Question about Intertherm P3RA-048K Air Conditioner
Furnace won't stay on
My intertherm furnace has been working very well until just lately. I woke up one morning and the it was 61 degrees in my home but my thermestate was set for 68 degrees. I noticed that my furnace would still blow out warm air but only for 20 to 30 seconds before stopping and then starting again. The furnace would run again and then the fan would run again for the same amount of time...and so on.. Basicly it wouldnt stay blowing long enough to raise the tempature.....
  • 306 Answers
Flame sensor could be dirty. It is located right beside the last burner looks like a thick piece of wire. Take steel wool and gently clean the probe 4 or 5 strokes is all it will take to take off the carbon build up off. Lets eliminate this item and see if it clears up okay. ken
Posted on Dec 21, 2008
INTERTHERM NO HEAT OR BLOWER
This could be failure of the igniter and/or thermocouple.
Jan 27, 2014 | Intertherm 56000 Btu Gas Furnace
Vanderhoof BC Canada
http://www.intertherm.net/DealerServiceLocator.aspx
Jan 08, 2014 | Intertherm 56000 Btu Gas Furnace
Intertherm feh 015ha
either the heat strips, fusible links on elements or sequencers.
Sep 21, 2013 | Intertherm E3EB010H Electric Furnac
Intertherm furnace burner comes on, but blower does not. If I turn thermostat off then back on until it clicks the fan will then come on. It does not do this all of the time, just now and then.
Furnace burner and heat element are not the same. I think the fan time delay, a sensor that turns the fan on when this sensor senses heat, is shot and needs replacing, for a furnace type heat ( gas heat)
Aug 08, 2017 | Intertherm E3EB010H Electric Furnac
Intertherm oil furnace in mobile home installed 3.5 years ago. Worked great until the Igniter transformer shorted out 1.5 years ago. When technican changed the transformer he also changed the burner...
hello,The 90* nozzle is usally installed in miller brand units because of the "short" chamber.The 90* should not cause soot.Soot = not enough primary AIR into the burner mix.If the unit mfg. wants .50/80*a it should be used.#559 might translate into a .65gph input thus overfiring the unit.If a .50gph is installed the AIR mix problem will take care of itself (less fuel).Soot is unacceptable in your (young)3.5yrs unit and should NEVER have soot at all.The problem started when the nozzle was replaced try (insist) on mfg spec. nozzle.
Nov 08, 2010 | Intertherm Heating & Cooling
The furnace is blowing warm air even if the thermostat low.
The only thing that tells the unit to come on and off is the thermostat so I would definatly say it is it. When you turn the system back on, does the a/c run normally? If it does, then it's the problem with the heating side of the tstat. Also, does the fan come on when you put it to on and then turn of when you switch it back to auto? If it does, then the system is working fine, its the t-stat. Let me know if you have any more problems.
Mar 23, 2009 | Intertherm P3RA-048K Air Conditioner
Ruud air to air heatpump intertherm propane furnace honeywell th5220d non programable thermostate.fan on furnace will not turn off in aux.mode even though the furnace heat kicks on and off. thank you for...
Make sure fan relay is wired correctly (G) wire. Ensure the fan on therm is not on, it should be on Auto or off.
If your furnace is short cycling because it has to keep heating your home, the delay in the control board may be staying on to compensate for the exchangers getting hot. If it heats normally, then put your attention to your thermostat.
Set the heating system on aux heat only. Fan should not be on, if it does stay on after a heating cycle, see if the furnace is heating normally, and reaching temp as desired before the heat comes off. Then check the therm wiring, pull the face of the therm, disconnect green wire (fan) and try the heating again.
Dec 06, 2008 | Intertherm Heating & Cooling
Intertherm P3RA-048K Air Conditioner Logo
1,532 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
