The pilot light is lit to light the main burner. First off, is your pilot light lit or is the igniter lit. There are two thermal sensor in the oven. One is above your pilot light and will not let the pilot light stay lit unless there is a flame. Secondly, you have a thermal sensor in your oven wired all the way to the switch to turn the oven on. If it thinks that it is at temp, then it will never turn on. This sensor may become bad or the case of my oven break. But if these are good, you many have a clogged burning unit underneath. Cleaning according to the owners manual may correct that. Check your owners manual to see what is user serviceable. Gas is nothing to play with.
Was this helpful?
Yes
No
Popular Solutions for GE Profile Spectra JGBP90 Gas
5 yr old pie wont get done ckd with thermometer and 50 degrees cooler than what was set. how do u...
(More)
5 yr old pie wont get done ckd with thermometer and 50 degrees cooler than what was set. how do u recalibrate oven temp?
gas oven does not light right away resulting in a strong gas odor and causing it to bang when it...
(More)
gas oven does not light right away resulting in a strong gas odor and causing it to bang when it does light
