Question about Hitachi 57F510 57" Rear Projection HDTV-Ready Television
Wireless head set connection
How can I connect a wireless head set to my Hitachi 57F510?
  • hancle Dec 25, 2008
    A call to Hitachi disclosed that while there is a pair of Audio out jacks, they wont work because the et is hooked up to Home Theater System using HDMI jacks.
  • Hitachi Master
  • 5,569 Answers
Your set surely has some kind of audio output in the rear if not under a front panel.
It could be in several different forms; very common is a left/right set of (RCA type) jacks color coded red (right) and white (left).
It could also be a 'Line out' jack that supplies a standardized level for use with an external audio system; this one is probably the best choice for your useage. You may have to buy an adaptor cable to connect the two devices.
Posted on Dec 21, 2008
Firmware update for Hitachi 51F59 51 in. HDTV Television
You need to set up the wireless internet connection in the TV to connect to a wireless router and then the TV will download the firmware update over the internet.
Dec 17, 2012 | Hitachi 51F59 51" HDTV Projection...
I have a red X on screen of my Hitachi 57f510 HD tv. What does that mean?
It may have to do with the Magic focus if that model has it: auto convergence and if fails a indication can appear on screen. The Magic focus if in play would be a flashing sequence moving to different areas of the screen in sequence.
Dec 09, 2012 | Hitachi 57F510 57" Rear Projection...
How do i connect my nintendo dsi system to the internet?
Hi there!
If you wanted to connect your Nintendo DSI to your wireless connection, just follow the following steps:
  1. Access the system settings while the Nintendo DSi is turned on
  2. Go to the third page and you will find there "Internet"
  3. Choose connection settings from the menu
  4. Click "none" for Connection 1
  5. Click on "Search for Access point"
  6. Your Nintendo DSi will search the available wireless connection in the area and your wireless should be listed.
  7. If you are using a secured wireless, you will be ask to enter the wireless key
  8. Once done, click on OK, Save Settings then Yes
  9. It will do a connection test and it will show if the test is successful or not.
If you want a video tutorial, just head to this website: Nintendo DSi Internet Connection Guide.
Hope this helps.
May 19, 2011 | Nintendo Dsi Pink Console
Can i connect the 57f510 to a pc?
yes if you have a blue vga input on your tv. or if you have an hdmi output on your computer. also please eleborate if you wanna run this as duel screen or not if so i can give you step by step directions on how to get this to work
Mar 19, 2011 | Hitachi 57F510 57" Rear Projection...
I have a Hitachi 57" projection TV Model 57F510.
You may well have either poor contact on the tube base of the colour that is missing or a poor contact in the tube itself. The latter is not repairable.
Dec 31, 2010 | Hitachi 57F510 57" Rear Projection...
Cannot connect to wireless internet
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Please follow this steps carefully
Turn on your internal wireless card?
If your wireless card is built in to your computer, there may be a switch on computer that turns the card off and on. When new from the store, these switches are often in the "off" position. They can also accidentally get switched off during use. Find the switch (often near a symbol that looks like a microphone or radio tower emitting radio signals), and turn it on. The card should now find wireless networks in the area and connect.
Find the scrldcolville network?
If your wireless device is properly installed, your computer should automatically start scanning for networks in the area and will inform you that there are wireless networks present. If not, you can scan for networks in the area manually.
*To bring up the Wireless Network Connections menu, go to the Start Menu (in the lower left-hand corner of your screen, choose "Settings," then chose "Network Connections," and finally, choose "Wireless Network Connection." Clicking on this option in the menu should bring up a window. In the upper left hand corner of the window under the heading of "Network Tasks" there should be an option that says "Refresh Network List." Click on this option to search for wireless connections. Choose scrldcolville, hit the "Connect" button in the lower right hand corner and enter the passkey to connect.
Enter the passkey correctly?
If the passkey is entered incorrectly, the computer will appear to connect to the internet, but will not actually connect. If you think you may have entered the passkey incorrectly, disconnect from the scrldcolville network (see steps above in #5) and then reconnect. Often, as you manually reconnect to the network, the computer will remember the passkey and a small window will pop up, showing the password as a line of dots. Re-enter the passkey correctly before connecting.
(#6, cont.): Sometimes, your computer will not allow you the option of re-entering the passkey when you reconnect to the network. If this happens, bring up the Wireless Network Connections menu. Click on the "Change advanced settings" option under the "Related Tasks" heading. Another window saying "Wireless Network Connection Properties" should pop up. Click on the "Wireless Networks" tab at the top of the window. Under the "Preferred Networks" heading, there is a box that lists all wireless connections your computer has ever used. Click on the scrldcolville network to select it. Now hit the "Remove" button just below the box, then hit the "Ok" button. This will make your computer forget the scrldcolville network and the bad passkey. Bring up the Wireless Network Connections menu again and connect to scrldcolville .Be sure to enter the passkey correctly.
Allow your computer to obtain an IP address automatically?
Be sure that your computer is set to obtain IP addresses automatically and that it does not have one assigned manually. To do this, bring up the Wireless Networks Connections menu .Click on the "Properties" button. Here, you will see a list under the heading "This connection uses the following items." Scroll down the list until you see an item named "Internet Protocol (TCP/IP)." Select this item and hit the "Properties" button just below the list. This will bring up a new window. In order to connect with the library's wireless device, you must have the option "Obtain an IP Address Automatically" selected (ditto for the DNS server address). If you are set with a manual IP address, you can click the button to obtain your IP address automatically (ditto for the DNS server address.) Be aware that this changes how your computer interacts with other networks. If you need a static IP address on other networks, you may have to reset your IP address again later. However, your computer cannot connect to the library's wireless network unless it obtains its IP address automatically from the library's wireless device.
Make the Windows wireless configuration your default configuration?
In many computers, Windows acts as the default wireless network configuration program. However, if you have an external wireless card, or if your computer has a secondary program enabling it to connect to the wireless network, you may discover Windows will not recognize your wireless connection program and visa versa. Sometimes, if you have a non-Windows program that runs your wireless card (for example, a Linksys driver for an external Linksys wireless card), the non-Windows program will connect to the wireless device, but Windows will not recognize that this secondary program has connected. You will need to allow Windows to control the wireless configuration in order for your computer to fully recognize the wireless connection. On way to solve this problem is to tell the secondary program to "stand down," as it were.
On some computers, an icon for your secondary wireless program will appear in the lower right-hand corner of the taskbar on your desktop. You can click on this icon to open the program options. Certain programs will give you the option to switch to Windows as the default manager of your wireless connection. This will allow you to use the Windows Wireless Network Connections menu to make changes to your wireless connection.
May 04, 2010 | ASUS Eee PC 900HD Netbook
Can I replace the screen on a hitachi 57f510 myself?
You can find a new OEM Hitachi replacement lenticular screen and Fresnal screen (availble together as the screen assembly) for a model # 57F510 from a major Hitachi distributor at the following links:
Hitachi 57F510 Replacement Part Screen Assembly (Fresnal Screen w/ Lenticular Screen)
And here's a link for the protection screen if needed:
Hitachi 57F510 Replacement Part Protection Screen / Super Shield
You should be able to replace it yourself with basic electrical knowledge.
Apr 13, 2009 | Hitachi 57F510 57" Rear Projection...
Wireless Adaptor Issue
First make sure that your wireless router is set to broadcast (or if you prefer not to broadcast) your SSID (your wireless network name) or that your laptop wireless network connection properties is set-up to "Connect even if this network is not broadcasting".
To check this go to:
Click Start> Connect to>Show all connections>
Right click your Wireless Connection and select properties>
On the Properties box select "Wireless Network" tab >
Go to "Preferred networks" then highlight your SSID (network name)
Click "properties" button check "connect even if this network is not broadcasting". (while youre here check that your "Wireless network key" confgurations are correct).
Make sure that you are also set-up to "Obtain an IP Address automatically " and "Obtain DNS server address automatically"
To check:
Select "General" and under the heading "This connection uses the following items">
Highlight "Internet Protocol (TCP/IP) then click "Properties" button
Jan 10, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Unable to go online
I want to tell you that before making wireless connection you have to ensure that are you able to go online with the netgear router using wired connection if yes i will provide steps to configure wireless on the router.
WIRELESS SETTINGS, you can follow directly to solve teh wireless part of the router :
Once its done follow the same steps to make you wired connection working. Once its done, Lets move on to the wireless connection
a. click on the wireless settings under the heading of setup
check out another screen shot below :
a. Change Name SSID : name of your network that you want to have
b. CHANNEL : Change to 11 and if uts 11 change it to 06
c. Mode : change to G&b
d. Sceurity : Select WEP
e. Key1 ; type any 10 digit number or you can type 1020304050, as mention above as the password for your wireless network
Till now we have set up the wired connection and wireless connection on router and now lets connect your wireless computer with it
you will able to see your wireless network name on your computer, simply select it and it will prompt you for password that will be your 10 digit number you punch in Key1
connect with it and you are ready to go with your wired and wireless connection
I believe these steps help you to resolve your problem
Thanks & Regards.
Jaspreet Singh Saini
Jan 10, 2009 | NetGear WGR614 Wireless Router
HITACHI MODEL 57F510 PROJECTION TV
had 57f510, not working. i need your help. I turn it on and led light come on and disappear and nothing shown. what should i do?
Nov 19, 2008 | Hitachi 57F510 57" Rear Projection...
Hitachi 57F510 57" Rear Projection HDTV-Ready Television Logo
41 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
