Question about Gigabyte Giga-Byte: GA-8I865GM-775 LGA775/865G/FSB800/DDR400/MATX Motherboard (MOTGB15)
When i turn on the computer it doesn't start at all. it doesn't show video and even no beeb it's hear it. what could be the prolem?
  • 45 Answers
Reseat RAM, CMOS, re-boot.
Posted on Dec 21, 2008
My CPU is on but no display in the monitor.
may be your video card is broken.. try to barrow a monitor from your friend or relatives and test if the problem is in your monitor or video card..
Apr 18, 2011 | Computers & Internet
My dv6000 dont start . i have black screen with one long beeb and two short beebs
HI friend,
one long beeb and two short beebs Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information,some couse of that issue is New hardware conflicting with old hardware or New hardware conflicting with old hardware or Connections not connected or connected properly or other hardware issue.Best solution is
If any new hardware has been recently added to the computer, remove that hardware to make sure it is not the cause of your issue. If after removing the new hardware your computer works it's likely the computer is either not compatible with the new hardware or a system setting needs to be changed to work with the new hardware device.Remove any disks, CD's, DVD's that are in the computer and if any USB devices (ipods, drives, phones, etc)
before all that please
Make sure all fans are running in the computer. If a fan has failed (especially the fan for the CPU) your computer could be overheating and/or detecting the fan failure causing the computer not to boot.
If you continue to to receive the same problem with all the above hardware removed attempt to disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue.
  1. Re-insert the memory into the same slot.
  2. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick.
  3. Try one stick of memory in each slot.
Thanks,
Please rate me.......
Apr 04, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
My chevrolet 2003 tahoe want start it turns over but want start the batery is good fuel system it think
if battery good starters good that still leaves fuel,air,spark or timing you could try disconnecting throttle body hose that comes from the air filter try starting if still no start spray throttle body cleaner in the throttle while someone starts. Do you hear the fuel pump coming on when turning key to the on position. Have you checked to see if it is getting fire to the plugs?
Mar 18, 2010 | 2003 Chevrolet Tahoe
I hear some beebs sound in mobo WB72 revA1. but no
http://www.5starsupport.com/info/beep_codes.htm
here you will find some info about the beep codes and what it means...
Jan 31, 2010 | Computers & Internet
Plugged it into my computer, now wont even turn on!
HI,
TURN IT ON WHILE ITS CHARGING WITH COMPUTER,SOME TIME THERE WILL BE STROKING ON PROLEM..
TNKS
RABBANEES
Nov 04, 2009 | Pure Digital Flip Video Ultra Camcorder
My monitor is working but nothing shows up. when I turn computer on I here three beebs a 10 sec pause three more beebs and so on whats the problem. motherboard is a ECS P4VMM2 V5.X that I rehooked up
The 3 beep error code means there is a prolem with the RAM, it could be faulty or needs reseating.
Try reseating the RAM and if this doesn't work then if you have more than one RAM module insert one at a time to determine which is the faulty RAM module.
OR take the RAM modules to your friendly computer shop to test them for you.
Aug 24, 2009 | Computers & Internet
Start up menu not coming on. no games loading
hold the power button down for 5 sec flipping the on off button on the back when it comes back on you will hear beebs and the blue light will flash it is reseting the system and it should wrk. GL.
May 19, 2009 | Sony Playstation 3 (PS3) Console
Start-Up Problems
it means you have a corrupted hdd.try replacing it and it should work properly
Dec 16, 2008 | Sony Playstation 3 (PS3) Console
CPU Hung
Hello Wolf, It sounds to me like the processor fan is not working correctly. When you put a load on the processor like programs, movies or games, it overheats and hangs up. Try taking a fan, and with the side removed from your case, have the fan blowing into the case, and try a movie or a game. If it does not hang up, replace the processor cooler and fan. Please let us know how it works for you, and if we can help you in any other way. Best regards, nightdiver
Oct 08, 2006 | Intel Celeron, 1.8 GHz Processor
Computers & Internet Logo
89 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
