Question about HP Photosmart C6280 Printer
Doesn't print from PC
Like is always looking for photo paper is causing "paper jam" taking sheet from the lower tray. Is there where is shown choice "print from PC", All I can see is asking for a card.
  • stefka_cragg Dec 23, 2008
    I have solved via HP Customer Service as it was brand new printer. Thank everybody for trying.
  • 700 Answers
Yes you need to open up the hp imigaing monitor and cloick on the corect button for what you want to do. Thanks for using Fixya.
Posted on Dec 23, 2008
Can't print pictures from my laptop. The printer always says paper jam but there isn't one
"Paper Jam" issues are common with printers. They most often occur right after there has been a paper jam. Most people (not necessarily YOU), don't take the time to read how to properly clear a paper jam in their printers and often yank the jammed sheets backward thru the paper tray. Most times you should remove the cover in the back and pull the jam FORWARD out the rear, or if the jam made it close to the output tray, then FORWARD thru to the output tray. Pull sheets backward can cause two issues. It makes tearing the paper easier. This can result in tiny pieces being caught in places where the printer detect them as a jam. The other issue is that pulling backward can damage the feed rollers that pull the paper into the machine, as well as the mechanical sensors that detect paper jams. If you cannot find ANY shards of paper in the machine, you may have printer damage that results in the jam indication.
Oct 10, 2015 | HP Computers & Internet
I have an epson printer and when I hit print, the paper slides right thru & says paper jam
  • Carefully remove the jammed photo paper. Gently pull the paper up and out of the paper feeder tray.
  • 2
    Reload the paper into the tray. Stack the paper on a flat surface and then carefully slide the paper stack straight into the paper feeder tray---along and aligned with the right side of the tray. Secure the stack in place by sliding the left "edge guide" against the paper stack.
  • Sponsored Links
  • 3
    Press the "OK" button to resume printing. If you had a "Paper is jammed in the printer..." error message displayed on the control panel LCD, pressing "OK" should also clear the message.
  • 4
    Pull the paper from the printer, if the status message reappears and/or the printer doesn't print, and check the paper for folds, buckling and curled edges or corners. Also check the sheets for sticking. If any of your sheets stick or have damage, remove them from your photo paper stack and replace with new sheets. Reload the paper and press "OK" to try again.
  • Performance Chip
    May 22, 2012 | Epson NX415 All-In-One Printer
    How do i clear a paper jam
    1. 1
    Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
    2. Step 2
    Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
    3. Step 3
    Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
    4. Step 4
    Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
    5. Step 5
    Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
    6. Step 6
    Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
    7. Step 7
    Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
    May 04, 2010 | Dell Photo 964 All-In-One InkJet Printer
    Paer prints half the PAGER AND THEN JAMS ... I
    The paper must be hitting something to cause it to jam. Take the drum/toner cart out also the paper tray. Unplug it and hold it upside down and see if something shakes out. Do not do this over carpet. If that does not do try a test page. look at the leading edge for dings and bends. If you find a bent spot on the leading edge thats where the problem is. Its almost always a small piece of paper Steven 818-888-0006
    Mar 08, 2010 | Dell 1710n Laser Printer
    Epson Stylus photo 340 r printer paper jam when trying to print
    first, make sure you the paper correctly to avoid paper jam.
    Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
    if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
    Feb 09, 2010 | Epson Office Equipment & Supplies
    PAPER JAMMED-PRINTER HL5150D
    Hello a_bowen1
    You can clear the jammed paper as follows.
    If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
    If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
    Note
      • If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
      • Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and reduces paper jams.
    1. Pull the paper tray completely out of the printer.
    1. Pull the jammed paper up and out of the printer.
    1. Press the cover release button and then open the front cover.
    1. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
    hl50_05712.gif Caution
      To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
    1. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
    Note
      If you have to pull the paper toward the back of the printer, the fuser may get dirty with toner powder and it may scatter on the next few printouts. Print a few copies of the test page until the scattering of toner stops.
    chap0615.gif Caution
      After you have just used the printer, some internal parts of the printer are extremely hot! Wait for the printer to cool down before you touch the internal parts of the printer.
    1. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
    1. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
    1. Pull the Duplex Tray completly out of the printer.
    1. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
    1. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
      Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
    hl50_047.gif Caution
      To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
      If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
    1. Put the drum unit assembly back in the printer.
    1. Put the paper tray in the printer.
    1. Close the front cover.
    Good Luck and don't forget to leave a rating based on my solution:
    Mark
    Apr 04, 2009 | Brother HL 5150D Laser Printer
    PAPER JAM ERROR 201.02
    if you are gettiing a 201 error without any paper in the printer you will need change the main motor drive if it fails to initialize this is the error that will show up and there is no other way to reset it
    Mar 20, 2009 | Lexmark T640 Laser Printer
    When printing paper continues to jam.
    1. Take out paper tray 1.
    2. Remove any jammed sheets of paper you find there.
    3. Once you have done this, reinstall the paper tray and try printing again.
      Note: You may receive a message informing you that another sheet of paper is jammed elsewhere in the printer. If so, please open the front door and remove the toner cartridge. Also open the rear door of the printer (and the duplex option if a duplex unit is installed). Remove any and all jammed sheets of paper you find. Then try printing again.
    4. If the printer jams again with a 241 Paper Jam error message, look to see if it has tried to feed a sheet of paper out of the tray.
    Dec 16, 2008 | Office Equipment & Supplies
    Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
    Hope this helps....
    Explanation of the paper jam message
    A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
    NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
    Clearing the jam
    To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
    Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
    NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
    For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
    NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
    Remove any jammed sheets of paper you find and try printing again.
    Dec 12, 2008 | Lexmark T640 Laser Printer
    RECURRING PAPER JAM - BROTHER MFC 5860 CN
    I just bought the 5860 and have this issue right out of the gates. I discovered that the back lid causes the paper jam when using the bottom tray while examing with a flash light during a print job. I dislodged the back plate/lid (same lid you remove to pull paper jam out) out about 10mm and fastened the lid loosely to the back with a piece of tape on each side. The paper from the bottom tray does not slam against the back of the printer any more, thus more freedom of movement and no jams. Just successfully printed an 80 page document. You shouldn't have to do this with a new printer but I got it so cheap with all the rebates that I'm going to keep it and live with this fix. To sum up, the problem is a design flaw where the removable back plate is snapped in too tightly and contacts the bottom tray paper roller (& paper) during a print cycle. To fix you need to clear the path by pulling the back lid out slightly and taping each side with scotch tape to 'suspend'the back plate out about 10mm.a5999d3.jpg
    Feb 02, 2008 | Office Equipment & Supplies
    HP Photosmart C6280 Printer Logo
    78 people viewed this question
    Seeker5211
    Seeker5211
