonn as you plug the tv back in,if it blows again it will need a more involved repair,the problem could be in the primary side of the power supply,if you are not too familiar you should seek the help of a servicer a least for an estimate but if you suspect power surge or lighting damage dont invest any more on this set and get a new one.
Posted on Nov 08, 2006
SOURCE: No picture
I hope youre lucky enough for that to be the only time, but mine has been doing this for over a year, getting progressively worse. As of the last 2 days, it has to sit over night b4 it will show an image again. Good luck with this B.S. tv. (Just spent $250 on new bulb last month too, had set 2 yrs. )
Posted on May 23, 2007
  • 129 Answers
SOURCE: Zenith R56W36 56..... Wont stay on
seems like aging problem , your best bet its to replace the deflection board, let me know if you need more info
Posted on Jun 10, 2007
Did this solution work? I'm having the same problem.
Posted on Jul 25, 2007
SOURCE: My tv will not turn on.
my tv does not click at all
Posted on Apr 27, 2008
The red power light comes on but nothing else works on my hitachi 53FDX01B PROJECTION TV
silly question but have you tried turning it on with the remote. if a tv has been turned off by remote and then power goes, turning it on by the tv switch will put the tv back in stand-by mode and you need to use remote.
just a suggestion.
Dec 13, 2013 | Hitachi 53FDX01B 53" Rear Projection...
The remote won't work
Is its a Sharp Remote? or a Generic
A) Check Batteries
B) If a sharp aquos remote there is a function button on the right top side - insure that TV is selected. TV led will light
C) On left side there is a red TV power button press and insure the red led on the remote lights.
D) IF Tv does not turn on then you may have a problem with
the sensor inside the tv.
Only real way of verifying it is not The Remote sensor is by trying another remote. If you have a Cable or Universal follow the instructions for a Sharp TV and try that. If it works problem is with the Sharp Remote if it doesnt its your remote sensor inside the tv.
Hope this helps.
Aug 02, 2013 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
-Plugged into wall -Red LED on -Remote and side POWER ON/OFF will not turn TV on. -unplugged and waited over night then plugged in and it worked fine until later that day. TV turned itself off. Now...
Did you ever got the solution for this problem?
I have the same, I did notice that when I lift my tv from the bottom, attached to the wall support the tv turn on by itself, weird no?
Jun 22, 2011 | Samsung LN52B530 LCD TV
I have bought an Antsig universal remote control for my Sony DVD CMT-GP8D but the 4 diget code is not in the operation book. Please help
Have you tried the manual option? Turn on your DVD player. Press "TV" or maybe a different button for DVD players, then a red light on your remote blinks once. Then hold both the "up" volume and "up" channel button down until your red light is permanently on. Then whilst holding your remote control 1mm away from your DVD player signal light (usually red too), hold down the "power" button until your dvd player switches off. Then switch it on again and try other buttons. However, I've only tried this on an LG TV, but took me 2 days until I really put the remote in front of that signal light. Took about 1 minute or more while holding down the "power" button. Hope it works =)
Jan 30, 2011 | One For All URC4110 Remote Control
Philips TV model 34PW9815/17 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt...
Philips TV model 34PW9815 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt respond to controls either on the set or the remote
May 12, 2010 | Philips 32PT81S 32" TV
No manual. How do I install (program ?) jumbo innovage.
To program your Innovage Jumbo Remote Control, you can ask it to cycle through all the codes it knows for TV's, DVD's, SAT boxes etc.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
To program for your VCR, repeat the steps starting with turning on your VCR, and substituting the VCR button for the TV button.
I hope that helps.
Jul 31, 2009 | Innovage Jumbo Remote Control
Vizio, Model P4, manufactured in 2003 -- worked fine until 5 minutes ago
I have the same tv and the same problem. The power switch in the front flashes a bunch of times, but nothing else happens. Have you had any success in getting yours fixed?
Sep 08, 2008 | V, Inc. Vizio P4 Plasma Television
Programming my remote to control the sound on my TV
Here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
Jul 24, 2008 | DISH Network IR Remote Control
Dish network remote
i would suggest trying power scan again...
3)press pound sign
if this doesnt work try addressing your old remote to the receiver by pressing record from system info screen
Jul 06, 2008 | DISH Network IR Remote Control
LG 37LC7D remote doesn't work
 I heard that Best Buy is still selling these models despite this known problem- I am trying to have mione fixed but was told the replacement part is on back order until DECEMBER!
Sep 06, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
