Question about Ruud UBHC Air Conditioner
Ruud heat pump makes a clicking sound
Ruud heat pump clicks when producing heat when the compressor comes on. No click is heard when only the fan is running.
The term H.P. is just a reverse flow a/c. do you have one big machine outside or do you have the h.p. outside with the "airhandler" inside. up in the attic, a closet,garage, etc?
if the sound you hear is coming from the airhandler, then it is the heat strip relay/contactor kicking i and out providing supplimental heat.
if it is the outdoor machine, or h.p. then it can get tricky.a onetime click is probly the contactor sucking in or the reversing va;ve energizing.if it is numerous clicks then it becomes a low voltage control problem.
a loose connection can cause this.check around the contactor, reverse valve solinoid, and control wire nuts.Quite possibly a bad relay.look for the rvr solinoid not being on the 4 way valve properly.
good luck with low volt problems.
Posted on Dec 29, 2008
  • Ruud Master
  • 5,568 Answers
Many thermostats have a setting to keep the fan running instead of cycling with the compressor. Check its settings.
Posted on Dec 21, 2008
Is a RUUD UBHC-14J11NFH a heat pump?
Compressor and condenser not included
Spec sheet go here
Jul 04, 2014 | Ruud UBHC Air Conditioner
Not making Ice
Are you getting any heat from the condenser? Sounds like the buzzing is the compressor failing to pump.
Mar 25, 2014 | Franklin Freezer Chef FIM70 Commercial Ice...
Condensor fan went out on 1999 ruud heat pump.
Did you try pushing in the contactor to see if the unit will even run?
Jul 18, 2010 | Ruud UBHC Air Conditioner
I have a Ruud Heat Pump system. The outside unit makes a humming sound in either heat or cooling modes. The fan won't come on. In cooling mode, the compressor starts up, but them shuts off after about a...
Sounds like your condencer fan motor is stuck. Can you take a long rod and when the power is off to the outside unit, spin the fan blade? Maybe it will be enough to get it working again.
Apr 07, 2010 | Heating & Cooling
Rudd Heat pump shuts down. Compressor is on and goes out on
Is your condensor coil clean?Needs air to breath.
Feb 12, 2010 | Ruud UBHC Air Conditioner
Ruud heat pump outside fan won't run
Tell him to make tight connections.
Jun 23, 2009 | Ruud UBHC Air Conditioner
Frig. and Freezer not cooling. Clicking sounds heard every 2 mins
sure sounds as if it is def a compressor overheating, now that the compressoe will be cooled it should work , but your right damage may be already done, the good news if any is that you should be covered under 5yr manufactures warr for compressor
Dec 22, 2008 | Maytag MTF2155GRW Top Freezer Refrigerator
Outside unit clicks while thermostat auxiliary light flashes
Sounds like the compressor starting relay or capacitor is defective. When the compressor could not start, the electric heat came on to satisfy the heat requirement and causing the emergency heat light to come on at the thermostat. This light warns you that electric heaters are energized. And they use a LOT of electricity! Call a different company for service. And do it soon.
Nov 16, 2008 | Ruud Handler Air Conditioner
Ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Sep 15, 2008 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
331 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
