Question about Vtech VT-300ATX 300-Watt ATX Power Supply (vt300atx) 165-Watt Power Supply
No power on my VT-300ATX powersupply
Power supply has no power output. I inputed 120AC but power supply is not turn on at all.
  • 624 Answers
If you're trying to just plug in the wall power cablem without connecting the motherboard it will not work. Switching power supplies need to detect a load (device) otherwise they will not put out power. Safety feature.....
Posted on Apr 05, 2007
The power is on..but if i switch on..can;t start,,
Posted on Apr 27, 2009
D-link router (with 1 antenna and no modem) that has no power and no LEDs lit. the outlet still works to charge a cellphone. how do we fix the router?
Possibly the powersupply for the router is dead. Find another powersupply with same voltage output to try OR test the output tip with a meter. If the power supply does work then your router is dead. Replace it. If there is no power (5 volts or 12 volts etc) coming from the tip of the power supply adaptor then replace the adaptor / power supply.
Apr 28, 2013 | Computers & Internet
I have a KDL52s5100 it is not working(no lights, dose not t turn on) due to a thunderstorm. I have bought 2 powersupply board and a new main board and still nothing turns on no even a light.. please help....
make sure that all the voltages in the power supply output are present before connecting to the control motherboard. also confirm that the cables supplying the voltages to the motherboard are all matching e.g do not make a mistake to connect the 3.3v cable to the 12v terninal. just be cautios and your system will power up
Sep 21, 2011 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
How can I tell if my VT-300ATX power supply is bad?
Short black and green wire the smps fan will start ,For details click bellow the link,
http://www.playtool.com/pages/psuconnectors/connectors.html#4into8
Let me know if you need more information
Thanks
Feb 07, 2011 | Vtech VT-300ATX 300-Watt ATX Power Supply...
I have an old SPX90 Digial Reverb with a dead powersupply. The part number on the board is VA81400. Is this part number correct? Is the part still available? We tried ordering it from the Yahama dealer,...
Any power supply will do as long as it has the same specs as the dead one, which will be:
Input : x Volts AC
Output: x Volts AC or DC
Watts: x
Amps: in millamps
Polarity: (for power supply with DC output only) Center pin = plus or Center pin = minus
You should be able to find the matching transformer/adapter/power supply at Radio Shack.
More info, let me know.
Charlie
P.S. The power supply you received may be the correct one -- check to see if the specs match the old one.
Aug 29, 2009 | Audio Players & Recorders
Scanjet 4300C
Hope this helps, but there's no specific model number, but here's a description:
Round barrel connecter with a positive center. Voltage regulator, power supply, powersupply, inverter, adaptor, adapter, transformer INPUT: AC 100V and OUTPUT: +12VDC/1.25A (12 Volt 1250mA)
And, a photo:
Aug 25, 2009 | Office Equipment & Supplies
Siren digital picture frame wont turn on
I had to fix my boss's digital photo frame today and it looks like it was a power supply issue. All i did to fix it was connect a usb cable AND the powersupply. The frame turned on right away. The power supply may not be able to output enough juice for powering up the frame.
Jul 02, 2009 | Siren Audio Players & Recorders
Power supply 4 logitech momo wheel force
powersupply for logitech momo. is
Logitech Ac adapter P/N: 190211-a110 Model: ADP-18LB
Input Ac 200-240
output: 24v --- 0.75A
Note this is the europe version.
Oct 12, 2008 | Logitech 963339-0403 (9633390403) Wheel...
Can anyone tell me if the 12 volt powersupply is 12 volt AC or DC ?
Model HER-48-12010
P/N: 68300021-0013
AC Input
DC Output
Sep 20, 2008 | Compaq S 200 Flatbed Scanner
Powersupply
first you switch on the supply by shorting (green and black )wire in output socket of smps.then check output voltages.If there is no voltage then check switching transistors or protection transistos that is placed on first hit sink.check primary bridge and capacitors for open.
May 24, 2008 | Dell NPS-110AB (NPS110AB) 110-Watt Power...
JVC TV- MODEL AV-K21T.
it was not necessry to replace so many parts if you go as per proper procedure.please proceed as 1 isolate horizontal output section from power supply & make power supply ok. 2 if it becomes ok check hor osc,driver&h/output section. 3 if it is ok connect power input to hor.section which was isolated. 4 check for loose contact or print. 5 put on tv .
Sep 22, 2007 | Televison & Video
Vtech VT-300ATX 300-Watt ATX Power Supply (vt300atx) 165-Watt Power Supply Logo
225 people viewed this question
Top Vtech Computers & Internet Experts
iphone4
Level 1 Expert
Tom Chichester
Bill Boyd
Are you a Vtech Computer and Internet Expert? Answer questions, earn points and help others
