Question about Rio Carbon MP3 Player
How do I access the EQ section on my Rio Carbon Pearl 5 gig to change the equalizer settings?
  • 51 Answers
i found the following solution:
1 Press MENU.
2 Select Settings.
3 Select Equalizer.
For more specific information follow the following link, its a manual. It answers you question on page 31.
http://www.rioaudio.com/support/rio/downloads/Carbon/RioCarbonPlaysForSure.pdf
Good luck
Posted on Dec 21, 2008
When I transfer music from Rio Music manager to my Rio Carbon the music manager indicates transfer successful but the MP3 player states no tracks present?
Try to transfer the tracks from the explorer.
1 Connect the Rio Carbon to a computer using the supplied USB cable.
2 Double-click My Computer on the Windows Desktop or in the Start Menu.
3 Locate MP3 or WMA audio files on the computer.
4 Highlight files and/or folders to transfer to the Rio Carbon.
5 Click Edit.
6 Click Copy.
7 Double-click My Computer on the Windows Desktop or in the Start Menu to open another window.
8 In the new window, locate the Rio Carbon (X:) icon that is associated with the Rio Carbon. (X equals the drive
letter assigned to the Rio Carbon.)
9 Double-click Rio Carbon (X:).
10Click Edit.
11Click Paste.
May 24, 2010 | Rio Carbon MP3 Player
Rio carbon 5 gig mp3
The Rio Carbon will not play songs from iTunes unless they are in mp3 format. If you cannot download the songs in this format then I would recommend a program such as mediacoder to convert the tracks. I don't know why iTunes was recommended for the Rio but I would just use drag and drop into the folder called Music on your Rio.
Hope this helps,
Mowcius
Oct 17, 2008 | Rio Carbon MP3 Player
EQ of two channels
The microphone input goes through the same equalization path as input 2: determined by blowing on the mike and hearing a change in speaker sound with changing high band EQ
Jun 09, 2008 | Audio Players & Recorders
Carbon Pearl: Invalid Argument
Try accessing the rio's hard drive through my computer to see if it can find the songs: they will be in a folder aptly called music within your rio carbon.
If this doesn't help then if it is picked up via my computer you could try wiping and rebooting your rio, read:
http://www.fixya.com/support/r601327-wipe_reboot_rio_carbon
You may have to change the firmware for the rio carbon pearl but this is easy to find on their website.
Hope this helps,
Mowcius
May 22, 2008 | Rio Carbon MP3 Player
Opening the Rio Carbon to replace the volume button
The easiest and least damaging way to open the Rio Carbon is to start at the bottom of the player and pry it open a little until you can see the tabs. You have to push those to release them. Work you way around clockwise and there are tab a little further into the player, you have to pull the bottom of those out to release them. I did it last night and was able to repair the volume wheel and get the player back together and it works.
Mar 29, 2008 | Rio Carbon MP3 Player
Tranfer from player to computer?
Go to Main Menu -> Settings -> Advanced -> Transfer Mode and select MSC. Worked for me.
Nov 18, 2007 | Rio CE2100 MP3 Player
Rio carbon pearl 6 gb
in general, it means converting to the newest industry-standard. in the case of your device, it means flashing (re-programming) the micro or increasing memory size
May 27, 2007 | Rio Carbon MP3 Player
Transferring music to new pc
You must use the music transfer software that came with the CD (also avail on Rio website) - which will not load on newer, Vista running computers.
May 03, 2007 | Rio Carbon MP3 Player
Rio Carbon 5 g
When Microsoft initiated the DRM system, any Rio Carbon that was hooked into Windows Media Player had the previously working files invalidated. Happened to me as well. The player lasted me three years, and that is about as long as any Mp3 player is going to last we are finding out b/c of all the software snafus.
Jan 09, 2007 | Rio Carbon MP3 Player
Rio pearl directory corrupted
first, and this is always good: If available, firmware for the Rio Carbon can be downloaded online. Second, this might be the problem: The Rio Carbon communicates with your computer differently in MTP mode than it does in MSC mode. When in MTP mode, the Rio Carbon cannot display hidden files in folders, cannot allow transfers to the root Rio Carbon directory, and cannot allow the creation of new folders. (Folders can be transferred to the Rio Carbon using drag-and-drop and copy-and-paste methods.) To use traditional folder options, change the Transfer Mode settings to put the Rio Carbon in MSC mode. Last, "..Removing the Rio Carbon from a USB connection before Idle is displayed on the screen may result in a corrupting the player's file system. If for any reason you suspect that your Rio player's file system has been corrupted, reformatting the player will restore the file system to its original state..."
Nov 27, 2005 | Rio Carbon MP3 Player
Rio Carbon MP3 Player Logo
87 people viewed this question
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
