Question about Dryers
Doesn't start and cannot turn drum with hand
Starter hums but will not turn drum. my guess is that something is impeding the dryer drum from turning. I am trying to figure out how to open the dryer to check and see if something is keeping the dryer from turning
  • 3,463 Answers
Although Maytag dryers are not one of my specialities, I am inclined to think that your problem is being caused by the start capacitor, which I am sure is fitted to m
Posted on Dec 21, 2008
  • Barry Coates
    Barry Coates Dec 21, 2008
    Hi I am back again,I pressed the wrong key before I could complete my solution, as I was saying,a start capacitor is fitted to the dryer which gives the motor a boost so to speak to get it going,.
    It is usually found adjacent to the motor, and is a round cylindrical tube about 4" to 6" long, usually plastic.
    It is has a capacitance rating in microfarads,,so it is important that you fit one of the same rating..
    all of the symptoms you describe suggest to me that this is the cause of your problem.
    I will be very interested to know if this solves your prob, so please feel free to leave comment
    Thanks, and merry xmas.
KEYS750LQ0 dryer doesn't start it just hums when I push start
Check the belt. You may have to open the machine up to look. if the belt is ok turn the drum by hand and see if the motor pulley is also turning. While you are in there look for foreign objects that have wedged against the drum preventing it from turning.
Oct 09, 2012 | KitchenAid KEYS850LQ Electric Dryer
Amana Dryer LEA30AW
usually the humming sound is coming from the motor,try this,open the door,turn the drum with one hand and hold the door switch in with your other hand and have someone else push the start button at the same time,this might help the motor turn on but if it does you need a new motor,if you can't turn the drum you could have something stuck in the blower wheel or something jammed in the motor like a broken belt but like i said a humming sound is usually the motor.
Feb 22, 2012 | Amana Dryers
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
My dryer wont start. When i turn the button to start it, it hums but wont run.
something is jamming the drum of the dryer from turning... remove the casing and take a closer look. There may also have been something recently dried which may have come out and jammed the dryer drum. Try hand turning the dryer drum to see... it should freely revolve at least a little bit
Good luck with it
Feb 13, 2011 | GE DVL223EBWW Electric Dryer
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
Drum not turning, hear humming noise
the humming noise is from the motor,see if you can spin the drum by hand,if it moves you have a bad motor,if it's hard to turn you could have something stuck in the blower wheel or the belt is jammed somewhere,the blower wheel is behind the duct that the lint filter slides into
Mar 20, 2010 | Whirlpool LER4634J Electric Dryer
Drying humming but drum will not turn
the humming is from the motor,try turning the drum by hand,if you can turn the drum the motor is bad, it might start after you spin the drum but it will stop again,if you can't turn it the belt could be locked up on something or something is stuck in the blower wheel located underneath the lint filter,you might have to remove the duct that the lint filter slides into to get at whatever might be stuck in the wheel.
Feb 04, 2010 | Kenmore 63942 Dryer
We just purchased a new Samsung Dryer model #DV218AEB/XAA the lights will come on but when you attempt to start the dryer there is a hum, the dryer does not spin, then the hum goes away after a few...
Could be a couple things causing this problem. If you can turn the durm by hand without much resistance then the belt may be too loose. This could be because the spring on the tension pully came off or the belt streached. The humming you hear is the motor spinning. If you cannot turn the drum by hand then something could be stuck between the drum and the frame of the dryer.
I would also check that the dryer is wired correctly, because low voltage could be causing the motor to hum but not turn.
Dec 23, 2009 | Samsung DV218AEW Electric Dryer
When start button is pushed, hums but does not run. Drum does not turn. Belt is okay
It sounds like it is the motor or a stuck/obstructed blower wheel. You can start by opening the door, push the door switch in, hit the start button & see if you can turn the drum clockwise by hand. This might get it going. if the drum does not move by hand then the problem is probably within the blower. post your findings for a follow up
May 01, 2009 | Dryers
Dryers Logo
65 people viewed this question
Top Dryers Experts
