Have a Quasar 27" tv Model #SP3233B. It started a few weeks ago with my picture screen shaking. Then sometimes I would get a thin silver horizontal line across the middle of the screen. Now I keep losing picture but have sound. When I turn it on there is no picture just a black screen with sound.
  • Televison & ... Master
  • 2,075 Answers
I'd suggest to bring it to repair shop if you're not technically literate
Posted on Jan 25, 2018
Basti
  • 1447 Answers
SOURCE: Panasonic 27 inch TV Model CT-2701G built 9/2003
Hi-
Try removing and reinstalling the cables from the back of your TV.
Keep us posted, thanks for using Fixya!
Posted on Jul 14, 2008
SOURCE: Thin red horizontal lines appear when viewing a dark background
Look around this sight the answer is explained here. you hace to take off the front speaker cover and a small panal undder it. you will find six knobs on a small panal. use these to adjust the settings fotr the power and they will remove the lines. You will need to have the tv on and I would sugest a normal size phillips head screwdriver not a power tool.
Posted on Jul 30, 2008
  • 927 Answers
SOURCE: Many thin black horizontal lines on my Hitachi Ultravision 50" TV
Good Day, LDS also;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Posted on Sep 06, 2008
  • 31 Answers
SOURCE: Black line across screen
module problem take it to a Authorized dealer or a NESDA dealer service manuals hard to say if available since analog TVs are slowly going away and parts well another story might as well go buy a new HDTV set as a CET no garuntee how long it will be analog TV parts will be discontinued. FCC has alot to do with it.
Posted on Apr 16, 2009
SOURCE: horizontal lines across middle of screen sometimes
Vertical problem coming from bad solder, or vertical circuit problems!!!
Check for bad solder and capacitors problems in vertical circuit.
Posted on Aug 30, 2009
Vizio VO370M LCD TV screen is mostly black with green/blue horizontal stripes at the to. How can I fix this?
Most likely you are looking at a defective LCD panel, but I would recommend getting a proper diagnosis.
Sep 07, 2012 | Vizio VO370M LCD TV
Need manual for Quasar TV model SP3233B made 2000
  • Hi, I can help.
  • When you get to the link click on"Click here to start download from MediaFire.." and tha manual will download onto your computer.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 26, 2011 | Quasar SP-3235 32" TV
Quasar 20yr old color tv sound but no picture, is it repairable
try adjust screen up, in you see horizontal line in bottom, the tv have the vertical ic with cold solder or bad.
Apr 20, 2010 | Quasar SP-2723 27" TV
Horizontal lines at the top of the t.v. screen.
you will have to find fault in vertical deflection try condencer replacement in that stage
Jul 11, 2009 | Philips 27PT6441 27" TV
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Skyassoc
Jun 23, 2009 | Toshiba 36A40 36" TV
Thin horizontal line across the screen
you need to replace the electrolytic capacitor in the horizontal section of of your tv sets,cause the capacitor is weak.need to repair
Jan 11, 2009 | Sharp 27C-240 27" TV
Vv 1220 screen shakes
Probable bad electrolytic capacitor in vertical circuit.....T.
To get more help from different experts, list your tv in the correct catogory....
All products>Quasar>VV-1220 Standard Television>
Oct 24, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Picture is now a thin horizontal line
now only visible in a thin horizontal line. first of all you reduce brightness to monimum. it just to protect your tv from crt demage. your problem is in horizontal output section as you have mentioned that week or so ago the right and left bottom edges of the picture began to move in like a sideways triangle filled with black so this sympton is due to hor. section problem. your flyback transformer or horizontal output might be defective. but remember check for power supply is ok from surge protector hope this will help.
Oct 07, 2007 | Hitachi 35UX80B 35" TV
Quasar sp2722 27 tv
you have an intermittent vertical ic or caps . it will need service sorry usually it's not to expensive werepair these all the time
Apr 01, 2007 | Quasar SP-2723 27" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
